Go to Post If you think it is such an outrage, then be a do-er and not a talk-er. - BrianBSL [more]
Unread 12-05-2006, 13:05
frodus frodus is offline
frodus is an unknown quantity at this point
VEX and Assembly or PICBASIC
I have Picbasic and the MPLAB but am wondering if anyone else has gotten asm files to work. I haven't played with it much, but would like to know if others have had experience with assembly. I can go from picbasic, to assembly to a hex file, but have trouble getting it to work. I might just have the include files wrong.
I want to use picbasic, because its easy and i know it. I don't know C very well (i could learn, but don't have time) and i already use picbasic for my oopic board with a 16f877a and would like to continue using the same program.
Thanks in advance. Travis
CMUcam w/ PICBasic wvenhau Programming 1 07-03-2006 15:07
Camera Assembly and Software? The yellowdart Programming 3 21-01-2006 10:31
pic: 885 Right-center wheel and drive assembly CD47-Bot Robot Showcase 2 30-04-2004 18:27
2004 Drill motor and gear assembly number LamdaCubed Motors 4 27-01-2004 22:47
Importing assembly into an assembly... James Green Inventor 8 22-01-2004 22:17
