Go to Post I'm currently working on design for a bin made out of concrete that will not break for next year's competition... :D - dlavery [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 02-05-2006, 23:37
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
Re: Why didn't your team use the Kitbot frame in 2006?
Originally Posted by chakorules
Kitbot and rivets don't mix well for us either.....
Really??? What problems did you have exactly? We used the Kitbot frame and riveted it together with 1/4" aluminum pop rivets to save weight and get rid of those pesky KitBot frame nuts and bolts that keep falling out. We never had a problem and the frame is as solid and tight today as the day we put it together in January.
Unread 03-05-2006, 00:45
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
Originally Posted by Raving Rabbi
our team didn't use the kitbot this year because we knew like 696 that we could make a better one for ourselves. we used 2x1 aluminum 1/8 thick tubing and welded a frame (like 254, 60 etc) it is much easier to work with but requires the ability to machine. it worked out well for us and is extremely strong. also the most important feature is that when you finish you can powdercoat it and make it look really sharp because it doesnt matter if it runs well it just has to look good right?
-guy
Actually, we did use a kitbot frame in competition this year. When our powder-coated robot decided to hang out in SoCal until Thurs night of the Greater Toronto Regional, we obtained a kitbot frame from the TechnoKats to build the "One-day Wonder". It was very easy to assemble, quite strong, and though not the most mass efficient chassis, it was quite acceptable. The predrilled holes for the axles (with the center wheel axle slightly lower than front and back) and transmissions makes assembling the drive components very straight forward. Next year, we'll have our "newbies" build a drive base from the KoP frame and transmissions so they can have a driveable 'bot early in the build season.
P.S. Guy says a good looking robot is better than one that is running well just to "jerk my chain". I guess I'm just not one of those "form-over-function" people.
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
Unread 03-05-2006, 01:24
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
The kitbot frame could be improved (we collapsed parts of it this year just from our conveyor belt to pick up balls), and is impracitcal for some drive systems. I think building our own chassis would be interesting; however with no machining or even welding capabilities, our team is quite happy to get the kit frame than trying to invent something of our own with nothing but hand tools like we've had to do in the past (I think we might have managed to get someone to do a tiny bit of welding for us). The kitbot works very well, and unless you're a team who knows what they're doing, I think it's the best way to go.
Of course I'd just love to do a fiberglass or wood frame and be totally custom, but I'll stick with what we can do for now.
Unread 03-05-2006, 01:32
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I see building a custom frame as a great FRC pastime that so many new teams are missing out on.
Unread 03-05-2006, 07:41
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
We used the kit bot last year and it bent and racked.
My self and some of the other mentors knew we could do stronger and lighter with welded box. We took a ~13 lb kitbot and replaced it with a sub 2 lb box frame. We however have access to welders who weld thin wall tubing all day long.
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 11-05-2006, 21:38
GB330033 GB330033 is offline
Programming Manager
FRC #1255 (Team Blarglefish)
GB330033 will become famous soon enough
Send a message via AIM to GB330033
1" square steel tubing > kit frame.
The kitbot frame became the basis for our robot cart, and served us well.
Hook'Em
Unread 11-05-2006, 21:43
Rohith Surampudi's Avatar
Rohith Surampudi Rohith Surampudi is offline
probably needs a new WAI
FRC #0075 (RoboRaiders)
Rohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond repute
Send a message via AIM to Rohith Surampudi
umm what exactly does the kitbot frame look like, our team has used our own chasis design, but i want to see how different it is from the kitbot frame
Blargha!
Unread 11-05-2006, 21:47
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
Here is a link to the IFI's website where it shows what the kit frame looks like.
Unread 12-05-2006, 16:11
JoeXIII'007's Avatar
JoeXIII'007 JoeXIII'007 is offline
Pragmatic Strategy, I try...
AKA: Joeseph Smith
FRC #0066
JoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond repute
Send a message via AIM to JoeXIII'007
Amen.
We've used a similar frame design, but built it out of Bosch extrusion for the simple reason that its simple to build off of and simple to use. Simple simple simple, gotta love it and hate it at the same time.
However, being next year is my senior year, I want to build something other than a boxy drivetrain. It's what we've been going with since 2000 something.
Joeseph P. Smith
jpthesmithe.com
University of Michigan - Informatics (B. Sci. 2012)
General Purpose Programmer - Cooperative Institute for Limnology and Ecosystems Research (CILER) at NOAA-GLERL
Unread 12-05-2006, 23:08
Jon Jack's Avatar
Jon Jack Jon Jack is offline
VEX Robotics
no team (No Team)
Jon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond repute
Send a message via AIM to Jon Jack
We were going to use the kit chassis. Then we realized that we would end up having to make modifcations to the kit chassis for our harvester and that those modifications made the kit chassis much weaker.
So we designed our own. Surprisingly our chassis is about 2-3 Lbs. lighter than the kit chassis and is much stronger. We will for sure be making our own chassis next year.
Team 1538 / The Holy Cows, 2005-2016
Unread 13-05-2006, 09:23
RoboMadi's Avatar
RoboMadi RoboMadi is offline
3 Fs..... Fun Friends FIRST!!
AKA: Imad
FRC #0612
RoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant future
Well it depends on the kind of game and what is needed. This year we used the gear boxes from the kit, but built our own frame out of Bosch, because its really simply to use as stated above and provides you with infinite possibilities as far as position of the tires goes.
Last year, out team actually built the Ackerman Drive System. It was really cool, until we had a system breakdown, tow days before the shipment, and have to switch the whole drive system to the kit drive system.
Unread 13-05-2006, 20:46
Umm Errr...
The kitbot is great if you want to build a kitbot, but we wanted to build a 1139 bot. Building your own frame takes minimal effort, gives infinite flexibility and theres nothing stronger than a welded connection. Designing around the kitbot seems like more trouble than its worth.
1139 Alumni
Unread 13-05-2006, 22:22
Beth Sweet's Avatar
Beth Sweet Beth Sweet is offline
is getting lost in her new home
FRC #0116 (Epsilon Delta), #1504 (alum), #67 (alum)
Beth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond repute
This is going to sound really silly, but we didn't use it this year because we didn't have to. It was kind of like a right of passage, we can do what we want! Kind of a reward for doing so much better in getting sponsors this year
This season, I was a part of a great team, with great kids who were really inspired, and who inspired me back. That's my brag, what's yours?
Unread 14-05-2006, 00:29
run the trap!!!
Team Role: Human Player
Our team did use the kitbot frame in 2006. But I sure wished we hadn't.
The problem with that frame is that it has no cross bracing to prevent bending. Over time it will slowly deform.
Which is what happened to us.
We started out with a six-wheeled, rocking (center wheel lowered), robot and ended our last match without any rock. The whole frame had literally been bent into an arch, with all six wheels flat on the floor.
To make matters worse the sides also bent in-wards! This distorted our chain path causing us to perpetually lose chains during matches.
I will be very hesitant to use the kitbot again in the future.
-Philip J. Fry
Unread 14-05-2006, 00:39
AKA: Ari
Very true... but to solve the problem why not make your own cross bracing to prevent it from bending?
... the kit chassis that is provided in the kit is very useful and I am sure many teams thank FIRST for providing them each year.
Please post your 2006 Chairman's Award entries nehalita Chairman's Award 3 22-03-2006 19:22
Thank you Team 179, team 237, team 269, team 303, team 1065, and team 1251 Arefin Bari Thanks and/or Congrats 13 16-03-2006 20:52
How do you organize your team? NoodleKnight Team Organization 18 03-11-2005 22:57
Who do you think is the best bet to win the Chairman's Award at the Championship? Koko Ed Chairman's Award 58 29-04-2005 16:39
Real names, please Andy Baker General Forum 131 21-07-2004 22:07
