Go to Post I'm intrigued by the possibility of Mayan stadium sports, minus the whole sacrificing part. - AlecMataloni [more]
Unread 13-05-2006, 19:33
Doug Leppard's Avatar
Doug Leppard Doug Leppard is offline
FRC #1902 (Exploding Bacon)
Doug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond repute
Send a message via AIM to Doug Leppard
Mapping VEX I/O to FRC code
I want to practice and adjust our FRC code using the VEX. Do you know of a document that explains the mapping of IO that is used in FRC and correlates FRC IOs to the VEX IOs?
When I complied the FRC code in the VEX the following variables were not defined:
'p1_x' has not been defined
'p1_y' has not been defined
'p3_wheel' has not been defined
'p1_wheel' has not been defined
Also on the VEX it says interrupts, how is that mapped to the FRC code. There is a lot I don't understand between the two.
Doug Leppard
Unread 13-05-2006, 23:23
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
Re: Mapping VEX I/O to FRC code
What are you using for both, EasyC for vex, for FRC or MPLab all the way, with these different options the coding and structure are different so we will need to know what your using b4 we can really help.
KK4KQO
http://voltair.us
Unread 14-05-2006, 02:32
DonRotolo's Avatar
Back to humble
FRC #0832
You need to look at what those mean, exactly, and translate that to Vex.
p1_x is OI port 1, the "X" direction. This would possibly translate to Channel 1 on the Vex controller. But, of course, you can define it as Channel 3 (which is "X" on the left joystick instead of the right), or anything else you like.
p1_y might be channel 2
The three "wheel" values are the switches on the little thumbstick on the standard KOP joystick. It is also an analog input (like X and Y) and has no equivalent on the Vex controller. Maybe a good use for Channels 3 and 4 or, with some limits, channels 5 and 6.
As a hint, you'd use the "RX Input" block.
Look at this schematic to help in understanding what the joystick does, and then you can think about how to replicate that functionality on the Vex controller.
Note that the FRC OI is a LOT more versatile than the Vex transmitter.
Don
Unread 14-05-2006, 06:45
Thanks. It is MPLab all the way. I want to play with our FRC code on a VEX, try various sensors on the VEX before we move it to the big FRC bot.
Doug Leppard
PIC18F8520 port mapping to VEX microcontroller module. Yuriy Programming 2 28-04-2006 13:11
Using Vex Brain as FRC Coprocessor Tom Bottiglieri General Forum 25 18-04-2006 22:36
FRC/VEX Challenge Rick TYler General Forum 32 05-04-2006 21:54
VEX 2005 = Mini FRC 2004 Joe Johnson FIRST Tech Challenge 12 08-04-2005 17:22
