Go to Post Quit hitting me with lexan, I'm NOT a pinata. - hcps-ruwedt [more]
Unread 13-05-2006, 21:51
Joe_Widen's Avatar
Joe_Widen Joe_Widen is offline
FRC #1675 (The Ultimate Protection Squad)
Joe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud of
Making Gears
Well, I'm a bit novice to cad, so whats the easiest way to make gears?
Finally in college =]
2009 Midwest Regional Champions - Thanks 111 and 1625
Unread 13-05-2006, 22:04
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Re: Making Gears
If you actually want to make gears, the easiest way is to cut them from gear stock.
If you want to model them in Inventor, start with a disk-shaped blank, model a tooth shaped cut, and pattern it. To get the cut to look right, experiment with arc shaped edges by adjusting the radius of the arc. To get the cut to actually be right, learn about involute gear teeth by reading a good reference. You can find several good ones online by Googling "involute gear" or something similar.
Richard Wallace
since 2003
Unread 13-05-2006, 22:22
K.Shaw's Avatar
K.Shaw K.Shaw is offline
The Zoomin' Human
AKA: Shaw 1, kevshaw, little shaw
FRC #0237 (Sie-H˛O-Bots (See-Ho-Bots), FLL #3954 (Swift Eagles))
K.Shaw has a brilliant futureK.Shaw has a brilliant futureK.Shaw has a brilliant futureK.Shaw has a brilliant futureK.Shaw has a brilliant futureK.Shaw has a brilliant futureK.Shaw has a brilliant futureK.Shaw has a brilliant futureK.Shaw has a brilliant futureK.Shaw has a brilliant futureK.Shaw has a brilliant future
Send a message via ICQ to K.Shaw Send a message via AIM to K.Shaw Send a message via MSN to K.Shaw Send a message via Yahoo to K.Shaw
Re: Making Gears
www.firstcadlibrary.com
2005 Bash @ the Beach Winners -Thanks Team 1511 and Team 181
2005 NJ Regional Finalist -Thanks again to 56 and 303
2005 Radioshack Innovative Control Award-NJ
2005 FLR Semi-Finalists
2005 Radioshack Innovative Control Award-FLR
2004 Archimedes Divisional Semifinalists
2004 NJ Regional Winners. -Thanks Team 56 and Team 303!
2004 NJ G.M. Industrial Design Award Winner
2004 UTC Motorola Quality Award Winner
Unread 13-05-2006, 22:33
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: Making Gears
Here's one of the best tutorials that I've found; it's set up in Pro/E Wildfire 2, but as long as you can get Inventor to solve the equations, I think that it could work. It's heavy on math, but you can scroll down to the solved equations, and implement those without necessarily working through the theory.
This will get you proper gear geometry, suitable for scaling to any size, and for cutting on a machine (such as an EDM, or a maybe even a waterjet or laser). Depending on your computer, and Inventor's capabilities, it may also take a long time to regenerate that sketch, every time you load the model.
In practice, you don't necessarily need that sort of precision for many jobs—it's really up to you, depending on what you need it for, and what tolerances your equipment can hold. In the event that you can deal with slightly imperfect geometry, try GearGen (or here), which will output a gear with small arc segments, rather than a continuous curve, in .dxf format. This can be imported into Inventor, and extruded.
In any event, for simply drawing the gear, you can just pattern an approximately correct tooth (using an extruded cut) around the circumference. It's also common to just model the gear as a cylinder with the pitch diameter.
Unread 13-05-2006, 23:16
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
Re: Making Gears
in inventor 10
File>New...>Standard.iam>Dropdown on Assembly Panel and Click Design Accelerator>Spur Gears
You should be able to get it from there....if you don't have inventor 10 talk with whomever is the main contact because they recieved the software.
Unread 13-05-2006, 23:29
Philip W. Philip W. is offline
Philip W. is a splendid one to beholdPhilip W. is a splendid one to beholdPhilip W. is a splendid one to beholdPhilip W. is a splendid one to beholdPhilip W. is a splendid one to beholdPhilip W. is a splendid one to behold
Re: Making Gears
(Someone beat me to it, but here are more details)
If you have Autodesk Inventor 10+, you can use the Design Accelerator. It's a new tool in version 10 and in assembly files; it creates parts such as gears, sprockets, bolted connections (i.e. inserts a bolt and optional washers and nuts according to different parameters) and others. While in an assembly file, go to Tools > Design Accelerator. Select Gears (or something like that) and run through the wizard. I'm not too sure what the next steps exactly are. Play around with it and you'll get the hang of it. You'll probably want to stick to Designer mode instead of Engineer or Expert. Remember, you need to do this in an assembly file. After finishing the wizard, it'll create the gear part files in the project folder. Alternatively, you can save the part as a new file once it is in the assembly. I hope you understand this, ask again if you don't and I can get back to you with Inventor 10 equipped.
If you don't have Autodesk Inventor 10+, which is my situation since my computer specs aren't to its liking, you can download gear parts.
1. Go to SDP/SI's Online Catalogue
2. Find the gear you're looking for.
3. Click on its part number.
4. Click on 3D CAD Models in the bottom right corner of the popup.
5. Click on Downoad CAD Model.
6. Select STEP as your format (I believe STEP is better for Inventor than IGES and DXF, but I might be wrong) and download.
The gear part you download may not be exactly how you want it (wrong bore size or thickness) but you can always edit the file or copy the profile of the gear to a sketch in another part file.
I hope you are using gear models for presentation or manufacturing purposes, otherwise it's pretty much unnecessary and will only slow your computer down by trying to display such a complicated CAD model. Circular discs with the diameter equal to the pitch diameter of the modelled gear will suffice for most designing purposes.
Unread 13-05-2006, 23:52
Joe_Widen's Avatar
Re: Making Gears
Yeh, thanks for your help. I guess I'll stick with circles....they do the job. I'm using Alibre Design so I cant really use all those tools. Thats my fault, I should have stated it. Thanks again.
Unread 14-05-2006, 00:11
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Making Gears
As far as I know, Alibre should be able to import STEP or IGES files such as those downloadable from FIRST CAD Library.
Unread 14-05-2006, 00:46
Joe_Widen's Avatar
Re: Making Gears
sanddrag beat me too it. I figured out how to import from the FirstCadLibrary. Well thanks for the help.
Unread 14-05-2006, 18:41
negfrequency's Avatar
negfrequency negfrequency is offline
the guy with the drawings
AKA: Willomatic
FRC #1559 (Devil Tech)
negfrequency is just really nicenegfrequency is just really nicenegfrequency is just really nicenegfrequency is just really nicenegfrequency is just really nice
Send a message via AIM to negfrequency
Re: Making Gears
Im still reading the book on the design accelorator and cannot completely use it yet so for the time being this is what i do:
make a circle to the diameter of the gear and extrude it. I then draw two lines that are dimensioned at an angle of say 360/24/2/2. This would be for 24 teeth. draw a "V" and set the bottom to the depth of each tooth, and then extrude the cut. revolve by the number of teeth. Lastly, for constraint animations, i draw another circle SLIGHTLY smaller on top and extrude it to flatten the tips of the teeth to a similarly sized circle.
The math works itself out quite easily and your left with gear that may be easily constrained to an animation as the computer can find the gear ratio when assembling the product itself since the egdes of the teeth act resemble a similarly sized circle.
I just started the fisher price motor. Its shown below, and is only about halfway done and some resizing needs to be done, but it animates VERY well.
www.evolved-ideas.net
-KOP CAD parts available for download
You know your me if.....
5) your 91 honda civic dx drives @ warp .000005376, not 60 mph
4) You know what "Bi-directional parametric associativity" is
3) Playing Diabolo does NOT mean you are a level 24 mage.
2) You've discovered you can rearrange the letters in William to spell "I am Will".
1) Your bicycle is 3 times more expensive than your car.
Making an Animation Jimbo5051 3D Animation and Competition 4 31-01-2006 21:05
Making Friends! :-) redragon226 Chit-Chat 17 23-12-2005 11:55
Making the gears drive - motion ronmarkum Inventor 4 17-12-2005 20:11
How to setup CNC for making dog gears sanddrag Technical Discussion 4 01-01-2005 23:21
