Go to Post The best way to brainstorm is to just do it. - EricH [more]
Unread 14-05-2006, 18:49
Andrew Blair's Avatar
FRC #0306 (CRT)
Re: Using Misled Facts As Scare Tactics
Hmmm... I see one major issue wiith the DVD backup arguement. People should backup their data frequently. A DVD must be written, then erased again should data need to be changed. Should you have important important files, they are typically also changed often or added to often. Unless you compile an entire folder of important files, then burn them, you'll end up with many different disks: an un-organized, inconvenient backup system. Not to mention the fact the time it takes for you to compile the folder, leaving those file not backed up. (And I HATE having to use that little CD tray... It's sooo...mechanical...)
I will agree with you however that a DVD is likely more survivable in a flood disaster. Wet DVD vs. wet hard-drive? Probably the DVD will stand a better chance.
A more conservative and easier thing to do would be to use a backup hard drive often, then backup really important files every month or two or twelve on a DVD. That way, you retain an extremely convenient way to backup files, (hard drive, flash, etc.), while also occasionally doubly insuring your really important files. Cause DVD's are pretty resilient. (DVD vs. truck, hard drive vs. truck?)
-Sir Francis Bacon
-Albert Einstein
Unread 14-05-2006, 18:59
Adam Shapiro's Avatar
Adam Shapiro Adam Shapiro is offline
FRC #0555 (Montclair Robotics)
Adam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud of
Send a message via AIM to Adam Shapiro
I agree. I definitely wouldn't recommend using a DVD for continuous backup, but rather for more periodic backup (however periodic is very relative and depends on the type of user as well). I'm not sure about the last part though. I think in either case something sized on the order of a DVD or hard drive would likely not survive a fight with a truck.
Mentor to Teams 555, 1929, and 2070!
Currently working in hardware design at Cisco.
Cornell University DARPA Urban Challenge - http://www.cornellracing.com
Co-Captain Team 555 - 2003,2004,2005
Trust, Love, and Magic
Unread 14-05-2006, 19:46
FRC #0306 (CRT)
Eh, if it was flat...
-Sir Francis Bacon
-Albert Einstein
useless facts Timmyd Chit-Chat 24 22-11-2005 22:44
Do defensive, low scoring tactics work? haverfordfords Rules/Strategy 37 18-02-2005 12:25
Help with Recruitment Tactics Rez648 General Forum 2 03-06-2004 23:36
Strange FIRST Facts Koko Ed General Forum 28 15-03-2004 17:44
Useless facts chellyzee93 Chit-Chat 47 05-11-2002 22:11
