Go to Post The GDC made something easier??? Link or it didn't happen! - JesseK [more]
Unread 15-05-2006, 09:27
Mark Pierce Mark Pierce is offline
FRC #0085 (B. O. B.)
Mark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant future
Re: Teams: How did you use your potentiometers this year?
Last year we used pots to read position on all three arm movements (height, left-right, angle) with corresponding pots on the OI for direct position control. Yes, we converted the values into degrees for the arm angle.
This year we used one pot in conjunction with two selector switches on the OI to adjust many values. I had hoped to implement storing these values in EEPROM, but never got that far. Still, setting the shooter speed and turret position PID loop values was easy. Once we found the values we wanted, we just hard coded those as defaults.
How many drive motors did you use (per side) this year? Billfred Motors 19 16-10-2004 20:27
How did you thank your engineers/mentors/sponsors this year? Bharat Nain Thanks and/or Congrats 15 01-08-2004 21:18
will your team use bumpers this year? Alex Cormier General Forum 7 30-01-2004 15:31
How did you learn how to use Inventor? Greg McCoy Inventor 26 24-05-2003 01:55
