Go to Post College was the best twenty years of my life. - Richard Wallace [more]
Unread 16-05-2006, 21:08
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
TI-89 Titanium
Ok, First of I have no idea where this belongs, but I want it somewhere that egineers will see it because they will most likely know.
I have a TI-89 Titanium calculator and in our math classes we use TI-83's. So this has brought up the problem tat things are obviously radically different between them.
Right now in Math (Math B, NYS Regents course) we just go done using the list function to enter a data set and using one var and 2 var functions to view mean, median, standard deviation( both little sigma and S) and all that. if you have an 82-84+ go do it and you will see what I am talking about. and in 2 var we used the r-value. I have now idea how to do any of this on my calculator and some assistance would be extremely helpful.
For sake of ease lets all use the same data set, and say it will be a little part of the fibonacci sequence. how bout we use:
{1, 1, 2, 3, 5, 8, 13, 21}
I would like to know how to put these into a list and then do something so that I can view all the one var stat values and 2 var stat valueson it like on the 82, 83 ,84...ect....
I hope you understand my question.
Unread 16-05-2006, 21:23
Kyle Fenton Kyle Fenton is offline
GET IT ON!!
FRC #0121 (Rhode Warrior)
Kyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud of
Send a message via AIM to Kyle Fenton
Re: TI-89 Titanium
Look at your manual for the proper syntax, but I think this is it
press 2nd "5" go to statistics
and you have all of your options
I know you can do list, so you don't have to enter the #'s over and over again. I think it is define, but I don't know how to get there
Rhode Warriors
NAVSEA/Raytheon/URI/Middletown, Portsmouth, Tiverton, Mt. Hope HS
Quality Robots Since 1996
Unread 16-05-2006, 21:59
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
Re: TI-89 Titanium
I figure out that much but I can't do anything more then that, I can't do anything with the list.
Unread 16-05-2006, 23:03
Back after 4 years off
FRC #5279
Re: TI-89 Titanium
I think this is what you are looking for
press apps to get to the menu, go to stats/lists (down 2, right one from home) press enter
this brings you to the list, (same as stat-> edit on the 83)
name the folder you want to save it in )so you can find it later if you don't want to enter it, then press enter (If you have entered a list recently it will not prompt you to do this)
Enter the data in the list of your choice (use list 1 for convenience) once you enter all of the data press enter once then press F4 (calc) select either 1-var or 2-var stats, press enter.
In the window that opened enter the list you put the data int (list1 or list2 etc. L1 and L2 don't refer to lists like on the 83) Press enter wait a couple seconds (don't press enter again if it says busy at the bottom of the screen just wait) A new window should open with all of the things you wanted in it.
If this is not what you wanted, try to reword your question and maybe I can help, If you have AIM my sn is Jamesbrownssn, that would be an easier way to talk.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 16-05-2006, 23:19
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
Re: TI-89 Titanium
Ok well I figured it out except for the onevar and two var stats. When I press F4 it wants med to enter a label for the colum or something, it goes to c1=[promt]. I can press F7 and a screen pops up but none of the numbers on there look like standard deviation, I know how to figure it out from home, but I would rather not have to retype a data set everytime I wanna do something.
Unread 16-05-2006, 23:30
FRC #5279
Re: TI-89 Titanium
Once you have all of the data entered (like I described above) press F$ (when you are still in the list editor, that should bring up a drop down list of 1-Var Stats, 2-Var stats. regressions etc select 1 or 2 depending on what you want, hit enter, a new wont will open, it will have list then a box you can type in, enter the name of the list you want to use, then hit enter ignore the other boxes (they should read from to to bottom 1, the second box after list should be blank then {} in the third box, hit enter and it should display what you want.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 17-05-2006, 00:41
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
Re: TI-89 Titanium
It doesn't do anything close to that. Mine does what I described earlier. What is F4 labeled on the top bar? on mine it says "F4 Header"
I just realized...I don't have the app you described, I have "data/matrix editor", but on of the file types in it is a list, and I just choose that when I open a new list. Also I cannot load a new app on my calc because I haven't gotten the right cable in the last 9 months....>_<
Can you describe how to do it in the default program that comes pre loaded on it, if it is possible in that
Edit:http://www.acad.sunytccc.edu/instruc.../stat/ti89.htm
I guess according to that I can't do stats on my calculator which is weird because mine isn't old I only bought it in september. I guess I need to go to the store and buy a cable this week so I can do my Math homework....
Unread 17-05-2006, 13:53
FRC #5279
Re: TI-89 Titanium
My 89 is new (I bought it in january) My calculator came with the app I am talking about on it, I am not sure if the first version of the 89 titanium had the app.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Titanium and magnesium fasteners? waialua359 Technical Discussion 7 12-02-2006 22:58
Titanium chain & sprokets rubicondsrv Kit & Additional Hardware 16 27-01-2005 13:00
Wear Data on Titanium Machining marias Technical Discussion 4 14-05-2004 13:24
Titanium Tubing (Small Parts Catalog) archiver 2001 5 23-06-2002 23:25
Brass Gears and Titanium Chubtoad Technical Discussion 3 16-01-2002 09:48
