Go to Post Fame is a funny thing, you can do nothing and get it, and do everything and get none. For me, it's not fame, but infamy that follows me. - Joe Matt [more]
Unread 16-05-2006, 22:47
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Hex Broach Options?
Originally Posted by Bill_Hancoc
I understand what a broach is used for but never actully cutting my own keyways could someone explain how one is used? Thank you very much
a hex broach has a cylindrical end to it that is the same OD as the ID of the pilot hole in your part. This helps align it with the part. You then use a press to push it through the part. the broach gets progressively larger as you approach the top, until it reaches it's finished size.
With a standard keyway broach, you have a bushing that has the same OD as the ID of the hole you're broaching, with the profile of the key removed from the edge so that you can push the broach through with a press.
2001-2004: Team 100
2006-Present: Team 254
Hex Couplers Chris 481 Technical Discussion 9 03-04-2006 20:49
Standard keyway broach in a metric bushing sanddrag Technical Discussion 2 18-02-2006 01:17
hex file garbage? sciguy125 Programming 2 04-07-2005 23:04
HEX CRAWLER... Arefin Bari Chit-Chat 3 01-05-2004 00:12
Options! Brandon Martus Announcements 0 15-04-2002 13:08
