Go to Post If all else fails, just ask the judges to turn off the gravity! :D - [more]
Unread 17-05-2006, 12:42
frodus frodus is offline
frodus is an unknown quantity at this point
Re: Homemade parts
there's lots of places online to get ESC's...
If you want to drive a heavier load servo, just make sure you follow the BEC (battery eliminating circuit) specifications. I THINK you just need to connect the ground wire of the cable from the pic to the ground of the battery you use together (reference same ground), signal wire goes to servo, and the positive lead from the battery goes to the positive lead of the servo, thus not using the vex to power the servo. JUST MAKE SURE that the battery you use is NOT more than the input voltage of whatever you are driving. There are also optocouplers that you could use to drive the servo off if you want.
I would just be safe and get a cheap ESC, i have one if you want it, send me $10 and shipping costs and its yours. Its a novak.
here's a good site too, for drivers:
http://www.pololu.com/products/pololu/#servcon
HomeMade Motor Controllers John Gutmann Electrical 19 06-08-2007 18:06
homemade speed controlllers (for school project) Denman Electrical 26 18-04-2005 11:07
Homemade Robotics Clothes Jill1022 General Forum 9 28-03-2005 14:57
Must Return Spare Parts to Small Parts? Pierson Rules/Strategy 10 20-03-2004 09:34
Parts dropped from the 2003 Kit of Parts? D.J. Fluck Rumor Mill 38 03-01-2003 19:29
