Go to Post I hate mini-bots. - Gdeaver [more]
Unread 17-05-2006, 18:43
Andrew Blair's Avatar
FRC #0306 (CRT)
Re: Hex Broach Options?
Originally Posted by geo
We made a hex broach this year our of a harden steel rod for our 2 speed gearboxes. We used a surface grinder to make the hex shape on the rod. I would 've taken a picture of it if we didn't loose it...LOL
I've heard of using a sharpened Allen wrench, after hardening it. Unfortunately, I doubt it would perfom on a high carbon or stainless steel.
-Sir Francis Bacon
-Albert Einstein
Unread 17-05-2006, 19:29
lupjohn's Avatar
lupjohn lupjohn is offline
AKA: Larry Upjohn
FRC #0692 (FemBots)
lupjohn is an unknown quantity at this point
Andrew;
here is an article supporting your idea.
It is from the Home Shop Machinist, 2002 Sept.-Oct. Issue page 36
titled:
"Make Your Own Socket Head Fasteners with the Brinkerhoff Rotary Broach".
It is an interesting approach and does use a hex key that is sharpened and hardened. Unfortunately the magazine does not provide online copies of the article. Enjoy Larry Upjohn.
Unread 18-05-2006, 04:02
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is online now
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
If this is for a school or robotics project, how about calling all of the shops within a 1hr drive and asking them to wire EDM or broach the parts for you? I bet you'd be able to find someone to do it for free within a weeks time of when you call. That is a conservative estimate, too.
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 18-05-2006, 08:24
Greg Perkins's Avatar
Greg Perkins Greg Perkins is offline
7 years, allready!!???!?!?!
AKA: Mongo
Greg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond repute
Send a message via AIM to Greg Perkins Send a message via MSN to Greg Perkins Send a message via Yahoo to Greg Perkins
*cough* waterjet *cough*
If you can find a shop locally that has one that may be able to waterjet your parts for free, look into it. You might not always get the friendly shops, so another option would be www.dcwaterjet.com I believe you can have your gears dropshipped to them and they do the cutting.
myResume -2004: PARC Referee; Beantown Staff; Battlecry Referee; Summer Frenzy Head Referee; River Rage Head Referee, 2005: Pittsburgh Regional Referee; PARC Referee
XBOX Live Gamertag = TrixAre4Kidss
Unread 18-05-2006, 10:55
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I don't think I'd waterjet something like that. I'd be worried about the draft.
Unread 24-05-2006, 11:25
Dick Linn's Avatar
no team (Synergy)
Here's one possible way:
"Make up a fixture to hold the [item] you want to broach the hole in. Ideally the end should be vertical but horizontal will do. Take a good quality allen key
and cut the short end off it. Drill a small hole about 4mm diameter through the
key about 1/2 inch from one end - you'll see why later. Then heat the other end to bright yellow and quench in boiling water to get a superhard tip. Grind the end to get sharp cutting edges.
Drill the hole in the piece to be broached at the size across the flats of the
allen key. Make it a bit deeper than you need so there is somewhere for the
swarf to go although if you want a bar magnet in there you'll have a smaller
deep hole anyway which will be fine.
Now you need a guide for the allen key to run in. Take a piece of steel about
3/4 inch thick and drill a hole through it just smaller than the size across
the corners (not the flats) of the allen key. Then tap the allen key through it
and you have just broached your first hole. Mount this piece of steel so the
hole in it is central to the part to be broached. You now have a guide which
will keep the allen key bang on centre all the time.
Now just tap the allen key into the workpiece a bit at a time and pull back to
blow out swarf. If the allen key sticks then use a small tommy bar in the hole
you drilled through one end of it. If you want the broached hole to be as dead
to size as possible then do this. Heat the workpiece in a flame to 200 degrees
C or so until you have broached to full depth. This will expand the workpiece
and the broached hole will be a tad undersize when cool. Then let it cool and
contract again and take a final cut in one hit to the full depth.
It's a lot of messing about to make one hole but you'll get it dead true and
dead to size if you do it this way.
Dave Baker at Puma Race Engines (London - England) - specialist flow
development and engine work. ."
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 24-05-2006, 12:07
For that amount of work, I think I'd just buy a broach. And how do you grind the allen key without losing some dimension? Surely the end result would not be able to freely slide over a piece of hex stock like it would had it been done with a real broach.
Unread 24-05-2006, 12:32
Dick Linn's Avatar
no team (Synergy)
In this case, they were only grinding the end of the allen key. Think of it as a broach with one edge. Similar to a mortising chisel attachment for a drill press.
A clever machinist/toolmaker can do amazing things with rather simple machinery. In this case, the idea is to make a real broach. Even if you were to taper it and make several steps, it's really only the final step that makes much difference. Whether it will work or not depends on the precision of fit required.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 24-05-2006, 13:48
David Hoff's Avatar
David Hoff David Hoff is offline
FRC #4050 (Biohazard)
David Hoff is a name known to allDavid Hoff is a name known to allDavid Hoff is a name known to allDavid Hoff is a name known to allDavid Hoff is a name known to allDavid Hoff is a name known to all
This year our team faced the same decision. Spend the money and get a hex broach or find a different way of locking it to the shaft. We decided to spring for the broach because in the long run we will most likely use it several times over the next several years. They are expensive but we feel we will get our money out of it. If you think you won't use it more than once or twice then I probably wouldn't buy it.
Cyber Blue Team 234: Indianapolis, IN 2002-2006
Purdue FIRST Programs: West Lafayette, IN 2006 - 2010
Cyber Titans Team 3793: Frederick, MD 2012
Biohazard Team 4050: Chambersburg, PA 2014
Unread 24-05-2006, 22:30
Not2B's Avatar
Not2B Not2B is offline
AKA: Brian Graham
And here is the OTHER answer...
EBAY!!
I just searched for broach hex on ebay, and found a few. Just need to get lucky - but they can be found for cheap.
Brian Graham
Unread 26-05-2006, 00:05
Veselin Kolev's Avatar
Veselin Kolev Veselin Kolev is offline
X51 Production Company PGM (TM)
Veselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond repute
Go to a waterjet shop.
Ask them to demo their waterjet.
By cutting some 1/2" hexes in 1" steel.
And ask if you can keep it as a souvenier.
Proceed.
Unread 26-05-2006, 13:25
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
buy a 3/8" hex and go!
$130 is not all that expensive if you consider all of your options. if you buy the right size, a size that will fit all your applications then that one broach will probably last you your entire life.
as long as you use the broach correctly and feed it plenty of high quality lube then you'll be fine.
we do a lot of broaching in our lathe. put the material in the chuck and the broach in the tailstock......lock, crank, broach. very simple.
no more keys, no more trantorqu......just cheap hexagon stock.
our 3/8" hex broach is going strong after hundreds of broachings.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Hex Couplers Chris 481 Technical Discussion 9 03-04-2006 20:49
Standard keyway broach in a metric bushing sanddrag Technical Discussion 2 18-02-2006 01:17
hex file garbage? sciguy125 Programming 2 04-07-2005 23:04
HEX CRAWLER... Arefin Bari Chit-Chat 3 01-05-2004 00:12
Options! Brandon Martus Announcements 0 15-04-2002 13:08
