Go to Post I don't even care if it doesn't work as well as they would like. YOU MADE IT. You may never use it, but you made it. AWESOME. Every year there has been 1 team (sometimes 2) that has done something that really stood out. This year 1 team has done 2 things that stand out. Thanks guys. - rees2001 [more]
Unread 17-05-2006, 22:06
CraigHickman
Posts: n/a
Inventor 11: Frame maker
Hey all-
I got a chance to use Inventor 11, and I noticed that the frame generator is a perfect tool, almost as if it were created for FIRST teams. So how many of you all plan on using this?
I personally love the ease of changing frame material, and how simple it is to make corners and joints in the frame.
So what's your ideas and thoughts on it?
Unread 17-05-2006, 22:07
Greg Perkins's Avatar
Greg Perkins Greg Perkins is offline
7 years, allready!!???!?!?!
AKA: Mongo
Greg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond repute
Send a message via AIM to Greg Perkins Send a message via MSN to Greg Perkins Send a message via Yahoo to Greg Perkins
Re: Inventor 11: Frame maker
I use Inventor 11 at work, but have yet to find this. Where do I access it in the software?
myResume -2004: PARC Referee; Beantown Staff; Battlecry Referee; Summer Frenzy Head Referee; River Rage Head Referee, 2005: Pittsburgh Regional Referee; PARC Referee
XBOX Live Gamertag = TrixAre4Kidss
Unread 17-05-2006, 22:08
David Guzman's Avatar
David Guzman David Guzman is offline
AKA: Dave
FRC #1251 (The Techtigers)
David Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant future
Could you elaborate on what it does and how it does it, for those of us haven't gotten the chance to use Inventor 11.
Team 1251 The Techtigers
2010 FL Regional Winner (BIG thanks to 86 and 1612)
2009 FL Regional Finalist (BIG thanks to 79 and 744)
2008 FL Regional Winner, FL GM Industrial Design, SC GM Industrial Design
2007 FL Regional Winner, FL GM Industrial Design, Palmetto Regional Finalist, Palmetto Motorola Quality.
2006 Palmetto Regional Winner, Daimler Chrysler Team Spirit Award
2005 FL Regional Judges Award, FL Regional 3rd seeded and finalist, Palmetto Regional Xerox Creativity Award, Palmetto Regional 1st seeded and finalist
2004 UCF Regional Rookie All-star Award
Unread 17-05-2006, 22:10
CraigHickman
Posts: n/a
The Frame generator allows you to draw lines, and it then creates a frame with specified materals(eg. 1x1 box extrusion, bosh sxtrusion, etc.), and corners/joints.
I forget exactly where it is... I'm not at home right now, I'll check when I get there.
Unread 17-05-2006, 22:18
Pat McCarthy Pat McCarthy is offline
FiM Volunteer
FRC #0067 (HOT Team)
Pat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond repute
Send a message via AIM to Pat McCarthy
Oh man, I can't wait to download it from students.autodesk.com !
2003-2006: FRC Team 67 - Drafter, Driver, Student Leader
2006 Volunteering: Kettering Kickoff Ref, Team Ford FIRST Robotics Invitational Ref
2007 Volunteering: GLR Field Reset/Repair; WMR Robot Inspector and Scorekeeper; MARC Referee
2008 Volunteering: WMR Planning Committee, WMR Scorekeeper, MARC Ref, IRI Scorekeeping, WMRI Scorekeeping & DJ
2009 Volunteering: Kettering District, MARC, IRI, and WMRI Scorekeeper/Field Power Controller
2010 Volunteering: Kettering District, MARC, IRI, and WMRI Scorekeeper/Field Power Controller
2011 Volunteering: Waterford District, West Michigan District, MARC, & IRI DJ
2012 Volunteering: Waterford District, West Michigan District DJ
Unread 17-05-2006, 22:49
petek's Avatar
petek petek is offline
What would Dave do?
AKA: Peter Kieselbach
FRC #3654 (Tech Tigers)
petek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond repute
Send a message via AIM to petek
The new Framemaker utility is going to save a lot of time in prototyping frames and other structures. It can create a frame which conforms to either a 3D wireframe (placing a frame element along each line) or you can wrap the frame around a shape, following its edges.
It does not create constraints between the frame members (it just locks their positions), but it does take care of cutting the ends to fit each other (miter, butt, etc.) and can "dress" the ends to prep for welding.
Framemaker creates the structures using profiles included in the Framemaker library. As delivered by Autodesk, these are standard ANSI, ISO, etc. tubes, angles, I-beams, etc. You can add custom profiles, but it is not a trivial task. Sean Dotson has a tutorial up already on adding a custom size for an existing profile and is working on one for adding your own profile (I'm thinking 8020, Bosch, etc.).
While you're at Sean's site, make sure you check out the winning entry in the Tinkertoy Inventor modeling contest - it's amazing.
Pete Kieselbach
Unread 18-05-2006, 10:25
negfrequency's Avatar
negfrequency negfrequency is offline
the guy with the drawings
AKA: Willomatic
FRC #1559 (Devil Tech)
negfrequency is just really nicenegfrequency is just really nicenegfrequency is just really nicenegfrequency is just really nicenegfrequency is just really nice
Send a message via AIM to negfrequency
Agreed. prototyping is going to be infinitely easier. General shapes can be made in a matter of seconds with the 3d sketch feature, which will be far more useful because of this. However, the detail is going to remain minimal on final structures, i would not use it on my autodesk competition submission.
www.evolved-ideas.net
-KOP CAD parts available for download
You know your me if.....
5) your 91 honda civic dx drives @ warp .000005376, not 60 mph
4) You know what "Bi-directional parametric associativity" is
3) Playing Diabolo does NOT mean you are a level 24 mage.
2) You've discovered you can rearrange the letters in William to spell "I am Will".
1) Your bicycle is 3 times more expensive than your car.
Unread 19-05-2006, 13:41
petek's Avatar
What would Dave do?
If we add the profiles we use on our robots to the library, I don't see any reason not to use a FrameMaker assembly in a submission. They aren't any different from an extrusion you might make without FrameMaker and there's nothing to prevent you from editing the parts.
When you think about it, you might get points for using FrameMaker or some of the other productivity tools. But that's just a guess on my part.
Pete Kieselbach
Unread 19-05-2006, 13:45
REVving up for a new season
FRC #2848 (All-sparks)
Well considering your past success....i would say your guesses are probably good.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 19-05-2006, 15:42
Andy A. Andy A. is offline
Getting old
FRC #0095
So, you can now produce a three dimensional sketch and use those lines as placement for frame members. You can also assign end treatments.
So, is this any different from how Solidworks handles weldments? It sounds like more or less what SW has been doing for a while now, but maybe I'm missing something? Is there any aspect of this that puts it way ahead of the competition?
-Andy A.
Unread 29-05-2006, 21:21
Joe_Widen's Avatar
Joe_Widen Joe_Widen is offline
FRC #1675 (The Ultimate Protection Squad)
Joe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud of
Can someone post a couple screenshots of the frame generator during the outlining of the frame and and end product, and all the cool stuff in between please?
Finally in college =]
2009 Midwest Regional Champions - Thanks 111 and 1625
Unread 30-05-2006, 14:16
petek's Avatar
What would Dave do?
Ask and ye shall receive. Here's a very simple example using ANSI square tube from the Frame Generator's stock sizes (why do I keep wanting to call it Frame Maker?) and simple butt joints. Note that the wireframe is 28 x 38 and I offset my tubes inside by .25 all around to make sure it fits in an arbitrary sizing box...
As for Solidworks, I couldn't say if this is the same kind of utility since I haven't used that program, but in any case we aren't comparing CAD packages, just exploring a feature in Inventor. If Solidworks has this already, that should help SW users, too, and I hope they have a lot of other great features for Autodesk to catch up with!
1. Create 3D wireframe envelope for frame:
2. Change to Frame Generator in Assembly tools pallet and use the Insert tool to create frame members:
3. Use Trim To Frame tool to trim overlaps:
Pete Kieselbach
Unread 30-05-2006, 15:49
Pete, when you make a frame maker Assembly and save it does save each individual member like ipart bolts or are each their own .ipt?
then when you put that frame into another Assembly how do the members take to editing from that screen? each member individually or do you have to go back into the frame builder tool.
Unread 30-05-2006, 16:30
Getting old
FRC #0095
From what I can see in the screen shots, it looks pretty nigh identical to how things are accomplished in Solidworks.
I'd love to try it for my self, but I have not be able to get Inv11 installed using the downloads from students.autodesk.com. I think my problem is coming from corrupt files, but I can't get around to downloading them all again (dial up!).
Anyone else having trouble with Inventor 11 downloaded from the student website?
-Andy A.
Unread 30-05-2006, 16:37
Bill_Hancoc's Avatar
Bill_Hancoc Bill_Hancoc is offline
Volkswagen Enthusiast
AKA: Bill Hancock
FRC #0573 (MechWarriors)
Bill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud of
Send a message via AIM to Bill_Hancoc
how can i register for students.autodesk.com if im not in college yet and dont have a college email address
MechWarriors 573
Movie Maker Mirza95vx IT / Communications 11 16-03-2005 21:18
Movie Maker Mirza95vx Technical Discussion 11 16-03-2005 21:18
know of a free gif maker? Mike33 Chit-Chat 3 02-03-2005 16:59
Windows Movie Maker 2.1 Yan Wang Chit-Chat 1 23-02-2005 14:55
Looking to borrow a button maker... 1685isalive General Forum 0 31-01-2005 14:03
