Go to Post Don't you people have jobs? - Koko Ed [more]
Unread 19-05-2006, 00:10
Xufer's Avatar
Xufer Xufer is offline
8 Seasons and as stable as ever
AKA: Working, 2/4 degrees complete still schooling...
FRC #1740 (The Cyber Colonels)
Xufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to behold
Send a message via AIM to Xufer Send a message via MSN to Xufer Send a message via Yahoo to Xufer
Emergency!! Help trouble shoot!!
Alright we pulled the robot out today for a demonstration and a final check before we head up to Bean town Blitz on Sat for the most part everything seemed to work correctly except we kept losing radio signal now and again finally watched do this over again until i noticed a pattern.
It would work alright for the first minute or so then the signal would come and go intermittently work for a few then quit for a few. Finally after a few mins have passed the signal would disappear altogether.
we also lost control over certain aspects of the robot, i.e. a switch would run a relay fwd but not rev.
we are going to try swapping the one or both of the radios tomorrow if we can borrow them from one of the other local teams.
So any suggestions, or comments would be greatly appreciated we don't have much time to get this working before Bean town but heres hoping we can!
Thanks In Advance!!
If saftey is first and i put FIRST ahead of everything, then i must be the safest guy in the world.
Team 521 Alumni -- Team 1740 Mentor-- Go Go 1740!
Sometimes I think I've been doing this too long and other times I think I haven't done this enough... but all the times I'm sure I'm crazy
Photonics, It's Your Future
Unread 19-05-2006, 00:17
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Emergency!! Help trouble shoot!!
Make sure you are using the correct year OI and radios. Try changing serial cables. Get away from fluorescent lights. Try changing team number to something greater than 2048 then changing the channel. Try reloading code.
Unread 20-05-2006, 11:33
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Stupid question, but were all the batteries charged? Robots do very funny things with low batteries. Also make sure you're using the right power adapter for the OI and haven't swapped it with something else. Also, also, if you're seriously thinking it's a radio issue, tether up the robot and run it around in the same fashion. That will tell you pretty quickly whether it's the radio or not. Just basic troubleshooting, really. Eliminate things methodically and one by one. Shotgun toubleshooting often just leaves you more confused.
pic: To shoot or not to shoot? JVGazeley Extra Discussion 2 29-03-2006 14:45
Emergency Vic 884 Help Needed psychoCHIPMUNKK Control System 10 22-01-2005 11:36
Emergency Vic 884 Help Needed psychoCHIPMUNKK Electrical 10 22-01-2005 11:36
Emergency:Streamline help Pat Roche Inventor 4 14-03-2004 10:40
Emergency Team 25 Needs Help Keith Chester Technical Discussion 19 25-02-2004 21:35
