Go to Post In FIRST you have the right to remain silent, anything you say can and will be held against you and your associates in the court of public opinion. - Koko Ed [more]
Unread 18-05-2006, 21:35
Joe_Widen's Avatar
Joe_Widen Joe_Widen is offline
FRC #1675 (The Ultimate Protection Squad)
Joe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud of
Sensors
Well, the team I am on is currently looking for sensors to increase the performance of our robots. Can you give me some specifics on good sensors that have worked well for your teams. I'm looking into sensors of every type. Please send the name, approximate price, and what it does.
Finally in college =]
2009 Midwest Regional Champions - Thanks 111 and 1625
Unread 19-05-2006, 01:15
RbtGal1351's Avatar
RbtGal1351 RbtGal1351 is offline
~La Reina de los Robots~
AKA: Stephanie
FRC #1351 (TKO)
RbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to behold
Send a message via AIM to RbtGal1351 Send a message via MSN to RbtGal1351
Re: Sensors
Okay, the basic sensors that FIRSTers use:
Limit switches: Mechanical switch.
USE: Robot has an extending ladder. Mount limit switch and the bottom, and when the switch is pressed, don't let the motor retract the arm (in software). < $4 per.
(Also, reed switches (magnetic) and optical sensors can be used similarly.)
Potentiometers: Variable resistor. Think of a volume control knob. Plugs into the Analog input; reads 0-1023 in code. You'll probably want LINEAR taper, not Audio taper, so one "tick" is the same # of degrees rotation. 1 turn, 5 turn and 10 turn are the most common.
USE: Robot has an articulated arm. Mount a pot to the joints to see what angle the arm is at. (Good for autonomous control, or making a mini-arm for the OI to control it by position.) < $4 per.
Gyro: Senses the rate of rotation in one plane. You can integrate the data to get the degrees of rotation. (Position from rate of change.) Kevin has code for this. (I think, anyway, you can find what direction you're facing...)
USE: Rotate accurately autonomously. Or interesting driver control of a robot with omni wheels. (Push the joystick forward and the robot goes away from you no matter what, you'd need a gyro for that.) ~$50 per. Kevin's site has suggestions on where to buy and which.
Encoders: Count gear teeth that go by. You can tell how far you've gone or the position of an arm.
USE: Driving accurate distances autonomously, for one. In that use, coupled with a gyro, you can tell where you are on the field at all times. (You'll need sin and cos functions, if you'd like a table look up sin approximation function in software, PM me. I still have to comment it, though.)
I don't know which types of encoders are best (optical? hall effect? etc.), where to buy them, or how much they cost. Could someone reply with that information please?
Dials/dipswitches: Many switches --> multiple combinations.
USE: Set to a position, do a different autonomous mode based on the switch position. If you have 4 switches, you could have 16 different modes.
You can also get encoded dials (easier to solder and attach PWM cables). (I can't find the link to the one we bought on jameco.com).
One set of dipswitches (8): < $1
Encoded dial w/ 16 positions: ~$3
(Our encoded dial was really small and you had to set it with a flathead screwdriver. Has anyone found a bigger one that can be set manually? Thanks.)
Other sensors possibly used: Camera, Infrared, Light sensors (for line following in 2004).
Hope this helped, not really sure what you were looking for.
~Stephanie
Team 1351 Controls Leader and Leader Programmer 2005-2006
2004 Founding member and Arm leader, 2005 Lead programmer, 2006 Controls leader, 2007 Project Manager/President
Thanks for making FIRST such a great experience for me. I'm no longer on 1351, and I'm not currently planning to mentor team 97, but FIRST has meant so much in getting me to where I am now, in life and at MIT, class of 2011.
I met Billfred! He recognized me!
SVR 04: 11th seed - Highest Rookie Seed - Semifinalists w/ 1120 and 568 - GM Industrial Design Award
SVR 05: Semifinalists w/ 8 and 766
SVR 06: 6th seed - Quarterfinalists w/ 368 and 1072
Davis 06: 1st seed - Quarterfinalists w/ 649 and 100 - KPCB Entrepreneurship Award
SVR 07: 36th seed
David 07: 4th seed - Semifinalists w/ 1280 and 692 - Johnson and Johnson Sportsmanship Award
Unread 19-05-2006, 10:40
Mike Bortfeldt Mike Bortfeldt is offline
FRC #1126 (& 1511)
Mike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud of
Re: Sensors
We have used the following components and have found them to be reliable.
Gyro:
Analog Devices ADXRS300EB - $50
Used to calculate robot heading - mainly used for autonomous navigation.
Potentiometer:
Bourns 6639 Series - $11
if you are going to connect one to an analog input on the RC, use one with less than 2.5k ohm resistance (1k works well). Used to know the position of our multi-jointed arm in 2005, and our turret angle in 2006.
Optical Encoders:
Bourns ENT1J Series - $70
We've used these for 2 years in our drive transmissions. Used to measure distance traveled, and control drive speed (PID).
Grayhill 63K or 63R Series - $60
Used to control our 2006 shooting wheel speed.
Be careful when mounting the encoders to minimize side loads on the shaft as this can cause premature failure of the device.
Mike
Unread 19-05-2006, 11:51
Adam Shapiro's Avatar
Adam Shapiro Adam Shapiro is offline
FRC #0555 (Montclair Robotics)
Adam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud of
Send a message via AIM to Adam Shapiro
Re: Sensors
Unless something changed drastically this year that I am unaware of, analog inputs read from 0 to 255. This corresponds to 1 byte (8 bits) of data input.
Originally Posted by Mike Bortfeldt
Potentiometer:
The RC reference guide recommends using a 10k-ohm linear taper potentiometer on analog inputs. They say to use a range from 250-100k, but I have found that their 10k recommendation is usually very good and provides more than enough resolution.
Mentor to Teams 555, 1929, and 2070!
Currently working in hardware design at Cisco.
Cornell University DARPA Urban Challenge - http://www.cornellracing.com
Co-Captain Team 555 - 2003,2004,2005
Trust, Love, and Magic
Unread 19-05-2006, 11:54
Re: Sensors
10 bits resolution (0-1023) on the RC analog inputs.
You're thinking of the 8-bits of resolution (0-255) for OI analog inputs
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Re: Sensors
The ADCs on the 8520 and 8722 are 10-bit (0-1023). It has been this way since the move to the C-based RCs a few years ago.
Unread 19-05-2006, 12:00
Re: Sensors
Wow, I guess I just never took notice of that. I haven't done the programming myself since the Basic Stamp RCs! That's nice to have so much of a higher resolution.
Unread 20-05-2006, 00:30
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Re: Sensors
We only really used one sensor other than the camera this year, so I'll list that as well as a few past ones/ones we're looking at:
Gyro: The Analog Devices ADXRS300EB that other people have already mentioned is good, ~$50. The kit ones are just a slower model with the 80 degrees per second, but anything less than 150 degrees per second is (I think) unacceptable, so the 300 degrees per second this sensor can handle is nice. The gyro was used for autonomous turning, but more importantly a very simple piece of code can be written to use it to help make your robot drive straight (we programmed it to work based on the joysticks, so our robot would drive straight during driver operation as well).
Limit Switches: Very cheap (less than $15), can be found at just about any electronics store (Radio Shack sells them in spare parts drawers). These provide nice safety limits for rotating or sliding mechanisms (to make sure you don't break an arm) and if you use them cleverly can be used to tell linear position (we used them in an arm that elevated vertically by having a metal piece slide along a track with multiple limit switches in it, and wrote autonomous code to automatically go to certain switch positions).
Potentiometer: Still pretty cheap (less than $10), available at most electronics stores. Potentiometers provide nice rotational feedback if you want a position rather than just limits. There's an interesting whitepaper on using them in place of encoders as well.
Accelerometer: Can't name a good one as I haven't used them, but most sell for between $30 and $50 (I know analog devices sells a number of them, and one was included in the kit). Accelerometers can be used for inertial navigation, but this would require a nice amount of math for the processor and small errors grow rapidly due to the math (without a high price model, I haven't found a sensor with enough accurate resolution to use for this). They can be used as a sensor for the earth's gravity though, and with a tiny bit of math you can determine the current angle your accelerometer is at with the earth based on the acceleration it reads, so you can make a nice anti-tip function programmed in your robot.
Sonar: Most cost $25-$50, the newer Maxbotix Sonar sensor outperforms most of the others out and only runs around $25 (this is from word of mouth from other sources, I've never used it). The only useful thing sonar can give you is distance of an object in its field of view, so you can use it to avoid walls/find a wall or goal in autonomous. I'm looking into developing a robot-dodging (for offense) and robot-seeking (for defense) autonomous mode with them, but something like this may not be very feasible.
Unread 26-05-2006, 15:11
Ken Leedle Ken Leedle is offline
College Student
FRC #0706 (CyberHawks)
Ken Leedle will become famous soon enoughKen Leedle will become famous soon enough
Re: Sensors
Slide Potentiometer: These come in various slide lengths and are useful for some applications where linear motion can be measured. We used one in a our control box for controlling the launch angle of the shooter.
IR Photointeruptors: These can either be used as limit switches, rotational encoders or anywhere else you want to see if something is there. We constructed one using a IR led pulsed at 38khz and a IR reciever for sensing if a ball was in our scoop. The effective range of this sensor is between 1 foot and 30 feet depending on the current through the LED.
Unread 27-05-2006, 00:12
intellec7's Avatar
intellec7 intellec7 is offline
108 programmer
AKA: Gustavo
FRC #0108 (SigmaC@ts)
intellec7 is on a distinguished road
Send a message via AIM to intellec7 Send a message via MSN to intellec7
Re: Sensors
Perhaps you could use a cheap Hitachi 44780 based parallel LCD and around 4 I/O lines (clock, data, enable, R/S) and a shift register ?
Unread 03-06-2006, 13:54
Joe_Widen's Avatar
Re: Sensors
I think one of the mods should make this a sticky for all the rookies and teams that want sensor feedback.
Unread 03-06-2006, 18:30
Alekat's Avatar
Alekat Alekat is offline
AKA: Alex
None #0701 (RoboVikes)
Alekat has a spectacular aura aboutAlekat has a spectacular aura about
Send a message via AIM to Alekat
Re: Sensors
I think it's great that your looking into sensors. We really just started getting our hands dirty with them last season but I have a lot of faith the team will step up to the next level next season.
Unread 25-06-2006, 21:45
987HighRoller's Avatar
987HighRoller 987HighRoller is offline
Vegas....Baby
AKA: Alex Sambvani
FRC #0987 (High Rollers)
987HighRoller has a spectacular aura about987HighRoller has a spectacular aura about
Re: Sensors
Can somebody post some more info on accelerometers, I have no experience with these. Also, so more info on gear-tooth sensors would be helpful as well.
Team 987 - The High Rollers - Las Vegas, Nevada
2007 Las Vegas Regional Finalists
2007 Newton Champions
2007 Championship Winners! Thanks to 190 and 177
2008 IRI CHAMPS with 67 and 330
where can we buy hall effect sensors or gear tooth sensors amirjpl Electrical 3 13-02-2006 11:02
Sensors cprogrammer Technical Discussion 3 06-12-2005 13:00
I R Sensors thoughtful Programming 2 06-02-2004 11:45
Sensors. Josh Hambright Technical Discussion 4 17-02-2003 11:08
sensors George Technical Discussion 15 08-01-2003 14:39
