Go to Post I like anything that is designed to bounce for up to 10 minutes. Expecially if it lands right side up :) - GregT [more]
Unread 23-05-2006, 06:28
dani dani is offline
Junior Member
FLL #0002
dani is an unknown quantity at this point
ADXRS150 turn rate controller help required...
Hi all,
I am working to make a angular turn rate controller for Radio Controlled aircraft. The main requirnment for this task is that rc aircraft should not go into unsafe bank which is actually when an aircraft turns too quick i.e. it complete 360 degrees in less than 2 min. the 2 minute turn is safe but less then this will cause aircraft to be in unsafe bank.
For this i am using ADXRS150EB the gyro from analogdevices.com. But unfortunately I am not able to figure out the correct priciple of a turn rate control therefore i couldnt write the correct code for this. So is there some one who can help me regading using ADXRS150EB for making a turn rate control for an RC aircraft.
Regards.
Dani
Unread 23-05-2006, 09:04
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Re: ADXRS150 turn rate controller help required...
The ADXRS150EB has a sensitivity of 12.5mV/°/s and reads the turning rate of itself, so to ensure that the aircraft does not turn too fast, you should just need to read the value of the gyro and then compare it to a limit on speed. For example, if you wanted to make sure to never turn faster than 20°/s, you would just read the value of the gyro and make sure it is not more than 250mV over or under 2.5V (which is typically the voltage when stationary of the gyro, you might want to test it and find out what yours is though).
Unread 23-05-2006, 11:18
A model RC / Hobby plane would have no trouble turning 360° in 2 minutes - it would have no trouble doing a 360 in 10 seconds (Ive been flying RC planes for 30 years)
but an auton RC plane with a heavy payload would have to turn slowly to avoid stalling its wings.
BTW, no offense intended but I'm a little leery assisting someone in Pakistan to design a control system for an autonomous RC aircraft. I don't know how many RC hobbyists there are in Pakistan, but I do know of other people in that part of the world who are very interested in autonomous aircraft!
EDIT: Im already taking a lot of (red) flack for my post in this thread - Its my opinion that we should not help anonymous first time posters who live on the boarder of a war zone to design autonomous aircraft.
Sorry if I come across as a jerk, but in this case I prefer to err on the side of common sense!
Unread 23-05-2006, 13:16
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Originally Posted by KenWittlief
BTW, no offense intended but I'm a little leery assisting someone in Pakistan to design a control system for an autonomous RC aircraft....
I think this comment plays into many stereo types that I think are largely undeserved.
Also, even if the concern was valid, this seems to me to be a pretty pathetic attempt to gather info.
Using Pakistan in his/her profile (I apologize for now knowing if Dani is a masculine or feminine name) is sort of a silly thing to do if one is trying to get access to sensitive data.
Beyond this, there are full blown, very well developed open source projects on inertial guidance (including How To's and Source Code!) available to anyone in the world with access to Google.
Even more, if you have access to Tower Hobby or 1000 other hobbyist websites, there are off the shelve solutions to autonomously fly RC airplanes.
There are a lot of things to fear in this world and a lot of people that might be good to question under the influence of Veritaserum But I doubt that Dani belongs on either list.
Callin' 'em as I see 'em...
Joe J.
Team #88, TJ2
Unread 23-05-2006, 13:50
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
SNIP!
Well that was uhh...rude.
As far as turn rate goes, if you can use a more sensitive gyro with a slower maximum turn rate, that will also help. Or perhaps (I'm not an EE here (yet ) so bear with me) using an opamp to amplify the signal and make it a little cleaner?
Matt Krass
Unread 23-05-2006, 14:55
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
It's a pretty sad day when anyone thinks they can pass racism off as common sense, Ken. You should be ashamed of yourself.
--Madison--
...down at the Ozdust!
Unread 23-05-2006, 14:59
Katie Reynolds Katie Reynolds is offline
no team (NEW Apple Corps)
Katie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond repute
Send a message via AIM to Katie Reynolds Send a message via Yahoo to Katie Reynolds
Closing this before it gets out of hand.
Dani, I believe Donut answered your question.
Team #93 - NEW Apple Corps
Student - 2001-2004
Team #857 - Superior Roboworks
Mentor - 2006-2009
ADXRS150 gyro yaw rate sensor Brian M. Electrical 13 17-10-2004 02:28
EduBot Help, RC Controller Allison K Robotics Education and Curriculum 5 29-03-2004 16:48
ADXRS150/300 Sensor m0rph3us Electrical 2 06-02-2004 22:37
Help On Coding 2K1 Controller GregTheGreat Programming 9 05-12-2003 18:35
Help - Gear Motor Controller dteshome Motors 17 13-05-2003 15:13
