Go to Post "Take a man to a FIRST contest and he's entertained for three days. Teach a man to build a FIRST robot, and he's out of your hair for six weeks a year..." - kmcclary [more]
View Poll Results: What size wheels?
< 4" 3 3.30%
4" 13 14.29%
5" 9 9.89%
6" 32 35.16%
8" 28 30.77%
10" 2 2.20%
12" 4 4.40%
Voters: 91. You may not vote on this poll
Unread 24-05-2006, 20:29
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Wheel size poll
I seem to recall having asked this before but I searched and did not find, so here we go. What size wheels did you use this year on your robot? Please round to the nearest size. If you care to elaborate on anything, feel free to post below.
Unread 24-05-2006, 20:33
Joe J.'s Avatar
Joe J. Joe J. is offline
My Gaming Is FIRST!
AKA: Joey
Joe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond repute
Send a message via AIM to Joe J.
Re: Wheel size poll
862 used 2 8" Skyway and 2 8" IFI wheels (2" wide).
Joe Jagadics
Lead Mentor / Coach
Lightning Robotics FRC Team 862
Unread 24-05-2006, 20:45
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
Re: Wheel size poll
2 8" AM Omni (trick wheels) for the front.
2 8" 2" wide IFI wheels for the back.
We used 8" so we'd have enough ground clearance for that ramp.
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
Unread 24-05-2006, 20:50
Billfred's Avatar
Billfred Billfred is offline
Re: Wheel size poll
Two 8" IFI wheels combined with four 8" Skyways (used for cost purposes).
Unread 24-05-2006, 20:54
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Re: Wheel size poll
Four of these. Effective diameter 4.8 inch.
Richard Wallace
since 2003
Unread 24-05-2006, 21:13
Andrew Schuetze's Avatar
Happy Birthday! Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC &amp;amp; FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
Re: Wheel size poll
We used these
6" o.d. wheel, with 14 rollers
Weight 0.75 pounds
Hardware Body Material is molded black glass-filled polycarbonate plastic
1.125" id bore (sized for 1/2" id bearing)
Worked well at the Lone Star regional. Heavy hitting and pushing on Archi in Atlanta resulted in at least four wheels cracking apart from hard hits. AM reports that they are going to look at a softer plastic that can bend but not break verses the strong yet brittle material used this year. It made for a very cool holonomic drive with four of these mounted at 45 degrees.
Looking into mecanum options for next year with hopes of someday being able to crab steer.
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
Unread 24-05-2006, 22:23
Lil' Lavery Lil' Lavery is online now
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: Wheel size poll
8" IFI traction wheels x 4
As a rule of thumb, bigger wheels mean you can traverse more uneven terrain. Yes, this can be acheived other ways, but bigger wheels tend to save weight and complexity (think of the 2004 stairs for a perfect example).
Smallers wheels are lighter and take up less space (duh!), which leaves more space/weight for the rest of your robot.
Simple trade-off.
Unread 24-05-2006, 22:38
Re: Wheel size poll
Simple trade-off.
Maybe not that simple.
Assuming equal motors, faster robots don't push as hard. So no matter what wheel diameter you choose, you still have the basic speed vs. force trade-off to consider. You find your own optimum solution by selecting your gear ratio (or ratios in the case of a shifting system) and your wheels.
8" IFI traction wheels will need about twice the gear ratio that 4" IFI traction wheels need, to get to the same speed and force. If your speed reduction system gets larger or heavier, or less efficient, because of the higher ratio, then you'll need to consider that trade-off against the benefit of larger wheels.
As always, the right answer depends on the game.
Richard Wallace
since 2003
Unread 24-05-2006, 23:21
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: Wheel size poll
I was assuming that you'd adjust the drive shaft rpm to match speeds, as I was purely comparing wheels, not entire drivetrains. Yes, wheels essentially act as the final gearing on the shaft, and you must adjust the shafts rpm to match your desired speed/torque. But you have to do that no matter what wheel size you chose.
Unread 25-05-2006, 00:11
Brian C's Avatar
Brian C Brian C is offline
Doer of Whatever
AKA: Brian Cholerton
FRC #1468 (J-Birds)
Brian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant future
Re: Wheel size poll
6" wheels all around. 4 skyway pneumatic tires, one on each corner of the robot and 2 A/M traction wheels. 6 wheel drive.
2017 Season; Game Announcer at
SBPLI Long Island Regional
Unread 25-05-2006, 11:03
Gene F's Avatar
Gene F Gene F is offline
FIRST Fanatic
AKA: Gene Falendysz
#0343 (Metal in Motion)
Gene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to behold
Send a message via AIM to Gene F
Re: Wheel size poll
We actually used tracks but one of the reasons is to give more stability. Large wheels reduce stance. Points of contact are closer to the outer edges of the robot with smaller wheels making it less likel to tip. The "wheels" we use with the track are about 3 inches.
- Gene Falendysz
Unread 25-05-2006, 12:49
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
Re: Wheel size poll
We used four 6" AndyMark plastic omniwheels (like those in Andrew Schuetze's picture). We only had one break, on our practice robot right before Nationals. We were in a heated battle with 469's practice robot at their field, and we got jammed up against the ramp and broke off one roller. Other than that, they worked great. A perfect balance of price and performance, IMO.
On a side note, in my experience, 6" wheels have usually been the "sweet spot" for most games that didn't involve large variations in terrain. They usually seem to be about the right balance of speed and power, without requiring excessive gear reduction. Also, I've used bigger wheels before, and they tend to take up too much space, and can sometimes make for awkward turning. They're great for games with ramps and stairs, but for a flat-field game, I always choose 6".
Jeff Waegelin
Unread 25-05-2006, 12:50
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
Re: Wheel size poll
Four 6" custom aluminum wheels with Nitrile tread, 3/4" width. Check them out.
Last year custom wheels with conveyor belt tread ruled the field. This year cheaper, simpler IFI and AM wheels ruled the field with their extremely wide tread (1" and over). This year 604 got pushed around because so many people had these wheels.
Darn IFI and AndyMark for making quality products!
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Unread 25-05-2006, 13:27
Joe_Widen's Avatar
Joe_Widen Joe_Widen is offline
FRC #1675 (The Ultimate Protection Squad)
Joe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud of
Re: Wheel size poll
Where do you guys get wheels that are easy to machine out like in the post above. I'm looking for some plain 4" wheels that i can machine out some of it and im not having any luck. Any rocomendations or anything to search for? Thanks.
Sorry A little off topic there, but this year my team used 6" AM omnis and 6"/1.5" Ifi's.
Finally in college =]
2009 Midwest Regional Champions - Thanks 111 and 1625
Unread 25-05-2006, 15:05
in between teams
AKA: Luke Van Oort
Re: Wheel size poll
6x 8" Skyway non-pneumatic wheels (KOP) ground flat with SBR Roughtop inclined conveyor belting from McMaster-Carr on them, attached with small wood screws. We ended up using ginormous 54-tooth AndyMark aluminum sprockets on them. Next year, I'd really like to downsize to 6", (Somewhere I have math that backs up what Jeff said about those being a sweet spot, at least in terms of gearing) although one of the mentors wants bigger wheels. (I really have no clue why)
Team 1219: 2009 - Mentor
2006 game poll #1 (field size) dhitchco Rumor Mill 18 30-12-2005 23:31
pic: Chantilly Academy's 4 Wheel Drive 4 Wheel Steering!!!! jskene Robot Showcase 25 18-02-2005 20:24
3 part wheel poll Zippiot Robot Showcase 2 11-02-2005 21:16
Calculating Wheel Size phrontist Technical Discussion 15 07-09-2004 18:55
Calculating Wheel Size To Climb Yan Wang Math and Science 12 18-01-2004 22:49
