Go to Post Picking up tetra's is going to be as easy as picking up a person of the opposite sex. While a select few will master it; others will be bumbling maroons.. - Elgin Clock [more]
Unread 25-05-2006, 11:15
Billfred's Avatar
Billfred Billfred is offline
Re: Coefficients of Friction
Originally Posted by sanddrag
That's what simple physics tells you, I know. But I have a feeling the interlocking action both on a macroscopic and microscopic scale between tread and carpet is anything but simple. Why do drag racing cars use such wide tires in the back?
Paul Copioli touched on that very question here.
<edit>There is a benefit to going wider in the form of slower wear on the tread surface. Perhaps not too useful for a one-regional team, but the long haulers might use that to their advantage.</edit>
realistic friction constants. Rickertsen2 Motors 11 18-10-2005 00:25
Thermal Expansion Coefficients FIRST JerseyKid Technical Discussion 2 05-04-2005 06:51
Coefficient of friction of tetra suneel112 Kit & Additional Hardware 1 12-02-2005 15:40
more on friction maxgebhardt Technical Discussion 0 15-01-2003 19:23
