Go to Post I thought Will.I.Am was a Dr. Seuss character - DonRotolo [more]
Unread 26-05-2006, 10:11
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Re: Coefficients of Friction
Originally Posted by JoelP
For example, if my robot was in a pushing match with another robot but unable to move it, the transmission would need to put out enough torque to cause the wheels to spin before the fuses blew. If the weight limit was increased, creating a larger frictional force which would have to be overcome by a transmission that wasn't designed to put out that much torque.
This is absolutely right.
If the weight limit goes up, suddenly a transmission that would have drawn 30 amps/motor will now draw 60 amps per motor, and you're in trouble.
Of course this could be easily fixed by changing the gearing in the transmission, but I'm not looking forward to making changes and testing a new transmission in the constrained conditions of the 6 week build period, especially when my team doesn't have the resources to quickly create parts for a new transmission.
So design a transmission that leaves you some breathing room...
I always try to leave some adjustability in the final sprocket reduction between the transmission and the wheel:
  • If I find the robot is going too fast, I can increase this sprocket ratio, to slow it down.
  • If I find the robot is going too slow, I can decrease this sprocket ratio to speed it up.
  • If I see FIRST has increased the weight limit by 30 lbs, I can increase this sprocket ratio to bring the motor-load back down to acceptable levels.
This method would allow you to design your transmission, and just tweak your final chain/sprocket reduction when you see the game.
JV
realistic friction constants. Rickertsen2 Motors 11 18-10-2005 00:25
Thermal Expansion Coefficients FIRST JerseyKid Technical Discussion 2 05-04-2005 06:51
Coefficient of friction of tetra suneel112 Kit & Additional Hardware 1 12-02-2005 15:40
more on friction maxgebhardt Technical Discussion 0 15-01-2003 19:23
