Go to Post It keeps your minibot from being destroyed by Dean's chainsaw, which is a big competitive advantage in future matches. - Joe Ross [more]
Unread 26-05-2006, 21:16
TimCraig TimCraig is offline
AKA: Tim Craig
TimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to behold
Re: Bolt hole circle without a mill
Along with the methods mentioned above, if you have multiple parts to make with the same bolt pattern, invest some time making an accurate template. Then you can duplicate your pattern without as much setup hassle.
Unread 26-05-2006, 22:59
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
This is actually pretty easy to do, and does not require a CAD system, transferring drawings, or anything more difficult than some simple scribing skills. Remember, machinists were doing these types of operations long before CAD systems, DROs, CNC machines, or EDM systems were ever invented. So there is usually a simple way to do a lot of these operations in a straightforward manner. In this case, it actually takes longer to explain than it takes to perform.
Mount a three-jaw chuck in the lathe (if you have a six-jaw chuck it would be even better, and make this whole operation trivial). Place a sharpened tool or scriber in the tool post, and adjust its height very precisely so that the cutting edge is on the centerline of the lathe. Make a short spacer that will fit in between the ways and the jaws of the chuck, so that when the chuck is rotated by hand it will stop the rotation by blocking passage of the jaw.
Coat the face of the part with marking fluid, and mount it in the chuck. BY HAND (not under power!) rotate the chuck so that one of the jaws is up against the spacer. Move the cutting tool in so that it just touches the face of the part. Run the cross-slide across, so that the tool scribes the part. You should now have a horizontal line across the face of the part that runs precisely through the center of rotation. Back out the cross-slide.
Move the spacer out of the way and BY HAND rotate the chuck 1/3 rotation. Put the spacer back in place and run the chuck jaw up against it. As long as there is no side-play in the chuck jaws, this will index the chuck precisely 120 degrees. Move the cutting tool back in, and run the cross-slide across to scribe a second line. Back the tool out, and repeat the whole operation a third time. You should now how three lines that intersect in the exact center of the part, and extend across the face of the part. The lines define six equally spaced radial segments.
Mount a sharp scribing tool in the tool post. Align the point of the scriber with the center of rotation of the part (where the radial lines intersect). Back the cross-slide out the desired radius of the bolt circle you want. Move the scriber in until it contacts the part, and then BY HAND (not under power!) rotate the chuck. This will scribe a circle that is concentric with the center of rotation of the part, and that intersects with the six radial lines. The intersections of the lines and the scribed circle will define the locations of the bolt holes.
When you are finished, take the spacer you made and store it away somewhere safe that you will remember. You will be using it again...
-dave
Unread 26-05-2006, 23:25
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
Originally Posted by dlavery
This is actually pretty easy to do, and does not require a CAD system, transferring drawings, or anything more difficult than some simple scribing skills. ... -dave
Pure old school genius!
Unread 26-05-2006, 23:03
Bill_Hancoc's Avatar
Bill_Hancoc Bill_Hancoc is offline
Volkswagen Enthusiast
AKA: Bill Hancock
FRC #0573 (MechWarriors)
Bill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud of
Send a message via AIM to Bill_Hancoc
dave beat me to it by 4 minutes
you should be able to scribe a circle on the part you want the holes on and then figure out where you want the holes...in this case ill use a 6 hole evely spaced bolt circle. First start by scribing the diameter you want the holes at. Find the degree of each hole 360degrees/6holes= 60degrees spacing. on the lathe mark a line then turn the chuck 60 degrees arny direction and mark you next 5 lines in this manner. to get the exact degree you need a backgear with 72 teeth which allows you to remove the pin and advance 1 tooth to rotate the chuck 5 degrees. to rotate the chuck an even 60 degrees rotate the chuck 12 teeth and replace the pin that will be every 60 degrees
hope this helps
MechWarriors 573
pic: A Perfect Circle? IMac Extra Discussion 5 14-02-2006 20:48
hole annotation problem in Inventor Nuson Inventor 0 29-03-2004 22:22
Bolt Action GateRunner Chit-Chat 1 15-04-2003 11:36
Goal Bolt Lengths archiver 2001 3 23-06-2002 23:14
bolt hole locations--Bosch and FP ajlapp Technical Discussion 6 28-10-2001 12:14
