Go to Post We are in the business of teaching our students. One of those things should be respect for the rules... - Tuba4 [more]
Unread 26-05-2006, 20:15
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Bolt hole circle without a mill
What is the most accurate and repeatable way to make a bolt hole circle on a round part without the use of a mill? I do have a lathe which I could possibly use to scribe a cicle, but I still need 6 holes evenly spaced around the circle.
Unread 26-05-2006, 20:38
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Bolt hole circle without a mill
Could you possibly CAD a circle split into as many equal segments as you needed, and then print it on an overhead transparency, and then use this along with your scribed circle to place the holes?
2001-2004: Team 100
2006-Present: Team 254
Unread 26-05-2006, 20:58
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
Ahhh... fond memories of our early years of putting those bolt hole circles into sprockets that fit those skyway wheel hubs. The way we did it was to CAD a pattern of the bolt hole circle with center point marks for each hole and a center hole. Print out a 1:1 scale drawing, cut it out, glue it on the sprocket centered with the middle of the sprocket (hardest part), use a punch for the holes to be drilled lined up with the center points on the drawing, and drill away!!
On second thought if you use a lathe to scribe the hole circle and then an edge to scribe some lines that bisect the circle into the parts where you want holes, that may be just as easy.
Unread 26-05-2006, 21:16
TimCraig TimCraig is offline
AKA: Tim Craig
TimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to behold
Along with the methods mentioned above, if you have multiple parts to make with the same bolt pattern, invest some time making an accurate template. Then you can duplicate your pattern without as much setup hassle.
Unread 26-05-2006, 22:59
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
This is actually pretty easy to do, and does not require a CAD system, transferring drawings, or anything more difficult than some simple scribing skills. Remember, machinists were doing these types of operations long before CAD systems, DROs, CNC machines, or EDM systems were ever invented. So there is usually a simple way to do a lot of these operations in a straightforward manner. In this case, it actually takes longer to explain than it takes to perform.
Mount a three-jaw chuck in the lathe (if you have a six-jaw chuck it would be even better, and make this whole operation trivial). Place a sharpened tool or scriber in the tool post, and adjust its height very precisely so that the cutting edge is on the centerline of the lathe. Make a short spacer that will fit in between the ways and the jaws of the chuck, so that when the chuck is rotated by hand it will stop the rotation by blocking passage of the jaw.
Coat the face of the part with marking fluid, and mount it in the chuck. BY HAND (not under power!) rotate the chuck so that one of the jaws is up against the spacer. Move the cutting tool in so that it just touches the face of the part. Run the cross-slide across, so that the tool scribes the part. You should now have a horizontal line across the face of the part that runs precisely through the center of rotation. Back out the cross-slide.
Move the spacer out of the way and BY HAND rotate the chuck 1/3 rotation. Put the spacer back in place and run the chuck jaw up against it. As long as there is no side-play in the chuck jaws, this will index the chuck precisely 120 degrees. Move the cutting tool back in, and run the cross-slide across to scribe a second line. Back the tool out, and repeat the whole operation a third time. You should now how three lines that intersect in the exact center of the part, and extend across the face of the part. The lines define six equally spaced radial segments.
Mount a sharp scribing tool in the tool post. Align the point of the scriber with the center of rotation of the part (where the radial lines intersect). Back the cross-slide out the desired radius of the bolt circle you want. Move the scriber in until it contacts the part, and then BY HAND (not under power!) rotate the chuck. This will scribe a circle that is concentric with the center of rotation of the part, and that intersects with the six radial lines. The intersections of the lines and the scribed circle will define the locations of the bolt holes.
When you are finished, take the spacer you made and store it away somewhere safe that you will remember. You will be using it again...
-dave
Unread 26-05-2006, 23:03
Bill_Hancoc's Avatar
Bill_Hancoc Bill_Hancoc is offline
Volkswagen Enthusiast
AKA: Bill Hancock
FRC #0573 (MechWarriors)
Bill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud of
Send a message via AIM to Bill_Hancoc
dave beat me to it by 4 minutes
you should be able to scribe a circle on the part you want the holes on and then figure out where you want the holes...in this case ill use a 6 hole evely spaced bolt circle. First start by scribing the diameter you want the holes at. Find the degree of each hole 360degrees/6holes= 60degrees spacing. on the lathe mark a line then turn the chuck 60 degrees arny direction and mark you next 5 lines in this manner. to get the exact degree you need a backgear with 72 teeth which allows you to remove the pin and advance 1 tooth to rotate the chuck 5 degrees. to rotate the chuck an even 60 degrees rotate the chuck 12 teeth and replace the pin that will be every 60 degrees
hope this helps
MechWarriors 573
Unread 26-05-2006, 23:25
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
Originally Posted by dlavery
This is actually pretty easy to do, and does not require a CAD system, transferring drawings, or anything more difficult than some simple scribing skills. ... -dave
Pure old school genius!
Unread 30-05-2006, 18:40
SgtMillhouse648's Avatar
SgtMillhouse648 SgtMillhouse648 is offline
AKA: Malhon Godwin
FRC #0648 (QC Elite)
SgtMillhouse648 has a spectacular aura aboutSgtMillhouse648 has a spectacular aura about
Send a message via MSN to SgtMillhouse648
you all are making this more difficult than it needs to be. all you need is a compass. scribe a circle centered on the part the dia of the pattern. then DO NOT CHANGE THE COMPASS IN ANY WAY. place the anchor point of the compass on the circle you just scribed. make an arc through the circle. then move the anchor point on the compass to the intersection point, and repeat the process. do this all the way around the circle. wahlah you now have 6 points equispaced around the circle. centerpunch the points where the circle and arcs meet, and drill
Unread 30-05-2006, 19:12
There was the word "accurate" in there.
Most compasses I've seen don't come close to even acceptable quality and you still have the problem of finding the center.
Unread 30-05-2006, 21:10
Andrew Blair's Avatar
FRC #0306 (CRT)
A decent compass is as accurate as the person using it. My hand happens to be a bit shakey evidently.
-Sir Francis Bacon
-Albert Einstein
Unread 30-05-2006, 21:37
AKA: Bill Hancock
but still not quite the level of accuracy achieved by using (what i assume is) a quility lathe
MechWarriors 573
Unread 01-06-2006, 14:02
Dick Linn's Avatar
no team (Synergy)
Dividers can be very accurate IF you can find the center and mark the bolt circle accurately. It's a matter of developing layout skills.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 01-06-2006, 14:57
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
What about on of those compases that have the thread shaft throught the middle and screw pen and closed.....That is if you know what I am talking about.....
pic: A Perfect Circle? IMac Extra Discussion 5 14-02-2006 20:48
hole annotation problem in Inventor Nuson Inventor 0 29-03-2004 22:22
Bolt Action GateRunner Chit-Chat 1 15-04-2003 11:36
Goal Bolt Lengths archiver 2001 3 23-06-2002 23:14
bolt hole locations--Bosch and FP ajlapp Technical Discussion 6 28-10-2001 12:14
