Go to Post After all, professional engineers know The Right Way To Do It (TM) and if we knew that we'd be deprived of the educational experience of screwing up. - phrontist [more]
Unread 28-05-2006, 13:45
Joe_Widen's Avatar
Joe_Widen Joe_Widen is offline
FRC #1675 (The Ultimate Protection Squad)
Joe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud of
Tank Tread Wheel
I was wondering if it would be possible to make a wheel by using a closed loop of tank tread (preferibly double-sided and say 32 teeth) on a pulley (32 teeth)? It would work the same way as a normal wheel. Now heres the question, how well would that work in a crab drive set up with the projected speed being 8.75 fps, using a 4 module configuration and one small cim on each module?
Finally in college =]
2009 Midwest Regional Champions - Thanks 111 and 1625
Unread 28-05-2006, 13:49
MikeJ675's Avatar
MikeJ675 MikeJ675 is offline
Near Chaos Robotics
AKA: Mike Jeffries
no team (Near Chaos Robotics)
MikeJ675 is a name known to allMikeJ675 is a name known to allMikeJ675 is a name known to allMikeJ675 is a name known to allMikeJ675 is a name known to allMikeJ675 is a name known to all
Send a message via AIM to MikeJ675
Re: Tank Tread Wheel
I don't think there will be any particular problems. Depending on the track design, it may be a bit bouncy between plates of the track.(if there are any)
Beyond that, it looks like it's mostly a somewhat more complicated way of making a wheel.
Team 675-Alumni
Near Chaos Robotics
Unread 28-05-2006, 14:04
Joe_Widen's Avatar
Actually it seems less complicated because you dont have to worry about riveting tread to wheels, instead of just sliding on the tread adn being done. Also, our IFI wheels began to lose tread and rivets got loose, so this is a quick and cheap way to switch tread. I'm not sure how well it would work but from a matinence stand point, it seems better then normal, treaded wheels.
Unread 28-05-2006, 14:32
We did something similar for our prototype shooter and as a backup to our current tank tread design. It worked fine.
The only problem I see you having is the tread sliding off the side. In the better tread/hub designs, there is a strip of rubber in the middle of the tread run as a guide. This guide keeps the tread on the hub and prevents it from sliding off when experiencing side loads.
So, for all of the extra engineering and cash this will take (treads/hubs are EXPENSIVE!) you would be much better off with modular "regular" treaded wheel design, where the wheels can be popped off and replaced very fast.
Unread 28-05-2006, 15:32
Bill_Hancoc's Avatar
Bill_Hancoc Bill_Hancoc is offline
Volkswagen Enthusiast
AKA: Bill Hancock
FRC #0573 (MechWarriors)
Bill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud of
Send a message via AIM to Bill_Hancoc
I had an idea like exactly like this a few months back and i scraped it because it would be really slow but if your max target speed is only ~9 fps it sould work fine.
good luck and i would like to see it if you get it done.
MechWarriors 573
Unread 28-05-2006, 20:15
MikeJ675's Avatar
Near Chaos Robotics
AKA: Mike Jeffries
with the idea here, there are two possibilities, custom tracks/wheels, or all stock components. The latter, much harder to find.
If you want simple to change, there's a whole different route to take. You've got a two piece hub that mounts to a specific shaft size, then interchangable wheels(built to fit the hub) that are in multiple diameters, so in a matter of a minute or so, you can switch tread and wheel diameter if you chose to.
Team 675-Alumni
Near Chaos Robotics
Unread 28-05-2006, 21:35
Not2B's Avatar
Not2B Not2B is offline
AKA: Brian Graham
When you poke holes in the tread material, don't poke them as large as the rivet hole if you have having trouble. That should help out some.
Otherwise - I would think that rivets are alot easier to deal with than tank treads. Of course, I think that rivets are a wonder drug for robots. All hail the rivet gun!!
Brian Graham
Unread 29-05-2006, 10:34
Mr.G Mr.G is offline
AKA: Kevin
FRC #0326 (Xtreme Eagles / Romulus High School / General Motors)
Mr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond repute
Send a message via AIM to Mr.G
We have used Loctite 380 Black Max Adhesive for 6 years on 6 inch wide tires and haven't had a problem.
Unread 29-05-2006, 23:28
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
The IFI wheels have a bit of a problem with the tread riveting it seems (I've heard a few teams complain about treads coming off during matches). I don't think the solution is developing a more expensive pulley/tread combo though. The KoP skyway wheels typically don't have a problem with treads coming off for instance (although they are also lower traction). Perhaps use an adhesive along with rivets (or instead of rivets), or use the AM traction wheels.
Tank Tread Stair Climber 114gopher Technical Discussion 9 12-12-2005 21:41
Tank Tread suppliers? Rombus Technical Discussion 2 22-02-2005 11:01
HELP us get rid of this wheel tread! sanddrag General Forum 3 23-01-2005 01:42
Semi-Tank Tread/Half Tank Treads thoughtful Technical Discussion 4 11-01-2005 08:33
Major problems with tank tread drive Lord Nerdlinger Technical Discussion 13 23-02-2004 21:15
