Go to Post A good teacher always needs to be a good student - Redhead Jokes [more]
Unread 28-05-2006, 03:59
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Getting Windows XP off of domains
I recently saved a computer from the trash dumpster. Remarkably it still worked and had XP Pro installed on the hard drive. Here's the only problem. It is set up on domains. So, instead of the normal XP login screen where you select the user, you get a screen telling you to press Ctrl-Alt-Delete and once you do you get network domain login (like this).
I have managed to reset the admin password but only for local login, so that does me no good until I can log in like usual.
So, can someone please help me out to remove the domain login? I know there's got to be a way to do it, whether it be through some sort of Linux LiveCD or command prompt or whatever. I've searched quite a bit and tried a few things but with no luck.
Please help me make this trash into treasure. Thanks.
Unread 28-05-2006, 10:22
Kyle Fenton Kyle Fenton is offline
GET IT ON!!
FRC #0121 (Rhode Warrior)
Kyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud of
Send a message via AIM to Kyle Fenton
Re: Getting Windows XP off of domains
You can try this but I don't know if it works
go to control panels-> system and go to computer identification-> then click workgroup instead of domain
then
go to users and groups, and there should be an option somewhere to get you back to the regular login
Rhode Warriors
NAVSEA/Raytheon/URI/Middletown, Portsmouth, Tiverton, Mt. Hope HS
Quality Robots Since 1996
Unread 28-05-2006, 13:56
fimmel's Avatar
fimmel fimmel is offline
Founding Mentor, Team 2370
AKA: Forest Immel
FRC #2370 (iBots 2370)
fimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond repute
i thought window had a log onto local workstation oly check box in the mor options on the login. maby not but u might try that
/forest
Unread 28-05-2006, 14:12
Michelle Celio's Avatar
Michelle Celio Michelle Celio is offline
dream. belive. accomplish.
Michelle Celio has a reputation beyond reputeMichelle Celio has a reputation beyond reputeMichelle Celio has a reputation beyond reputeMichelle Celio has a reputation beyond reputeMichelle Celio has a reputation beyond reputeMichelle Celio has a reputation beyond reputeMichelle Celio has a reputation beyond reputeMichelle Celio has a reputation beyond reputeMichelle Celio has a reputation beyond reputeMichelle Celio has a reputation beyond reputeMichelle Celio has a reputation beyond repute
Instead of logging on to the domain, in the drop down box there should be something along the lines of "this machine" or "local" something similar as to the way the pc is set up. Drop me an IM and I can help you better since it varies from PC to PC.
Ah who am I kidding.. Fdisk format re-install do dah do dah! (Sung to Camptown Races)
If you can get it to log in, right click my computer properties, computer name and then change and just join the workgroup (machines normally come in the work group WORKGROUP)
UCF History & Education '12
Sometimes you just need to step away
"They were shown as everything is shown, for, like the lens of a camera, history is a force that does not discriminate."
JRW <3
Volunteering: IRI - Reset 07/08, Mission Mayhem 07 - Referee
TnT - Referee 07/08, FLL Florida State Tournament - Judge 08/09
Florida Regional 08 - Reset/Repair, Florida Regional 09/10 - Photographer
8 Events - Web Evaluator 08/09/10
Unread 28-05-2006, 14:29
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Chances are there's all kinds of residual left over, you might really want to just torch the OS and reinstall if you have that option
Matt Krass
Unread 28-05-2006, 15:13
There is a "this computer" option but I still can't log in. I don't want to resinstall the OS. I'd like to keep it. Any help?
Unread 28-05-2006, 15:14
Adam Richards's Avatar
Adam Richards Adam Richards is offline
I'm baaaaaaack.
FRC #1902 (Exploding Bacon)
Adam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond repute
Send a message via AIM to Adam Richards
You really should reinstall the OS if it was someone else's computer. Their files could be confidential, and viewing them would be breaking the law.
Unread 28-05-2006, 15:15
If you wipped the password, then you should be able to log in...
Boot into safe mode, see what happens there you might be able to over ride the password and change it.
JRW <3
Unread 28-05-2006, 15:43
Timothy D. Ginn's Avatar
Timothy D. Ginn Timothy D. Ginn is offline
I check here maybe once a year.
Timothy D. Ginn is a name known to allTimothy D. Ginn is a name known to allTimothy D. Ginn is a name known to allTimothy D. Ginn is a name known to allTimothy D. Ginn is a name known to allTimothy D. Ginn is a name known to all
Send a message via ICQ to Timothy D. Ginn Send a message via AIM to Timothy D. Ginn Send a message via MSN to Timothy D. Ginn Send a message via Yahoo to Timothy D. Ginn
If all else fails you may be able to use system restore to roll back to a version of the configuration files before it joined the domain. (Off hand I'm not exactly sure how to do this since it's been a long while since I've used a Windows computer for much of anything at this point).
Alumni of FRC Team 1006
Former mentor of Full Lego Alchemist (FLL 5621) - Sempar School / Computing Students' Association of Queen's University
Unread 28-05-2006, 17:48
SamC SamC is offline
AKA: Sam Couch
FRC #0103 (Cybersonics)
SamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond repute
Sice he found it in a dumpster i'm pretty sure thier are no confidential files on that computer.
Unread 28-05-2006, 18:05
I was able to blank the admin password from a linux boot cd, then I was able to login in safe mode as admin, then take the computer off the domain, and now all is well. I'm actually posting from it right now. This was quite a dumpster find really, it has Dreamweaver and Office as well.
But now I have another question. My motherboard is carrying dual Pentium 3 500MHz processors. In My Computer "Properties" tab it only shows one. I have a feeling this is just due to Windows's stupidity but I'd like to be sure both are being recognized. Is there any diagnostic or hardware specs program I can run that will verify that both processors are working and being recognized. Is there any setup I need to do in XP to make sure that it is utilizing both processors?
I tried checking in the BIOS but the only thing it will tell me is the current temperature of each processor.
Unread 28-05-2006, 18:13
I know there is something you have to do in windows. I'm currently looking threw my course work for an answer. I will edit this post once I figure out where it is..
A hour later...
Symmentric Multiprocessing
I'm still trying to figure out how to implent it. A week out of school (not even) and I allready forgot how to do it. I will keep looking.
JRW <3
Unread 28-05-2006, 18:32
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
Is it XP Home? I was under the impression that only XP Pro is able to use dual processor.
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
Unread 28-05-2006, 18:35
no, it is XP pro
Unread 28-05-2006, 19:20
BrianBSL BrianBSL is offline
FRC #0190
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
I was able to blank the admin password from a linux boot cd, then I was able to login in safe mode on "this computer" as admin, then take the computer off the domain, and now all is well. I'm actually posting from it right now. This was quite a dumpster find really, it has Dreamweaver and Office as well.
If you don't have the paper license for Office and Dreamweaver, they are not legal to use. Chances are pretty high that whoever threw the PC away is planning on reusing those licenses on their new computer and did not intend to transfer the license to you. Even using their XP license is somewhat on the sketchy side, especially if it is not the OEM license that came with the computer. Since it was joined to a domain, I would guess it is some company's VLK, which would certinally not transfer to you.
If you open up task manager, go to performance. If you only see one processor there, then windows isn't seeing the 2nd one. Since it is XP Pro, there should be nothing you have to do to tell it that there are two processors, chances are its a BIOS config problem.
My posts represent my personal views only, and do not represent the views of either my team, Team 190, nor its primary sponsor, Worcester Polytechnic Institute.
Windows vista!!! [527]phil General Forum 27 25-07-2005 17:01
Getting off CMT pulleys Adam Y. Technical Discussion 4 30-01-2004 07:08
hanging off off other robots that are hanging off the horiz bar Andrew Dahl Rules/Strategy 15 12-01-2004 19:14
Windows ME robot180 Chit-Chat 11 07-07-2003 00:21
Threads getting off topic Mike Soukup CD Forum Support 29 20-08-2001 04:08
