#16
Re: Coefficients of Friction
Our team hopes to do a traction test over this summer with varying materials. We'll post the results we get on here. Alot of what we test depends on the price of it and how difficult it is to attain, but these are some of the things I have in mind right now...
Standard Skyway Wheels (both 6" and 8" to settle the debate once and for all on whether bigger diameter wheels get better traction) Pneumatic Skyway Wheels Roughtop Tread Wedgetop Tread Linatrile Tread from Brecoflex Correx Gum Tread from Brecoflex Nitrile Tread from Brecoflex Gum Rubber Tread on Bottom of a Shoe Anti-Slip Matting Go-Kart or Mini-Bike Pneumatic Wheels Colson Wheels Some of these things we already have lying around, the others we'll have to figure out. Any other suggestions are welcome, and it can be ANYTHING (if you didn't gather that from the fact that we're going to test a shoe). |
#17
Our team went through this a couple years ago when we were picking wheel types.
While it's true that the coefficient of friction between two surfaces is based on what the materials are made from, there is still a macroscopic relationship that must be accounted for. There are tables of friction coefficients you can use as a start, but we have seen that things such as knobby tires of the same rubber compound will grip the carpet better. That's more because the knobs deform the carpet, so there is no longer a purely tangential force acting on the carpet; the tire has become something like a gear. But I think the big question is really what kind of forces to design for in your gearbox, and friction coefficients are only one part of it. You know what your maximum torque on the motor is, and you should have some idea what your desired top speed for the robot will be as well. Looking at those, you also want to figure where in the drive train the transmission will be; if the transmission will be stepping down the motor speed, and will go straight to the drive wheel, then it will have to handle the full torque you expect the wheels to see. However if the 'box will step down to a mid-level, then you're using chains and sprockets to step down the speed more, your max torque will not be as much at the gearbox. Remember also that the ultimate thing your transmitting from the motor to the wheel is power, which is RPM*Torque. Raise one, and you lower the other. But I wouldn't design for max torque, and add a little, I would design for max torque, and multiply by 5 or 10. I don't know how many regionals your team will attend, or if you'll be at nationals, but add up all the matches you'll be in, plus practice matches, and practice time at home before it ships. Our team lost out winning the Philly regional because our drill motor transmission died in the finals. Very frustrating. But that was probably the robots 20th match, so it had a few miles on it. I can't stress (no pun intended) that enough. Hope this helps. Ted |
#18
We've used the 8 inch (nominal) Skyway pneumatic wheels for a couple of years. The ones that are available with the 5/8 inch bore and keyway. They are a bit taller than 8 inches. We generally end up with more traction than we really need, at least on carpet. I'd prefer 6 inchers, but these are easy to work with and fairly inexpensive. They do tend to bounce around, though. We were using 4 CIMs and the kit gearboxes with about a 1:2 further reduction to the wheels.
#19
The coefficient of friction can theoretically reach infinity (think Spiderman). The coefficient of friction can be calculated by taking your floor material and putting it on a ramp. Be able to change the angle of the ramp with respect to the floor. Place your item that you want to test on the ramp. Change the angle until the item starts to slip. Measure the angle. The coefficient of friction equals tan(angle). As you can see, any angle that can get higher than 45 degrees with have a coefficient of friction higher than 1.
| realistic friction constants. | Rickertsen2 | Motors | 11 | 18-10-2005 00:25 |
| Thermal Expansion Coefficients | FIRST JerseyKid | Technical Discussion | 2 | 05-04-2005 06:51 |
| Coefficient of friction of tetra | suneel112 | Kit & Additional Hardware | 1 | 12-02-2005 15:40 |
| more on friction | maxgebhardt | Technical Discussion | 0 | 15-01-2003 19:23 |
