Go to Post Most of our old robots have been scrapped for parts. Our Chairman submissions are still read every year by the whole team. - N7UJJ [more]
Unread 29-05-2006, 21:27
alysume alysume is offline
FRC #0192
alysume is an unknown quantity at this point
Hex vs. Key
Our team is planning our drivetrain for next year, and we are considering using hex shafts instead of a key, as we have done in previous years. What are the pros and cons of each? I've heard that a hex broach costs quite a bit of money, but that's about all I've heard. Also, how do hex shafts work with e-clips?
A couple more hex related questions:
-When we buy say 3/8" hex stock, is 3/8" the diameter of the incircle or the circumcircle?
-If we buy 3/8" hex stock, I'm assuming we would use a 3/8" hex broach? Would we drill a 3/8" hole, then broach it, or drill some smaller hole?
-We only have a manual lathe. If we wanted to turn down the ends of the hex shaft so that they fit into bearings, is the interrupted cut hard to deal with?
Thanks a lot!
Unread 29-05-2006, 21:43
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Hex vs. Key
Hex is measured flat to flat, not point to point. So, it is the same measurment as the inside circle. Before broaching a 3/8" hex, drill and ream a hole to 3/8". Most broaches are usually .0005-.001 oversize so 3/8" hex stock will be a slip fit into a 3/8" hex broached hole. A hex can easily be held in a 3 jaw chuck or in a hex collet. The "interrupted cut" is usually never a problem when turning it down on a lathe. Just don't take too heavy of a cut at once.
Unread 29-05-2006, 21:46
REVving up for a new season
FRC #2848 (All-sparks)
Re: Hex vs. Key
When we buy say 3/8" hex stock, is 3/8" the diameter of the in circle or the circumcircle?
3/8 is the distance from flat to flat of the hex
yes.
depending on what broach you get there will be a specified pilot hole most will be the broach size rating, but check the broach you plan to buy. mcmaster part# 2875A19 does use a 3/8 pilot
interrupted cuts aren't that bad, as long as you use a good cutter and the correct speed. The trick is just go slow, making small passes. This also depends on your material, if you are doing alum or steal.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 29-05-2006, 21:59
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
Re: Hex vs. Key
Thanks a lot!
There's a lot of relevant discussion (including alternatives to buying a hex broach set) in this thread:
Chief Delphi Forums - Hex Broach Options Consensus is: buy the hex broaches, they're easy to use and are very reliable.
Here's a page from McMaster-Carr for broaches:
McMaster-Broaches
A 3/8" broach uses a 3/8" drill and creates a hex hole with the inscribed circle 0.376" across. A 3/8" shaft should fit snugly in this hole.
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
Unread 29-05-2006, 22:14
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
Re: Hex vs. Key
We have always used keys due to the simplicity and cost.
Most sprockets are keyed so why not use them.
Proud to say our TigerDrive transmissions are hexless and keyless...
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 29-05-2006, 22:17
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Hex vs. Key
A manual lathe is perhaps preferable to a CNC one, since you can judge the cut and chatter, backing off as necessary. Take a light cut, and cut the shaft speed down about 30% from normal. It's possible to break the tool, so have spares on hand, and take a lighter cut.
The key is an even feed rate sideways, so if you have a screw-cutting lathe, use the finest feed rate (usually about 0.001" available.
An alternative is to grind away some of the points first, just don't overdo it.
Don
Unread 29-05-2006, 22:48
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Hex vs. Key
Without a doubt, if you can afford the hex broach, or find a shop willing to do it for you, use hex shafts wherever possible. It's so much easier than using keys--nothing to lose, and unlike keys, the hex won't slip.
2001-2004: Team 100
2006-Present: Team 254
Unread 29-05-2006, 23:32
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
Re: Hex vs. Key
The key will stay in place if it is brazed to the shaft, which immobilizes it (adhesives might work). You can also cut a light groove around the shaft for a retaining clip or e-clip.
Most gears and sprockets with finished bores have a standard keyway cut into the instead of square or hex shafts, when purchased from sources such as McMasterCarr and Grainger. One reason why keys are so common.
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Unread 29-05-2006, 23:35
Re: Hex vs. Key
There is also the option of woodruff keys which are stronger and will not slide out, but I will admit, hex is nice.
The only thing that is kind of annoying about hex is when you go from round shaft down to a smaller hex. Then you have to mill it with an indexing head (or 4th axis in the case of CNC).
Unread 30-05-2006, 22:01
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Hex vs. Key
Nor will it weaken the shaft.
The keyway in a shaft is a stress concentrator, which significantly reduces the strength of the shaft, especially its resistance to breaking under shock loads. Keyways are popular 'cause they're easy, and using a 5/8" shaft where a 3/8" will do isn't an issue if weight is not a consideration.
Einstein says the limit is ~286000 miles per second
Dean says the limit is 120 lbs.
Don
Unread 30-05-2006, 23:03
FRC #0701 (RoboVikes)
Re: Hex vs. Key
isn't the speed of light closer to 186,000 miles per second...
but regardless.... I think key does pose alot more problems... i think hex shaft would significantly reduce maintainance and wear issues... we have lots of problems with keys walking out, shafts getting worn
if you have the tools i would think hex is the way to go
i wouldn't know but i do know that key kinda sucks
Team 701
Unread 31-05-2006, 09:31
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Re: Hex vs. Key
Wikipedia sez: According to the currently prevailing definition, adopted in 1983, the speed of light <in vacuum> is exactly 299,792,458 metres per second. Since 1 mile = ~1.609344 kilometers, the speed of light is about 186,282.4 miles per second, or in more convenient units about 0.983571 feet per nanosecond. [digression] This gives an upper bound for the speed at which information can be transported using electromagnetism; e.g., lightguide. Actual transmission speed in fiber optic cable is about 30% slower than this, because the fiber has greater electrical permittivity than free space. [/digression]
Short FIRST-friendly summary: remember, Aluminum weighs about one-tenth of a pound per cubic inch, and light travels about one foot per nanosecond. The second approximation has almost no practical significance for FRC robot building. So back to the main topic now:
We've been using keys for several years. I'll be ordering a 3/8" hex broach soon. Summer is the time to practice new tricks.
Richard Wallace
since 2003
Unread 31-05-2006, 22:37
Gabe's Avatar
Re: Hex vs. Key
Machanically speaking, a spline shaft is the best, but that is really hard to get and it is really hard to broach matching splines without laying out some money.
Hex Broach Options? Andrew Blair Technical Discussion 31 25-08-2006 21:12
Hex Couplers Chris 481 Technical Discussion 9 03-04-2006 20:49
Hex file downloads Ryan M. Control System 2 29-10-2005 19:50
HEX CRAWLER... Arefin Bari Chit-Chat 3 01-05-2004 00:12
Hex key sizes archiver 2001 3 24-06-2002 01:21
