Go to Post Needless to say, lots of smoke came out, and I debated using its terrible smell as a deterrent. - Snapshot [more]
Unread 29-05-2006, 21:46
REVving up for a new season
FRC #2848 (All-sparks)
Re: Hex vs. Key
When we buy say 3/8" hex stock, is 3/8" the diameter of the in circle or the circumcircle?
3/8 is the distance from flat to flat of the hex
-If we buy 3/8" hex stock, I'm assuming we would use a 3/8" hex broach?
yes.
Would we drill a 3/8" hole, then broach it, or drill some smaller hole?
depending on what broach you get there will be a specified pilot hole most will be the broach size rating, but check the broach you plan to buy. mcmaster part# 2875A19 does use a 3/8 pilot
We only have a manual lathe. If we wanted to turn down the ends of the hex shaft so that they fit into bearings, is the interrupted cut hard to deal with
interrupted cuts aren't that bad, as long as you use a good cutter and the correct speed. The trick is just go slow, making small passes. This also depends on your material, if you are doing alum or steal.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Hex Broach Options? Andrew Blair Technical Discussion 31 25-08-2006 21:12
Hex Couplers Chris 481 Technical Discussion 9 03-04-2006 20:49
Hex file downloads Ryan M. Control System 2 29-10-2005 19:50
HEX CRAWLER... Arefin Bari Chit-Chat 3 01-05-2004 00:12
Hex key sizes archiver 2001 3 24-06-2002 01:21
