Go to Post FIRST doesn't end after your last year within a team. It's never going to end. - Tetraman [more]
Unread 29-05-2006, 13:21
Rob2713g's Avatar
Rob2713g Rob2713g is offline
FRC #0540 (Screaming Eagles)
Rob2713g has a spectacular aura aboutRob2713g has a spectacular aura aboutRob2713g has a spectacular aura about
Suction Device
Hey,
I was wondering if anyone had some good designs or links for information on suction devices. A team this year at the VCU Regional had an interesting suction device, but I can't recall what team number they were. This information would be very helpful for an off-season project.
Thanks in advance.
Unread 29-05-2006, 21:40
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
Re: Suction Device
I recall a very effective suction device used by the Bomb Squad (Team 16) in "Stack Attack (2003)". I think they used a pair of pneumatic cylinders to create the vacuum for a suction cup on the underside of the robot. That device made them immovable on the plastic surface on top of the mid-field platform.
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
Unread 29-05-2006, 22:21
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Suction Device
A venturi tube is used to generate a decent vacuum from air pressure. These are available coimmercially. The downside is that they consume a lot of air in the process, the KOP compressor is not a high-volume device. Thius limits te amount of evacuated space available.
Don
Unread 29-05-2006, 22:51
Billfred's Avatar
Billfred Billfred is offline
Re: Suction Device
I recall seeing on 1398's 2004 robot a hacked-up Shark vacuum cleaner, which I assume was powered by a Fisher-Price motor for its ridiculous speed, to grab the 2X ball from the mobile goal. The stock vacuum hose was used and connected to a sort of bowl device, which had a nice and wide contact with the ball itself. I'll try and find out some more information about it.
Unread 30-05-2006, 09:43
Re: Suction Device
best way to go is to get a vacuum pump and adapt one of the motors in the KOP to drive it.
Vacuum pumps are very common on industrial equipment, from little ones that look like model airplane engines to big multi HP units that can pull a vacuum on a 500 gallon tank in a matter of seconds.
Unread 30-05-2006, 12:01
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
Re: Suction Device
Team 987 made a suction plate for the 03 event with 2 3/4" bore pistons that produced over a 1000 lbs of negative pressure and was awarded the Xerox Creativity Award (I believe at the SoCal Regional)...very effective.
Unread 30-05-2006, 13:08
AKA: Joe Barry
Re: Suction Device
Oops...Team 987's suction device's Xerox Award was for Arizona Regional...
Unread 30-05-2006, 13:57
Re: Suction Device
OK, you got some splaining to do. Air pressure at sea level is 15 lbs / sq"
a perfect vacuum is 0 lbs / sq"
what exactly is negative pressure ?!
Unread 30-05-2006, 14:38
Re: Suction Device
If you use ambient pressure as a reference, you can measure down to -15 PSI.
To get 1000 pounds of negative pressure out of a total vacuum, you need more than 65 square inches of suction plate, as long as the other side of the plate is open to the outside air. You can do it with a square foot using only a 7 PSI vacuum source.
Unread 30-05-2006, 15:00
Re: Suction Device
ok, I guess its the units that threw me off
pressure is measured in lbs/sq".
So he was saying 1000 lbs of negative force then? That makes sense.
Unread 30-05-2006, 17:05
Mr.G Mr.G is offline
AKA: Kevin
FRC #0326 (Xtreme Eagles / Romulus High School / General Motors)
Mr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond repute
Send a message via AIM to Mr.G
Re: Suction Device
We used this venturi pump in 2004 to pick up the 2x ball with 6 inch suction cup. It is a very small unit about as big as a lighter. You had to pull hard to get it off. We actually added a blow off because it would take ~5 seconds for the suction to stop on its own. The compressor kept up with it easily, and we never used the extra storage tanks that come in the kit.
http://www.piab.com/Templates/WebBas....aspx?id=10209
Unread 30-05-2006, 22:37
Re: Suction Device
Please be aware that the the rules for suction devices vary more year to year then just about any other rule in FIRST.
Unread 30-05-2006, 22:45
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
Re: Suction Device
That brings up an intresting entry in this year's game manual
Originally Posted by GDC
<R100> The following pneumatics items may be added to your robot:
• You may use the 2005 Kit pneumatic cylinders, solenoid valves, and pneumatic tubing in addition to
those items in the 2006 Kit, but you must account for their costs as explained in the Cost Limits and
Accounting section.
• You may use a pressure transducer as long as it is rated to the operating air pressure at its mounting point
in the pneumatic system.
• For the purposes of the FIRST competition, a device that creates a vacuum is not considered to be a
pneumatic device and is allowed. This includes, but is not limited to, Venturi-type vacuum generators and
off-the-shelf vacuum devices (as long as they are powered by one of the Kit-of-Parts motors).
• For the purposes of the FIRST competition, closed-loop pneumatic (gas) shocks are not considered
pneumatic devices, and are permitted additions to the robot.
SURVIVORfan44's Avatar
SURVIVORfan44 SURVIVORfan44 is offline
SURVIVORfan44 is on a distinguished road
Send a message via AIM to SURVIVORfan44
Re: Suction Device
539 was the team this year at VCU that had the suction cup.
In 2004, my team, 616, used suction cups to pick up the huge yellow doublar balls.
Unread 30-05-2006, 22:57
Billfred's Avatar
Re: Suction Device
It should also be noted that the current stance on suction devices has read about the same since I started in 2004. It's still a gamble, naturally, but not nearly as much of a gamble as, say, developing a flopbot.
Suction ????? ak_Knight Rules/Strategy 2 24-02-2004 01:57
Suction Cups Sachiel7 Technical Discussion 9 13-03-2003 22:41
Suction Cups / Alternative Traction MikeDubreuil General Forum 0 19-02-2003 02:41
Suction Cups: How? Kai Zhao Pneumatics 25 04-02-2003 19:02
Suction Cups Lauren Hafford General Forum 4 06-01-2003 00:01
