Go to Post I think we need to take away your hammer privileges. - Katy [more]
Unread 29-05-2006, 22:48
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Hex vs. Key
Without a doubt, if you can afford the hex broach, or find a shop willing to do it for you, use hex shafts wherever possible. It's so much easier than using keys--nothing to lose, and unlike keys, the hex won't slip.
2001-2004: Team 100
2006-Present: Team 254
Unread 29-05-2006, 23:32
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
Re: Hex vs. Key
The key will stay in place if it is brazed to the shaft, which immobilizes it (adhesives might work). You can also cut a light groove around the shaft for a retaining clip or e-clip.
Most gears and sprockets with finished bores have a standard keyway cut into the instead of square or hex shafts, when purchased from sources such as McMasterCarr and Grainger. One reason why keys are so common.
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Unread 29-05-2006, 23:35
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Hex vs. Key
There is also the option of woodruff keys which are stronger and will not slide out, but I will admit, hex is nice.
The only thing that is kind of annoying about hex is when you go from round shaft down to a smaller hex. Then you have to mill it with an indexing head (or 4th axis in the case of CNC).
Unread 30-05-2006, 22:01
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Hex vs. Key
Nor will it weaken the shaft.
The keyway in a shaft is a stress concentrator, which significantly reduces the strength of the shaft, especially its resistance to breaking under shock loads. Keyways are popular 'cause they're easy, and using a 5/8" shaft where a 3/8" will do isn't an issue if weight is not a consideration.
Einstein says the limit is ~286000 miles per second
Dean says the limit is 120 lbs.
Don
Unread 30-05-2006, 23:03
FRC #0701 (RoboVikes)
Re: Hex vs. Key
isn't the speed of light closer to 186,000 miles per second...
but regardless.... I think key does pose alot more problems... i think hex shaft would significantly reduce maintainance and wear issues... we have lots of problems with keys walking out, shafts getting worn
if you have the tools i would think hex is the way to go
i wouldn't know but i do know that key kinda sucks
Team 701
Unread 31-05-2006, 09:31
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Re: Hex vs. Key
Wikipedia sez: According to the currently prevailing definition, adopted in 1983, the speed of light <in vacuum> is exactly 299,792,458 metres per second. Since 1 mile = ~1.609344 kilometers, the speed of light is about 186,282.4 miles per second, or in more convenient units about 0.983571 feet per nanosecond. [digression] This gives an upper bound for the speed at which information can be transported using electromagnetism; e.g., lightguide. Actual transmission speed in fiber optic cable is about 30% slower than this, because the fiber has greater electrical permittivity than free space. [/digression]
Short FIRST-friendly summary: remember, Aluminum weighs about one-tenth of a pound per cubic inch, and light travels about one foot per nanosecond. The second approximation has almost no practical significance for FRC robot building. So back to the main topic now:
We've been using keys for several years. I'll be ordering a 3/8" hex broach soon. Summer is the time to practice new tricks.
Richard Wallace
since 2003
Unread 31-05-2006, 22:37
Gabe's Avatar
Re: Hex vs. Key
Machanically speaking, a spline shaft is the best, but that is really hard to get and it is really hard to broach matching splines without laying out some money.
Hex Broach Options? Andrew Blair Technical Discussion 31 25-08-2006 21:12
Hex Couplers Chris 481 Technical Discussion 9 03-04-2006 20:49
Hex file downloads Ryan M. Control System 2 29-10-2005 19:50
HEX CRAWLER... Arefin Bari Chit-Chat 3 01-05-2004 00:12
Hex key sizes archiver 2001 3 24-06-2002 01:21
