Go to Post If you have a robot you don't need any more, use it for demos, or let a rookie team borrow it to learn wiring, programming, and demo around their school. - Barry Bonzack [more]
Unread 31-05-2006, 08:45
tacman1123 tacman1123 is offline
AKA: Tac Tacelosky
FRC #1900
tacman1123 is an unknown quantity at this point
Send a message via AIM to tacman1123
Using printf() as UserCode in EasyC 2.0
I've add stdio.h to the Include files of my project, but printf("Test: %d", 1); (as a UserCode block) isn't writing to the terminal. What does PrintToScreen() do differently? PrintToScreen is limited to a single variable, and has a "\n" at the end, I'd like to have a bit more control (and just understand the communciation process better).
Do I need to include the printf_lib? If so, can someone explain the steps of integrating the VexCode libraries with the EasyC libraries?
TIA,
Tac
Unread 31-05-2006, 09:03
gabrielse's Avatar
gabrielse gabrielse is offline
FRC #1748 (Lab Rats)
gabrielse is a splendid one to beholdgabrielse is a splendid one to beholdgabrielse is a splendid one to beholdgabrielse is a splendid one to beholdgabrielse is a splendid one to beholdgabrielse is a splendid one to beholdgabrielse is a splendid one to behold
Re: Using printf() as UserCode in EasyC 2.0
TIA,
Tac
I've had good luck using PrintToScreen as user code when I need to print multiple variables on one line. Use PrintToScreen the same way you would use printf in a user code block, just make sure you typecast your variables. There is no need to include any libraries.
example (type this in as user code):
PrintToScreen("x = %d, y = %d\n", (int)x, (int)y);
Good luck.
Unread 31-05-2006, 10:01
AKA: Tac Tacelosky
FRC #1900
Thanks, that helps. I'd still like to know more about how to integrate low-level calls, but your solution solved my immediate problem, which was a simple script to monitor the radio transmitter values (since the Online mode doesn't display those). For those that are interested, here it is.
#include "Main.h"
void main ( void )
      int time = 0;
      int rx = 0;
      int channel = 1;
      int rx_value = 1;
      int i = 0;
      StartTimer ( 1 ) ;
      while ( 1 )
            time = GetTimer ( 1 ) ;
            for ( rx=1 ; rx<=2 ; rx++ ) // loop through rx
                  for ( channel=1 ; channel<=6 ; channel++ )
                        rx_value = GetRxInput ( rx , channel ) ;
                        PrintToScreen("%3d ", (int)rx_value);
            PrintToScreen ( "at %d\n" , (int)time ) ;
Now what would be nice is if the terminal window could be widened and the font could be changed to a fixed-width font, so that the results came out tabular instead of in a series of numbers.
Printf BillyJ Programming 9 21-01-2006 14:03
Kickoff easyC workshop integrated into EasyC help file Dan Larochelle Programming 0 11-01-2006 06:12
Why printf? Mike Programming 5 20-03-2005 15:54
printf isn't printf-ing. Help! Meandmyself Programming 14 15-02-2004 16:27
