Go to Post Blasphemy! This is FRC we must over analyze everything! - Ginger Power [more]
Unread 31-05-2006, 13:25
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
Re: VEX inputs
Originally Posted by Damien1247
I would post them but i have been unable to write the code so it registered the encoders. Also, you seemed to be using easyC and i am using MPLAB. Using the sensor test code provided by vexlabs i was unable to make the encoders work. I put his down to the fact that i was attempting to use a grayhill op encoder. I am currently lookin into purchasing a pair of encoders from vex.
Damien,
The algorithm should be fairly independent of the encoder used (especially for straight-line motion). I am still interested....
Blake
PS: Private email works for me, if you want to avoid a public posting of incomplete results.
Useful VEX Tools Joe Johnson FIRST Tech Challenge 4 26-04-2005 18:48
Vex Robotics Vex FIRST Tech Challenge 0 14-04-2005 13:48
VEX Robotics vexrobotics FIRST Tech Challenge 8 30-03-2005 23:25
VEX Kits ARRIVED!!! Joe Johnson FIRST Tech Challenge 14 28-03-2005 19:28
digital inputs not valid just after initialization? WizardOfAz Programming 2 26-01-2004 13:21
