Go to Post In my opinion, the right mix of student, mentor, and engineer involvement is when everyone gives it 100%. - Jack Jones [more]
Unread 01-06-2006, 15:44
Joe_Widen's Avatar
Joe_Widen Joe_Widen is offline
FRC #1675 (The Ultimate Protection Squad)
Joe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud of
Gear Types
Well, I was just looking at 968's robot. I was trying hard to keep my jaw off the floor and then I saw their gearboxes. Those are beautiful. I did notice that the gear on their CIM and the gear on the first reduction were different then what I'm used to. They gears were on like a 30* Ang to the gear. It was weird. Heres the link to the picture,
http://www.chiefdelphi.com/forums/sh...hlight=pic+968
Look at the third picture to see what I mean.
Now is there an advantage to doing that, or do they just do it because it looks cool?
Finally in college =]
2009 Midwest Regional Champions - Thanks 111 and 1625
Unread 01-06-2006, 15:52
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
Re: Gear Types
It's unlikely that its cut at 14.5*, 30* would more likely than not HAVE to be custom made, and a 20* pressure angle, commonly refered to as a Metric gear, is the only other reasonable alternative.
From what I've heard from people, though Metric gears are better for some purposes, I'm not sure if they are a step up in effiency though, and they aren't desirable because usually of a higher price, and a lesser availability, but at the size 968 looks to be using them, the price difference would be minimal I believe. However that depends on where you live (see Tristian's Response)
Unread 01-06-2006, 16:11
Joe_Widen's Avatar
Re: Gear Types
Well I figured it out. Its a helical gear and the reason they use them is because there is more surface area in contact allowing to transfer more torque. The down side is they are a very little less efficient.
Unread 01-06-2006, 16:16
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Gear Types
I'm not entirely sure what you're talking about. neither 254 nor 968 used anything other than plain old spur gears in our drivetrain.
There are two possibilities to what you're seeing.
1) It's an optical illusion
2) (the more likely reason) SDP sent us gearstock with messed up teeth. They were slanted in multiple directions. The shop that made the gears for us did everything concentric to the teeth of the gear, and as such, they wobble slightly. You're probably looking at the gear when it's in the part of it's rotation that throws it off center the most.
2001-2004: Team 100
2006-Present: Team 254
Unread 01-06-2006, 16:29
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: Gear Types
I've got to admit that I can't see what he's talking about in that picture...they look like spur gears to me. But, just to clarify this:
The pressure angle of 20° isn't limited to gears governed by Metric standards. Years ago, AGMA instituted Imperial standards dealing with 20° pressure angles, which were originally intended to replace the older 14.5° standards. But for various reasons (some performance-related, some logistics-related), the 14.5° gears never really died. So, to summarize: Metric gears are usually (but not always) 20° pressure angle, while Imperial gears are usually 14.5° or 20° pressure angle; note, though that the terms "Imperial" or "Metric" refer to the measurement system, and not to the actual dimensions, and that custom gears in either measurement system can have any pressure angle that satisfies the involute curve equations (though this is limited by practical considerations).
As noted above, this statement is not correct. In the U.S., Metric stock gears tend to be more expensive than Imperial stock gears, because there is relatively little demand. The reverse is true in Europe.
Also, note that helix angle (i.e. in a helical gear, it's non-zero) and pressure angle are distinct quantities.
Unread 01-06-2006, 16:48
Joe_Widen's Avatar
Re: Gear Types
I swear its a helical gear. It cant be anything else. I'll post a picture on CD media, because my computer wont let the attachment thing come up.
http://www.chiefdelphi.com/media/photos/25071
Unread 01-06-2006, 17:14
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: Gear Types
It's not a helical gear. You can see the same gearboxes in the photo above the one yours is taken from and it's obvious from that photo that they're using plain old spur gears, just like the rest of us. There's no special sauce or anything.
--Madison--
...down at the Ozdust!
Unread 01-06-2006, 17:18
Joe_Widen's Avatar
Re: Gear Types
Then why is the gear on the motor and the gear it meshes with have slanted teeth like that? I do agree that from the other angle it looks different. It just seems wierd.
Unread 01-06-2006, 17:28
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Re: Gear Types
Maybe the gear was moving when the picture was taken?
Digital cameras can do strange things when the target is moving.
Richard Wallace
since 2003
Unread 01-06-2006, 17:38
Ben Piecuch Ben Piecuch is offline
Bengineer
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
Re: Gear Types
I think the resolution of the picture is what is making the gears look odd. Once the gear tooth size is on the same order of magnitude as the image's pixel size, the image gets a bit distorted.
Now, helical gears obviously exist, and there are probably more than a few FIRST teams that have used them. However, team 968 is not one of them...
BEN
Unread 01-06-2006, 21:12
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
Re: Gear Types
This should help...
Spur gear it is.
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 01-06-2006, 22:11
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: Gear Types
Any chance the rest of us can see the designs on those transmissions?
And yup, definately a spur gear.
Unread 01-06-2006, 22:27
JoelP JoelP is offline
whats the P for? Pazhayampallil
FRC #1155 (Bronx Science Sciborgs)
JoelP is a jewel in the roughJoelP is a jewel in the roughJoelP is a jewel in the rough
Send a message via AIM to JoelP
Re: Gear Types
I read that you guys used 32 pitch gears. Why did you choose to use those over more common (as far as I know) 20 pitch gears? Advantages/Disadvantages?
The Sciborgs
2006 NYC Engineering Inspiration Award Winner
2007 NJ Regional Finalist
2007 NYC Regional Best Website Award
2007 NYC Regional Chairman's Award Winner
Unread 01-06-2006, 23:31
Joe_Widen's Avatar
Re: Gear Types
How do you guys get those gears to stay put with out keys or set screws? I know you used hex stock on the final stage. I'm mainly asking about the gear on the Fischer Price.
Unread 02-06-2006, 00:01
Engineering Mentor
FRC #0254
Re: Gear Types
Are you refering to the pinion or the driven gear? The pinion is mounted onto the CIM and AM planetary shafts using the supplied 2mm keyway with an internal spline retaining ring.
The driven gear is also a hex. The only other place we used a keyway within the gearbox was on the output shaft to retain the sprockets that go to the front and back wheels. There is no easy way to put a hex there, as much as I would have liked to.
As for 32 pitch vs 20 pitch, the 32 pitch at 3/8" face was far strong enough for the initial reduction off the motors and allowed for a more compact gearbox overall. The large 32 pitch gear is a 96 tooth, and the large 20 pitch dogged gear has 72 teeth. Both are relatively large, but allowed us to have only one intermediate shaft with no chain reduction.
-Travis Covington
Attachment Types russell CD Forum Support 6 24-02-2005 10:12
R/C Control types Andy Brockway Programming 43 24-11-2003 17:07
Types of Drives? indieFan Technical Discussion 50 20-10-2003 12:27
Button types Scottie2Hottie General Forum 7 27-03-2002 00:13
Music types Carolyn Duncan Chit-Chat 42 03-08-2001 23:06
