Go to Post Best. Team. Update. Ever. - Billfred [more]
Unread 01-06-2006, 17:21
Joe_Widen's Avatar
Joe_Widen Joe_Widen is offline
FRC #1675 (The Ultimate Protection Squad)
Joe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud of
pic: Helical Gears?
Finally in college =]
2009 Midwest Regional Champions - Thanks 111 and 1625
viking1902's Avatar
viking1902 viking1902 is offline
Team Viking/Head Mechanical
AKA: chuckie
FRC #1902 (EXPLODING BACON!!!)
viking1902 is a glorious beacon of lightviking1902 is a glorious beacon of lightviking1902 is a glorious beacon of lightviking1902 is a glorious beacon of lightviking1902 is a glorious beacon of lightviking1902 is a glorious beacon of light
Send a message via AIM to viking1902
Re: pic: Helical Gears?
from what i can see, yes it is.
edit: after reading the thread related to this picture, it looks like an optical illusion. weird.
Too much bacon for the pan to handle.
Unread 01-06-2006, 17:29
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Haha, I know that transmission anywhere (after spending hours with my face about two inches away from it. I hope all that drool didn't make the gears bind up too bad ). That is West Covina High School team 968's 2006 transmission. That is a 32 pitch standard spur gear. No helical gears anywhere on that bot. Must just be something funky going on with the picture.
Unread 01-06-2006, 21:07
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is online now
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
What he said^^^^
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 02-06-2006, 08:18
patrickrd's Avatar
patrickrd patrickrd is offline
AKA: Patrick Dingle
patrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to behold
Send a message via AIM to patrickrd
This picture is disturbing. How does it look like perfect continuous diagonal lines on both the pinion gear and the driven gear, and normal spur elsewhere? My best guess is that these are normal spurs with a little groove in the middle of each tooth... I have seen that before but I still can't see it looking like perfect diagonals in the picture.
If you look closely, you can also see that if we did assume they are helical gears, then the helix angles of the two gears would not mesh! One of the gears would need the angles reversed from what is shown.
Systems Engineer - Kiva Systems, Woburn MA
Alumni, Former Mechanical Team Leader - Cornell University Robocup - 1999, 2000, 2002, 2003 World Champions
Founder - Team 639 - Ithaca High School / Cornell University
Alumni - Team 190 - Mass Academy / WPI
Unread 02-06-2006, 10:56
It's an image artifact. The spacing of the gear teeth in the image is close to the size of the pixels, and the JPEG compression picks up on the diagonal aliasing and enhances it. Look at the bright area on the left end of the CIM motor and you'll see the same kind of illusion.
Unread 15-06-2006, 13:34
jackie Ha's Avatar
jackie Ha jackie Ha is offline
Team President and Captain 05'-07'
AKA: Jacqueline Ha
FRC #0968 (Robotics Alliance of West Covina aka RAWC)
jackie Ha is a splendid one to beholdjackie Ha is a splendid one to beholdjackie Ha is a splendid one to beholdjackie Ha is a splendid one to beholdjackie Ha is a splendid one to beholdjackie Ha is a splendid one to beholdjackie Ha is a splendid one to behold
Send a message via AIM to jackie Ha
Wink Re: pic: Helical Gears?
If you want a better picture, go to the thread above, Gear Types. My mentor Travis Covington posted a clearer picture of the gears for all to see.
Unread 15-06-2006, 13:45
it looks like the photo is a small part of a larger picture, and this section was enlarged with photoshop or some other editing program.
When you scale an image up the program has to make assumptions about what is between pixels. Sometimes you get aliasing, and patterns are created where there was no pattern in the original photo (in this case, diagonal lines).
Unread 15-06-2006, 14:59
Engineering Mentor
FRC #0254
Here is the other thread that has the pictures in it and further discussion as well.
http://www.chiefdelphi.com/forums/sh...&highlight=968
-Travis Covington
Helical Gears in Inventor 8 xxmaddjxx Inventor 4 26-06-2004 00:04
helical gears Max Lobovsky Technical Discussion 10 16-04-2004 22:48
Helical Gears Gear Ratio Joe P Technical Discussion 11 23-01-2003 22:55
helical gears efficency Andrew Dahl Technical Discussion 0 07-01-2003 13:02
