Go to Post Now there is something I am going to suggest to my team...."testing before ship (bag)"....on second thought, maybe I'll just ref! - ExTexan [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 01-06-2006, 13:25
tacman1123 tacman1123 is offline
AKA: Tac Tacelosky
FRC #1900
tacman1123 is an unknown quantity at this point
Send a message via AIM to tacman1123
Angle Sensor for Vex
I'm looking for a rotation sensor for the Vex, an angle sensor. I have the optical shaft encoder, but I see that it doesn't measure the direction that the shaft is rotating, so it's impossible to use it to calculate the angle.
The new Mindstorm NXT kit will have angle measurements (to 1%) built into their servo motors, something which I think will increase the precision of Mindstorm bots significantly.
I've also played around with the idea of using the optical shaft encoder and some other mechanism for seeing which direction an axle is turning, but can't come up with anything that immediately responds to a change in direction. An angle sensor is really what I'm looking for.
Thx,
Tac
Unread 01-06-2006, 19:54
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Re: Angle Sensor for Vex
I don't know how to do an angle sensor, but an idea I've had is to attach an intake roller to an axle, then position a limit switch so the metal end of it gets hit by the intake roller. Since the roller and metal are flexible, they can bend and let the roller spin. The roller spinning one way will trigger the limit switch, the other way it won't.
I haven't tested this of course, just an idea.
Unread 01-06-2006, 20:23
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Was it the VEX sensor or the KOP sensor that pulsed for a slightly different length of time one direction than the other?
The other option would be to get a quadrature encoder, which has two inputs that fire in one order for one direction, and the other for the other direction. It involves using interrupts to listen to which one goes first, but would solve your problem.
ericand's Avatar
ericand ericand is offline
AKA: Eric Anderson
FRC #3765 (Terrabots)
ericand is a jewel in the roughericand is a jewel in the roughericand is a jewel in the rough
If you don't need 360 degrees, a potentiomiter works well. We used one this year to measure the tilt of our robot's shooting mechanism. Of course you would need to do some calibration to match the voltage values with the angles that you want to find.
Unread 02-06-2006, 00:15
The Arizona Mentor
AKA: Andrew
I can't believe I completely forgot about potentiometers. Probably because they're not standard for Vex and I was assuming he was looking for Vex parts.
A potentiometer would be a very effective use for this, most of them can measure close to 300 degrees of rotation. Alot of them are single turn, some can be turned a few times (I've seen up to 10 turn ones), and there are a few rare continuous-rotation potentiometers that can handle infinite revolutions. They would only require one pwm cable soldered on to the POT and one analog input to hook it up to for each POT.
The KOP gear tooth sensors have different pulse lengths for different directions, Vex encoders are blind to direction. I should probably clarify my idea above was for sensing direction with a Vex encoder, since I failed to mention that in the post.
If you're trying to tilt something to a specific angle (rather than just measure somethings angle), you could just use the Vex servos as they can be set to specific positions. I'm not entirely sure what the conversion from PWM values to degrees is, but I'm sure it could be found.
Unread 02-06-2006, 00:29
If the motors are the sole thing controlling the motion of the robot, you can just look at the output signal to determine whether they are moving forward or backward.
0-126 Backward
127 Neutral
128-255 Forward
Unread 30-06-2006, 08:58
Noggin Noggin is offline
Noggin is an unknown quantity at this point
Can you give some detailed info on what size pot you used, and how you hooked it up?
Unread 30-06-2006, 11:06
RoboMadi's Avatar
RoboMadi RoboMadi is offline
3 Fs..... Fun Friends FIRST!!
AKA: Imad
FRC #0612
RoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant future
Well you can use couple, but it depends on how you use them. For example pot. are good but not that reliable, as they don't give you a precise reading (eg if you set Position A at 210, it might not remain the same and fluctuate).
I recommend using Infrared sensors, if you are mounting it on an angle and trying to find/set a certain distance.
Other than that, this might help you a bit.
Unread 30-06-2006, 11:29
The Arizona Mentor
AKA: Andrew
What kind of accuracy and range are you looking for this sensor?
If you want to experiment with potentiometers you can find them in random parts bins at electronics stores (radio shack has them in those racks of parts). They're usually like $5-$10. I'm not sure what type of resistance the POT would need to work with Vex.
Unread 30-06-2006, 14:54
Just wanted a wide enough range to determine when the arm was all the way down, all the way up, and an idea of where its at in the middle. I want to control an articulated arm to determine position upon bot startup and set both arms to their neutral positions, then use the sensors to detect extension and make sure the upper arm is limited while the lower arm is in its neutral position, and make sure the lower arm cannot close if the upper arm is beyond a certain point. I was thinking of using the pots connected to chain drives to do gear reduction to get a analog input for the entire range of motion along both arms.
Unread 30-06-2006, 18:12
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
IF you make the right kinda of endcoder, OR find one somewhere, just by looking at how the encoder beam is broken you can tell which direction the wheel is spinning.
For example if you have 2hall effects next to each other on a sprocket
and a tooth hits the left on before hitting th right one then it is traveling one direction, and the inverse is also true for the other direction.
Unread 02-07-2006, 10:02
UPDATE*** I used 2 50k pots (1 for each arm) and linked them directly to the pivot axle of the arm to get my readings. I know get analog values from 0 to 86 or so that I can use to determine if I am close to the arms limit for range of motion. Wiring was easy as I took a pwm extension cable and cut off the female end to solder it to the pot (center & either outer tap on pot, signal & ground on controller end). To mount it to the shaft I had to cut off some of the length (RS's pots are like 3-4 inches) and then I used a dremel to hollow out the shaft so it would fit over an axle. Origionally, I had drilled another hole in the side of the shaft for a set screw, but the walls are to thin to get any turns, so I have resorted to gluing the pot to the axle. Once accomplished, it is a simple thing to read the value of the pot to see where the arms are.
Vex Ultrasonic Sensor not responding SomeoneKnows Programming 6 18-12-2007 16:48
Vex line follower sensor kit program jbill30 Programming 5 12-05-2006 14:43
Vex Sensor Sample Code nonother FIRST Tech Challenge 2 08-05-2006 16:49
VEX Ultrasonic Sensor delay P1h3r1e3d13 Programming 4 28-03-2006 13:45
Sensor or no Sensor For Autonomous mode Kyle1010 Programming 14 22-01-2003 13:10
