Go to Post So, you're saying there's a correlation between hard work and success? Who woulda thunk it?! - Tom Bottiglieri [more]
Unread 04-06-2006, 22:47
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: Offseason gearbox project... maybe this gearbox has helical gears?
Originally Posted by Pat Fairbank
The sounds made by the two gear meshes in the box are supposed to be two octaves apart. Since two octaves would mean that the higher frequency is four times the lower one, I'm guessing all that means is that the medium-sized gear in the left side of the picture has four times as many teeth as the small gear beneath it, on the same shaft.
It's not really that big a deal engineering-wise, but the attention to detail is nice.
Here's the page detailling how the gearbox works.
pic: Helical Gears? Joe_Widen Technical Discussion 8 15-06-2006 14:59
request for info on gearbox gears jskene Technical Discussion 0 08-01-2005 18:07
helical gears Max Lobovsky Technical Discussion 10 16-04-2004 22:48
helical gears efficency Andrew Dahl Technical Discussion 0 07-01-2003 13:02
