Thread Tools |
Rating:
Display Modes |
Re: Building a special coffee table...suggestions
If you use polycarbonate or acrylic, you'll be annoyed when it gets scratched by just about anything that you put on top. Plus, some household chemicals will cloud or discolour plastic. The only thing that's really practical (with similar aesthetic properties) is a thick piece of glass, probably on the order of 1/2" to 5/8" thick—you need to be able to put significant weight on it, just for safety (you don't want it collapsing when someone leans on it, or worse, mistakes it for a seat, and you want it to be heavy and rigid enough to stay level and planar, even if the stuff on top is unbalanced). See if you can find someone who will sell you a 4' circle of tempered glass, with a finished edge (rough, polished, beveled—anything without sharp edges).
If you must use thin plastic, because of cost, don't extend out to 4'; instead, keep the overhangs small (2" or so, maybe), so that you don't inadvertently tip the table by leaning on the top. Alternatively, if you don't mind damaging the tire, drill holes through it, and fasten the top with through-bolts—maybe using some 1/2" flat socket-head cap screws, recessed into the tabletop and secured on the inside of the tire with nuts. That will at least retain the look—but if I had a souvenir like that, I wouldn't necessarily want to drill through it. And, by the way, recent F1 tires are made by Bridgestone, or previously, Michelin. It's been a while since Goodyear made tires for F1 cars themselves—maybe it's another racing series that you're thinking of? In fact, Goodyear makes tires called F1, but they aren't F1 tires! Last edited by Tristan Lall : 06-06-2006 at 00:28. |
I'd visit a couple of salvage shops/yards for old doors, windows, mirrors -
windows in their frames (round) can be found - Also a new round grate from a barbeque pit with a oil pan on top for holding glasses or magazines. Last edited by JaneYoung : 06-06-2006 at 17:50. Reason: typos |
I planned on drilling through the tire anyway |
I would say you should go to some thrift stores and used furniture stores to begin with and see if you can find a table top of some kind to use. I would say if you used a piece of wood even painted it wouldnt be sorta lame. The reason is since your tire is gonna be on its side its just gonna look like a big round piece of rubber, and most people wont even think about it being a sweet f1 tire.
If you cant Find a suitable tabletop And dont want to spend the money on a glass top (prolly expensive) I would say you could do the wood thing but cut out a window in the center so you can see the tire. As far as structure, Seeing as how i have never actually tested the strength of an f1 tire i would say it might be a pretty wobbly table if you drill through it, so some sort of nice structure to keep it stable might be a good idea. I would Def say look in stores and stuff for somthing you could modify, if someone did the work for you already why hassle over making an inferior top. (a quick ebay search finds many glass coffee tables in the 50 dollar range) |
You can purchase circles of tempered glass in various diameters. I recently bought a 4' diameter one at Pier 1 Imports for just over $100 - a three foot diameter version is somewhat less costly, and sounds like the right size for your tire. Tempered glass is very tough, hard to break, but turns into little cubes if you manage to shatter it - safe
To mount it, I'd suggest dabs of a strong adhesive (like silicone sealer) or something stronger mounted to a few metal studs, which mount through the tire. Take a photo when it's done! |
How about getting one of those round patio furniture tables with the expanded metal type top? I've seen them in various colors (black, white, green) and in various diameters (usually 3' and 4'). Cut the top off and bolt it to the tire. You could probably find one used for pretty cheap and paint it some really cool color you like and even paint the car number of you favorite driver on it or something. Red against the black tire might look kinda cool.
#7
DJ,
I am liking the patio table idea. They all have this really nice hole in the center for an awning. This would make an interesting way to attach the table top without having to drill the tire. Just run a threaded rod through a piece of PVC down the center of the tire into a plywood base. Paint the entire thing black so it is hidden in the background of the tire. You could even buy some lug nuts and use those on the top of the threaded rod for added effect. Or add a really nice hubcap to the top and you wouldn't have to hide anything underneath. Hubcaps are cheap when you pick them up off the road. Being able to take it apart for moving I think would be an essential part of your design. I agree with the smell, clear gloss polyeurathane should cure that and keep the tire smooth and shiny. Inside and out, please. ( I know you don't care about dusting now, but you might in the future. |
#9
My dad got me the tire in 1996 and I guess it was sitting in the guy's attic he bought it from for a few years. I bet you the tire is probably a good 15 years old. Fortunately, there is no smell to the tire anymore. A little history behind the tire, it was used for time trial testing in England by Bertrand Gachot. He raced from 1989-1995 and from what Ive seen, he wasn't very good in F1. It seems like he was always with a very underfunded team. ![]() Last edited by D.J. Fluck : 08-06-2006 at 01:46. |
| How refreshing really is coffee | MisterX | Chit-Chat | 0 | 02-04-2004 23:21 |
| Image Discuss: Team 624 takes a coffee break?!?! | CD47-Bot | Robot Showcase | 4 | 21-02-2003 09:42 |
| Coffee can 802.11b antenna | MattK | Chit-Chat | 1 | 05-11-2002 17:19 |
