Re: Cutting stainless steel discs
Last year my team used a bandsaw to cut 1" keyed stainless steel rod. We used a lathe to scribe each cut. Worked fine. You could try using a mill with a solid carbide bit, that should do the trick (I heard the lighten those KOP gears in minutes). They are relatively cheap if you have the piece to hook it up to the mill. If i had to get one, Id buy <Vibration-Free Rough/Finish Carbide End Mill 3/8" Mill Dia, 2-1/2" O'all Length W/ Square End> part number <8745A13> from McMaster. Its $42.38. It would be a good investment if you need to make alot of them.
Consider making the tooling to punch out the disks, and use your big press. 10 tons should be plenty.
The problem with Greenlee punches is that they keep the hole nice and clean, but bend up the disks created in the process. You need the other direction. To mount on the press ram, all you need is a 1 inch diameter bar. Ideally of something hardened. The bottom surface should be flat, and the edges sharp, as that's what will do the cutting. the female die to mount on the table is also a hard piece of something, with a 1" hole in it - but the top surface is not flat. (Trying to punch the whole circumference in one shot takes too much force). Instead, it is angled like a V, the depth of the V being about 5-10x the material thickness - maybe 0.100" or so. Deeper cuts better, but deforms the disk more. The punch coming down hits the upper edges of the die - for example, at 12 and 6 o'clock - to start, and as it moves down, the cutting edge eventually reaches the low point of the V, at 3 and 9 o'clock. Look at these to get the idea, but remember, these have the center punch like a V (kinda) and the outer die flat - you want the opposite. Good luck, Don |
You could check with a metal tag supplier, such as http://www.metaltags.com/stainlesssteeltags.htm
You could get a blanking die fro your press, or possibly find a carbide-tipped annular cutter with a 1 inch diameter interior for use on a drill press. |
| Cutting | cprogrammer | Inventor | 6 | 28-10-2005 10:35 |
| Welding stainless steel to mild steel... can it be done? | Travis Covington | Technical Discussion | 3 | 27-01-2004 19:11 |
| Steel Blends | Wetzel | Technical Discussion | 2 | 15-09-2003 17:01 |
| steel tubing | BBFIRSTCHICK | Rules/Strategy | 2 | 14-01-2003 22:03 |
| Steel Edge | AJ Howard | Rules/Strategy | 1 | 18-01-2002 18:52 |
