Go to Post Someday I will have to learn how tagging and reps work. I already know how search and brain farts work. - kstl99 [more]
Unread 06-06-2006, 15:34
acer_7 acer_7 is offline
acer_7 is on a distinguished road
Extension Mechanism
Hi all,
Hope ur all fine . .
I wanna ask about something please. I wanna make an extending pipe consisting of 2 or 3 layers and I want to make it very simple and speed is not important. I am participating in a robot contest and this mechanism is very important for me, so i really need ur help.
How can i use a motor for that type of extension? I need an extension for about 6 or 7 meters.
Thanks in advance . .
Unread 06-06-2006, 15:38
Billfred's Avatar
Billfred Billfred is online now
Re: Extension Mechanism
Do you mean more like this:
http://www.chiefdelphi.com/forums/sh...extension+lift
or more like this:
http://www.chiefdelphi.com/forums/at...achmentid=2834
The means for doing the two are somewhat different.
Unread 06-06-2006, 16:09
Joe_Widen's Avatar
Joe_Widen Joe_Widen is offline
FRC #1675 (The Ultimate Protection Squad)
Joe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud of
Ahh yes. Our team had something exactly like this. It was a cascading lift. It was in Billfred's second link on the left. What we did is we took 3 pipes and they cascaded. We used a CIM motor and the kop parts gearbox. Now it looks like you dont quite know what FIRST is. So here, you could by a CIM motor from < http://www.ifirobotics.com/first-store.shtml > its part number < FR801-001 >. Now buy gearing for a reduction of about 20:1 or 30:1. I recomend 3 stages. 2 through gearing and 1 through chain and sprocket. Now what we did is we went to a local sailing shop and bought sailboat pulleys and a white rope. They were both rated for 1500+ pounds. We took off the outer coating which is just for protection. We had 3 tubes that fit snuggly inside each other. I'm guessing you would want to use 3 tubes that are each 3 meters long and the one on the bottom being 2.5 meters. We used a mill to key each tube for the ropes to run. We drilled holes in the pipe near the edge and used a 1/8" stainless steel rod. We mounted the pulleys and tied the rope. Finally we welded it to 1/4" Aluminum disc and then hooked it all up to a 2.5" od spindle. The spindle was then hooked up to the cim with the gearing. I think ours was 27.16 to 1. I dont know much about the electrical part so someone else can help you there.
Finally in college =]
2009 Midwest Regional Champions - Thanks 111 and 1625
Unread 06-06-2006, 22:06
Simon Strauss's Avatar
Simon Strauss Simon Strauss is offline
None #1155 (Sciborgs)
Simon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant future
Send a message via AIM to Simon Strauss
My suggestion is that you take a look at Greg Needel's presentation on designing competitive manipulators, which can be found here if you scroll down about half way to where it says Needel. The presentation was quite good when i sat in on it at nationals and has a few ideas that should be helpful on how to pull off what was posted by Joe and Bilfred above. Also i suggest that you look through the rest of it because it has some interesting solutions for some other things that i have a feeling that you will need for whatever you are building. If you have any other questions on specifics Greg is reachable through these forums and myself and many others here either heard the presentation or know its contents and can help you if need.
also this might give you some ideas
-Simon
NYC Chairmen's Award Winners 2007 Thank you team 2265, you were our project and we couldnt have done it without you all
New Jersey Regional Finalists thanks to teams 359 and 486 Aloha
"Beware of the Ska Robot Army!" -The Aquabats
Unread 07-06-2006, 07:25
Well, the type of extension i need is a horizontal one. I don't need to lift anything. I am using this extension mechanism as mean of blocking another robot. I have thought in the fork lifting mechanism like the one Billfred has sent in this link http://www.chiefdelphi.com/forums/a...tachmentid=2834 but I don't know how would it affect the balance of the robot; especially when u extend for about 6 meters.
If I used a light material, will it work ?
Unread 07-06-2006, 07:39
Acer,
An extension for 6-7 meters would need some serious counter balance or a support at the end to hold up the extensions. How much stess will the device receive from the blocking action? Will the opposing robot be able to crash against your device? If the answer is yes, you might want to come up with a different strategy.
As to telescoping assemblies, Small Parts sells tubing that nests inside the next larger tube, but they are not long enough for the 6-7 meter dimension. On our robot lasst year, we used some drawer slides from McMaster Carr. They were heavy but allowed us to have and extension that went up to about 5 meters vertically with a 2 meter height when collapsed.
Unread 07-06-2006, 12:46
RogerR's Avatar
RogerR RogerR is offline
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
i'm not sure what how stiff your blocking mechanism needs to be, but maybe a nuremburg scissors mechanism would be better suited? it folds up relatively compactly, and is fairly simple to actuate. on the down side, they can be somewhat flimsy, especially when fully extended (the reason i tend to shy away from them).
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 07-06-2006, 12:57
Joe_Widen's Avatar
Well, if you can give a more accurate description of what you need it to do, I'll be more then happy to cad one for you. I'm on summer break.....what else do I have to do?
Unread 07-06-2006, 13:47
Umm . . I will try to explain it more guys & thx for all these replies.
Inspite of the extension being desired to be 6-7 meteres, I don't need it to be stiff at all. I just want it to reach a specific area. The robot competition - I am participating in - has a special playground. Besides, I got a specific start zone for my robots that has limited dimensions. The robot carrying this extension mechanism should have a maximum dimension of 500*1000*2000mm (2000mm is the height).
The scissors mechanism is great but for such distance I need to use large ones and I don't have the place for it as I am using my robot for other things and there are other stuff placed on it.
Can't the forklifting mechanism be modified for such purpose ? I also thought that I would use a fishing rod but I couldn't get an idea for extending them using motors or pulleys. Air was another idea to use in extending the rod but to use that I need an electromagnetic switch and other pneumatic stuff.
Unread 07-06-2006, 14:10
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
If you don't need it to be stiff, then you can unroll a thin sheet of spring steel, much like a tape measure. This can be motorized, as the steel tape can be shot out (at about 25cm/sec) and recoiled with the same motor.
Is the arm simply touching something 6-7 meters away? If so, then the above suggestion works well.
Good luck,
Andy B.
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Can this be a one-shot mechanism; i.e., can it start within the original 500 x 1000 x 2000 limits, then deploy once to reach the 6000 - 7000 height, requiring manual intervention to get it back to the starting configuration?
And how much payload do you need to raise to the target height?
[edit: I was thinking of some shock-corded tent poles with sections of fishing rod to deploy them.]
Richard Wallace
since 2003
Unread 07-06-2006, 14:11
Billfred's Avatar
Well, here's an idea that might work for you. Have a mass (how much depends on fifty other things) on the end of your line, which you plant at the location. You then drive about with the reel disengaged, like you were casting the line if you were using the rod for its intended purpose. Once you're ready to unblock, engage the reel and start turning.
Unread 07-06-2006, 14:46
Joe_Widen's Avatar
Here, coudl you string 6 of these together and using one pneumatic piston to get the first on out. Then you could hinge the rest together and use a fishing line and rell to pull on them and get them out?
http://www.chiefdelphi.com/media/photos/25088
Unread 07-06-2006, 15:02
Acer,
Are the rules published on the web so we can see them? It might help if we could get a complete picture. Several years ago, our competition had a requirement that allowed many teams to use Andy's suggestion above. There was great fun and anticipation waiting for the "magic tongue" to deploy at the end of a match.
Unread 07-06-2006, 15:25
Does anyone have any old videos or pictures of tape measure deployment or coils of spring steel unrolling from the 2002 FIRST Competition? If this mechanism is legal for Acer's competition, we can all pick the best of these mechanisms and give Acer some good examples.
292 had a motorized tape measure by the end of the season... it was really neat.
111 had a reliable unrolling steel coil.
535 had a bigger version of a motorized coil... it was very impressive.
Andy
pic: 1625 full extension Aren_Hill Robot Showcase 15 07-12-2005 23:12
Extension lift mechanics Steve Compton Technical Discussion 8 25-01-2005 15:47
What File Extension Are You? Joe Matt Chit-Chat 42 27-10-2004 07:07
**IMPORTANT FIRST BLAST**/2004 KOP Checklist Deadline Extension miketwalker FIRST E-Mail Blast Archive 3 16-01-2004 15:54
