Go to Post Travel is a LOT less expensive when you pack the grown ups in the crate. - Rich Kressly [more]
Unread 06-06-2006, 17:04
SgtMillhouse648's Avatar
SgtMillhouse648 SgtMillhouse648 is offline
AKA: Malhon Godwin
FRC #0648 (QC Elite)
SgtMillhouse648 has a spectacular aura aboutSgtMillhouse648 has a spectacular aura about
Send a message via MSN to SgtMillhouse648
Motor Gears
okay, so the gears inside the motor keep on stripping even with the clutch, are there any that are more durable, it seems to always be the three tiered white gear in the back side of the motor,
thanks
malhon
Unread 06-06-2006, 17:17
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
Re: Motor Gears
thanks
malhon
go to the local hobby house and get a metal geared servo. I went through atleast 2 plastic onces before i stepped up the a metal one for my R/C truck. I haven't had any problems with my vex motors.
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 07-06-2006, 00:51
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
Re: Motor Gears
okay, so the gears inside the motor keep on stripping even with the clutch,...
malhon
I'm curious; are you intentionally working it as hard as possible, or is this just the result of long-term "normal" wear and tear? I haven't stripped any yet, but I am wondering how long until it happens....
Blake
White Paper Discuss: Approx. Motor Spec for Taigene Motor Joe Johnson Motors 2 22-01-2005 16:36
Globe motor - no lubrication in gears! jskene Motors 1 19-03-2004 11:04
Grinding Down Drill Motor Gears fred Motors 3 21-02-2004 22:13
Helical gears that come with new drill motor Joe P Technical Discussion 4 12-01-2003 11:09
