Go to Post Rule 1. Never take Dave's hint's seriously. Rule 2. Watergame. - AndyB [more]
Go Back   Chief Delphi > Technical > IT / Communications
Unread 06-06-2006, 15:38
Bill_Hancoc's Avatar
Bill_Hancoc Bill_Hancoc is offline
Volkswagen Enthusiast
AKA: Bill Hancock
FRC #0573 (MechWarriors)
Bill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud of
Send a message via AIM to Bill_Hancoc
Question Linux USB Dual Booting
I am new to linux and a considering installing it. I dont want to mess with my internal HD just because i dont want to. I dont need to access linux when i am away from my desk i mainly want to use it to learn and just mess around with. I have a DELL Inspiron 6000 with XP home on the internal HD. I recently got a very cheap HD and made it external through USB. i have a 60GB NFTS partition on it for windows file storage and the remaing 20GB are unallocated. Is it possible to install Fedora Core 3 on the 20GB partition and Boot from it when i feel like using linux. I have no intention of trying to boot on another computer only this one.
MechWarriors 573
Unread 06-06-2006, 15:42
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Re: Linux USB Dual Booting
Have you considered a Linux LiveCD?
You just boot from the CD and it throws you right into a completely set up Linux environment. It's good for when Windows breaks itself, or if you want to get your feet wet in Linux.
Unread 06-06-2006, 15:44
AKA: Bill Hancock
Yup knoppix is fun but i want to go a little further and install it and learn about some of the different ways of doing things.
And knoppix doesnt let me really install all the drivers i need like for my wireless card and other things that i want to do.
MechWarriors 573
Unread 06-06-2006, 17:33
MattD's Avatar
MattD MattD is offline
AKA: Matthew Douglas
FRC #0228 (GUS Robotics)
MattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to behold
Send a message via AIM to MattD
I also have a Dell Inspiron 6000. I installed Ubuntu 6.06 last weekend on my internal HD (I partitioned it so that I could have a dual-boot with XP Pro and Ubuntu). To my amazement nearly everything worked "out of the box" including the scrolling on the touchpad and even the wireless. I have an Intel PRO 2915 ABG card. The NetworkManager app makes it really easy to configure wireless connections. Ubuntu's Live CD allows you to play around with it for a bit, and then install right from there. The installer probably has the best GUI installer for any Linux distribution that I've seen. It only asks a couple of simple questions and then pretty much does everything on its own, including the set up of the GRUB boot loader. The part I like the most is that only one single CD is ever needed.
I don't know anything about Fedora, but I do know that Ubuntu truely lives up to its claim of being "linux for human beings" in its latest 6.06 "Dapper Drake" release (June 1).
GUS Robotics Team 228
2010 WPI Engineering Inspiration Award
2010 WPI Regional Champions (Thanks 230 & 20!)
2010 CT VEX Champions
2010 CT VEX Innovate Award
2009 QCC VEX Champions
2009 CT Motorola Quality Award
2007 CT J&J Sportsmanship Award
2006 CT Best Website Award
Unread 06-06-2006, 17:40
AKA: Bill Hancock
I have tried knoppix before and im pretty sure that the touch pad worked fine but it would not recoginze my intel pro 2200 card for some reason. I didnt really want to play around with it at the time but i did find drivers on the intel site for linux so i plan to use those.
I also posted this on linuxforums.com but posted again here since i figured i would get a quicker response. They reply i got on there was
Originally Posted by Linux Forums
if the laptop can boot from the usb yes. but you may need to make a grub boot disc. if that's the case the laptop may not even need to boot from usb because it's possible i've heard to configure grub to do it. i've never tried it, but in theory it should work but as i said you'll probably need a grub boot disc
im not very familier with grub but from what i understand i can install to an external HD and when i want to boot linux from that i put in the grub cd and it boots linux. when i want to boot XP i just boot normally with out the cd in the drive...
is this correct?
ps. The reason i want to use Fedora is because i already have the dvd that came with a book.
Unread 06-06-2006, 17:47
Michelle Celio's Avatar
Michelle Celio Michelle Celio is offline
dream. belive. accomplish.
Michelle Celio has a reputation beyond reputeMichelle Celio has a reputation beyond reputeMichelle Celio has a reputation beyond reputeMichelle Celio has a reputation beyond reputeMichelle Celio has a reputation beyond reputeMichelle Celio has a reputation beyond reputeMichelle Celio has a reputation beyond reputeMichelle Celio has a reputation beyond reputeMichelle Celio has a reputation beyond reputeMichelle Celio has a reputation beyond reputeMichelle Celio has a reputation beyond repute
What don't you just dual boot the hard drive? Do a small enough partition just enough for the OS, save everything to the other partition and you don't lose as much storage space.
UCF History & Education '12
Sometimes you just need to step away
"They were shown as everything is shown, for, like the lens of a camera, history is a force that does not discriminate."
JRW <3
Volunteering: IRI - Reset 07/08, Mission Mayhem 07 - Referee
TnT - Referee 07/08, FLL Florida State Tournament - Judge 08/09
Florida Regional 08 - Reset/Repair, Florida Regional 09/10 - Photographer
8 Events - Web Evaluator 08/09/10
Unread 06-06-2006, 17:52
AKA: Bill Hancock
I want to keep my internal hard drive the way it is just because...i have no real reason to it except that i want to and i need a use for the recently unallocated 20gb on my new external
MechWarriors 573
Unread 06-06-2006, 17:57
Well some bios' have the ability to boot from USB, you should look into if yours can. Then if it can install it on on the external drive and set the bios to boot from USB.
JRW <3
Last edited by Michelle Celio : 06-06-2006 at 17:58. Reason: it helps if I read the orginal post...opps
Unread 06-06-2006, 18:02
AKA: Bill Hancock
I am pretty sure i can boot from a USB (99%) but i read somewhere i would have to do more than this.
MechWarriors 573
Unread 06-06-2006, 20:28
AKA: Bill Hancock
Ok so i just tried to install fedora core and when i got to the partitioning setup it did not list my external HD as one of the options to partition.
I do have USB booting in my BIOS and when it was loading the installer i remember it saying it loaded the USB something it flashed by too fast but does anybody have any suggestions?
Unread 06-06-2006, 22:17
MattD's Avatar
I haven't read through it too much, but I think this guide may be what you are looking for.
Unread 07-06-2006, 05:48
AKA: Bill Hancock
I read through the first few sections and that looks about like what i want...Thank you very much
MechWarriors 573
Unread 07-06-2006, 06:53
I have to agree with Matt. Dapper Drake (Ubuntu 6.06) has really set the bar for what a Linux distribution should be.
Unread 15-06-2006, 21:16
Mazin Mazin is offline
FRC #1720
Mazin is a name known to allMazin is a name known to allMazin is a name known to allMazin is a name known to allMazin is a name known to allMazin is a name known to all
Send a message via AIM to Mazin
I have to comment. Fedora Core is at version 5, in case you were wondering, and as they say, Ubuntu Dapper Drake (I personally prefer Kubuntu, same thing) is much more user friendly. I have had a horrendous experience with FC4 (4 discs???!!!). Ubuntu's partitioner works great too and the new theme doesn't suck like Breezy's did.
You have to set your BIOS settings, to list USB external hard drive /before/ the internal one in the boot order. This way, your bios checks the usb for a boot record before your internal, and you can just disconnect the drive before you boot to use Windoze.
Unread 15-06-2006, 21:45
AKA: Bill Hancock
I actually got it to work thanks to the pdf that MattD sent me but now im working on getting it to connect to the internet...my problem is i dont know how to use linux so that will be a work in progress
MechWarriors 573
Booting Linux off iPod Mike Chit-Chat 11 22-12-2004 12:26
Trouble booting Linux from hard drive after CD install edomus Technical Discussion 2 01-11-2004 08:03
White Paper Discuss: Dual-motor, dual-speed gearbox CD47-Bot Extra Discussion 8 05-04-2004 19:24
White Paper Discuss: Dual-motor, dual-speed drive transmission design CD47-Bot Extra Discussion 9 03-09-2003 10:40
