Go to Post Must...squish....bugs... :p - nighterfighter [more]
Unread 07-06-2006, 04:07
NoodleKnight's Avatar
NoodleKnight NoodleKnight is offline
24 Hours of LeMons?
FRC #0100 (WHS&CHS Robotics)
NoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud of
Send a message via AIM to NoodleKnight
Re: Thanks for the information - But I should have mentioned
Paint it white, the olive drab ammo canister probably absorbs quite a lot of heat from the sun. Additionally, you can channel the heatpipes to the ammo can so that the heat spreads throughout the metal shell (I'm assuming it's metal, since I've never seen a plastic ammo box). 100*F for electronics isn't really bad for electronics, now if it were 100*C...
WHS/CHS Robotics - Team 100 (2003-2006):
2006- Delphi's Driving Tommorow's Technology @ Davis | Imagery Award @ SVR | 2004- SVR Finalists (w/ 691 and 1280)| 2003- Delphi's Driving Tommorow's Technology @ Sac
Is anyone else having this problem hpman247 Programming 10 27-11-2008 02:57
If you are having a problem with one of the members from this site what do you do ? team66t-money General Forum 1 10-02-2005 22:16
If you are having a problem with one of the members from this site what do you do ? team66t-money Electrical 0 10-02-2005 22:06
Having a little problem with the camera... capenga Technical Discussion 3 21-01-2005 10:54
