Go to Post I'll guess those tie-dyed, numbered balls are used for alliance-partner lotto. :D - Richard Wallace [more]
Unread 07-06-2006, 07:31
Re: Robot having internal heat problem
I like the drilling holes idea but it takes away from the asthetic value of the the ammo can. You can add fins (painted to match) to the outside of the can so that airflow will cool the exterior, then mount the electronics (the hot bits) on the interior of the can.
Some kind of scoop intake on the bottom would be out of sight and vent holes on the top would allow convection cooling to remove some of the internal heat as well.
Is anyone else having this problem hpman247 Programming 10 27-11-2008 02:57
If you are having a problem with one of the members from this site what do you do ? team66t-money General Forum 1 10-02-2005 22:16
If you are having a problem with one of the members from this site what do you do ? team66t-money Electrical 0 10-02-2005 22:06
Having a little problem with the camera... capenga Technical Discussion 3 21-01-2005 10:54
