Go to Post "Insanity: doing the same thing over and over again and expecting different results." - Albert Einstein - Edward Debler [more]
Unread 07-06-2006, 01:30
Loki1989's Avatar
Loki1989 Loki1989 is offline
AKA: Mike Parker
FRC #5338 (RoboLoCo)
Loki1989 will become famous soon enough
Programming on a Mac
Is it possible to do and what do i need to do it for robotics
2017 - FRC 5338 RoboLoCo - Mentor
2005-2013 - Team 1544 - One Byte Short
Unread 07-06-2006, 01:40
Jon Jack's Avatar
Jon Jack Jon Jack is offline
VEX Robotics
no team (No Team)
Jon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond repute
Send a message via AIM to Jon Jack
Re: Programming on a Mac
I don't think that there is any Mac native software for programming FIRST robots. You could run VirtualPC to emulate a Windows PC and run all the MPLab stuff that way. If you have a MacBook or a MacBook Pro you could run BootCamp and install Windows and then run MPLab without any emulation. Take your pick, but as far as I know there are no Mac versions of MPLab.
Team 1538 / The Holy Cows, 2005-2016
Unread 07-06-2006, 07:42
Bill Moore's Avatar
Bill Moore Bill Moore is offline
Iv2gr8sons
AKA: Be More
FRC #0365 (Miracle Workerz)
Team Role: Team Spirit / Cheering
Bill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond repute
Send a message via AIM to Bill Moore
You may want to look into how well developed the Darwine project is. That will allow you to run Windows programs without the WinOS.
http://darwine.opendarwin.org/
Three Signs You Are Getting Old: 1) You forget things, 2) You begin repeating yourself, 3) You forget things.
Unread 07-06-2006, 08:14
petek's Avatar
petek petek is offline
What would Dave do?
AKA: Peter Kieselbach
FRC #3654 (Tech Tigers)
petek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond repute
Send a message via AIM to petek
Has anyone out there in CD-Macland tried running MPLab on WinXP on a MacBook yet? Or with a virtual machine under OS X, like Parallels?
Just wondering if there are any issues with USB-serial converter drivers or other hardwareish things.
Pete Kieselbach
Unread 07-06-2006, 10:41
I'm not too familiar with Mac stuff, but I know someone got FRC programming to work with Eclipse.
Eclipse works on Mac.
There's a MacOS native solution!
Unread 07-06-2006, 17:22
Kyle Fenton Kyle Fenton is offline
GET IT ON!!
FRC #0121 (Rhode Warrior)
Kyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud of
Send a message via AIM to Kyle Fenton
Not exactly. Even though you can write C code using an editor like eclipse, the PIC compiler is still Windows only. You can set up the compiler in windows to work with eclipse, but without a Mac OS X compiler, there is no way to program your RC.
Rhode Warriors
NAVSEA/Raytheon/URI/Middletown, Portsmouth, Tiverton, Mt. Hope HS
Quality Robots Since 1996
Unread 07-06-2006, 20:08
Mr. Steve's Avatar
Mr. Steve Mr. Steve is offline
No relation to Mrs. Steve
#1626 (Falcon Robotics)
Mr. Steve is an unknown quantity at this point
I haven't tried it, but I asked the gentlemen in the Apple store who said that one of the reasons Boot Camp was designed the way it was was because they had to make sure any windows specific hardware with less-common drivers would still work.
In a nutshell, "If it works in windows, it will work in bootcamp" was his response.
Falcon Robotics
Unread 12-01-2007, 16:01
JohnC's Avatar
JohnC JohnC is offline
my other name is nigel
FRC #0360 (360 Revolution)
JohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the rough
Send a message via AIM to JohnC
I have a Core2Duo Macbook Pro.
I have Parallels with WinXP with service pack 2.
MPLab and friends work wonderfully, and compiling with mcc18 is successful.
However, the RadioShack USB to Serial adapter that I just installed drivers for isn't working. The documentation says that when I plug in the USB end, Windows should create another device in my "Ports (COM & LPT)" section in device manager. That doesn't happen in Parallels, though it does happen on a regular desktop PC.
So that has been my experience. Anybody have ideas? We were so close...
What place are we at? ... TODAI!
Unread 12-01-2007, 16:13
Robby's Avatar
Robby Robby is offline
AKA: Kevin Beranek
FRC #0269 (Cooney Robotics)
Robby has a spectacular aura aboutRobby has a spectacular aura about
I have experience with vmware, none at all with parallels. In vmware there is a dialog to configure what hardware to emulate for the virtual machine and there is the ability to give the vm access to a real serial port. I would imagine that there is something similar for parallels. I tested it on a linux host with windows guest and it worked without problems with the radioshack usb to serial adapter.
Unread 12-01-2007, 16:32
karlcswanson's Avatar
karlcswanson karlcswanson is offline
karlcswanson is just really nicekarlcswanson is just really nicekarlcswanson is just really nicekarlcswanson is just really nicekarlcswanson is just really nice
Did you install drivers for the USB adapter on the mac, or on Windows XP?
Unread 12-01-2007, 16:42
You need to sync devices in Parallels to the VM. More specifically, put your VM in "windowed" mode, click the USB symbol in the bottom right corner of Parallels, and click the device "On"
Unread 12-01-2007, 20:44
GET IT ON!!
Here is an article about sharing a serial port using Parallels
http://www.macosxhints.com/article.p...70111135928615
Rhode Warriors
Unread 12-01-2007, 21:05
dk5sm5luigi's Avatar
dk5sm5luigi dk5sm5luigi is offline
AKA: Nick Galotti
FRC #1735 (Green Reapers)
dk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud of
Send a message via AIM to dk5sm5luigi
I was successfully able to run easyC Pro in Parallels and download the code to the robot. This was about a month and half ago before Parallels fully supported USB 2.0 so the download was a little slow. I haven't tried it since with the new support but I can only assume it works faster now.
Team 1735 Green Reapers: 2005-Present
Team 190 Gompei: 2001-2005
Team 155 Technonuts: 1997-2001
http://www.first-a-holics.com/
http://www.findrobotparts.com/
Unread 12-01-2007, 23:56
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
easyC PRO works in both Parallels and Bootcamped XP. We are also offering free copies to the team or person who can make it install and run in DarWine.
Unread 17-01-2007, 17:35
unknownmosquito unknownmosquito is offline
FRC #0900
unknownmosquito is an unknown quantity at this point
Since the IDE doesn't matter the real question is this: is there a compiler and/or IFI loader that works with Macs (natively)?
Furthermore, has anyone had any luck with QEMU (called Q for Mac) and MPLab?
CAD on a Mac sanddrag Inventor 14 21-11-2005 13:08
Works on Mac? spears312 IT / Communications 8 12-01-2005 10:31
mac? AlbertW Chit-Chat 9 29-03-2003 21:01
Mac Programming tiskippy Programming 2 12-02-2003 00:08
Mac Programming? tiskippy Programming 11 27-01-2003 23:15
