Go to Post When teams work together to design things rather than going it alone, you can really come up with magnificent machines. - JesseK [more]
Unread 07-06-2006, 22:22
kiettyyyy's Avatar
kiettyyyy kiettyyyy is offline
FRC #1538 (The Holy Cows)
kiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond repute
Send a message via AIM to kiettyyyy
Wiring Solinoid to Digital I/O
Hey All,
My i'm trying to wire up a spike relay to a digital in and out, but it happens to only go in one direction (remember digital is only a 1 or a 0), im thinking i should split a PWM cable and set the black as a shared ground between two digital i/o, and the red going to one digital i/o and the white going to another digital i/o. Is this right?
Whats your opinion? Or if i'm totally wrong, whats the correct method to wiring a spike relay to a digital i/o?
Thanks!
-Kiet Chau
2004-2008 - Software Developer/Driver on Team #968
2008-2011 - Software Developer/Coach/Mentor/"Engineer" on Team #968
2011-Present - Mentor & Engineer on Team #1538
www.team1538.com
Unread 07-06-2006, 22:28
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: Wiring Solinoid to Digital I/O
That's not necessary. Here's the Spike manual; it's got the correct method using the relay outputs.
Or do you have a reason to want to connect two separate digital I/Os, instead of the relay outputs?
A fuller description might also allow us to suggest some other options.
Unread 07-06-2006, 22:35
kiettyyyy's Avatar
But thats for using relay outputs.. I need a digital output because i'm using an EDU-RC board.
-Kiet Chau
www.team1538.com
Unread 07-06-2006, 22:51
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
The Spikes aren't PWMs, they just use a PWM cable. You can figure it out looking at the program aliases. At any rate, on the relay's PWM cable, black is black/ground, red is reverse, white is forward. So you'd connect the red cable to the white pin of a second digital IO.
Here's IFI's info on it:
Spike FAQ
Spike Manual
EDIT:
As it says, you need to get 12V of power to the spike, so no using 7.2V batteries.
Unread 07-06-2006, 23:23
There's a solenoid out port on the EDU board. Use that.
Unread 07-06-2006, 23:53
BrianBSL BrianBSL is offline
FRC #0190
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
Originally Posted by kiettyyyy
Hey All,
Thanks!
Your assumption is correct on how to wire it, but might not necessarily work. I have had problems with vex controllers driving spikes before (but only certain spikes - the old style blue's IIRC), where the digital IO wasn't able to source enough current, so you might need to try the solenoid outputs if it doesn't work. Double check that the output of the Darlington pair on the solenoid outputs is 5V though, and not 7.2.
Edit: after thinking about it, if you can get it to go one direction, then you likely won't have the probelm I was having, and wireing it the way you said should work. Too much time at work and then in the robot lab tonight for me.
My posts represent my personal views only, and do not represent the views of either my team, Team 190, nor its primary sponsor, Worcester Polytechnic Institute.
Unread 08-06-2006, 00:31
kiettyyyy's Avatar
Dont worry about that 7.2v part, i have a breaker panel wired up to a 12 volt battery. The EDU-RC will be powered using the 7.2 battery.
I think splitting the PWM into two parts would work.. About that shared ground.. Should i just stick a wire in to the pwm connector (on the black female pin) and solder it, then do the same to the 2nd pwm connect? I'm afraid i might short something :-/
-Kiet Chau
www.team1538.com
Unread 08-06-2006, 08:44
Ground is ground is ground is ground. All those little black pins go to the exact same place and have the (nearly) exact same potential, barring odd very small resistance and capacitive effects, I suppose. So you shuldn't really have to worry about splitting the ground and sending it somewhere else.
Unread 08-06-2006, 20:59
kiettyyyy's Avatar
Okay i finally soldered the wires and stuff.. it doesnt work.. my code is just.. rc_dig_out02 = 1; rc_dig_out03 = 0;
Why wont it move the solenoid??
I have black wired to black
white wired to white, and red pin moved to white pin
-Kiet Chau
www.team1538.com
Unread 08-06-2006, 21:18
Hmm. Do you know if it's the red wire that's not working or is it the white wire that's not working? That is, make the white wire IO = 1, and the other = 0 and see if it still works in that direction. If it doesn't then your wiring might be faulty somewhere. If it works in that direction but not the other, then your wiring of the red wire might be bad.
Unread 13-06-2006, 02:40
kiettyyyy's Avatar
OOPPS! I forgot in the EDU.. you have to specify the port to become an input or output.. that IO stuff.. not that rc_dig_out...
It works fine now!!
Thank you for all your help!
-Kiet Chau
www.team1538.com
Digital Caliper as a Digital Readout on Small Mill sanddrag Technical Discussion 9 13-10-2005 22:51
Digital Cameras Jeff Waegelin Chit-Chat 10 05-06-2003 11:45
Digital videos archiver 2001 1 24-06-2002 03:57
digital camera archiver 1999 4 23-06-2002 23:17
Digital Filters? archiver 2000 2 23-06-2002 22:55
