Go to Post Common sense can take you a long way!!! - ClintDog [more]
Unread 11-06-2006, 08:34
negfrequency's Avatar
negfrequency negfrequency is offline
the guy with the drawings
AKA: Willomatic
FRC #1559 (Devil Tech)
negfrequency is just really nicenegfrequency is just really nicenegfrequency is just really nicenegfrequency is just really nicenegfrequency is just really nice
Send a message via AIM to negfrequency
Flat Pattern "Situation"
I was wondering if it is possible to get a curved, or "bent" piece of sheetmetal, and then turn it into a flat pattern. The general trends in inventor dont allow stuff like this, but i was wondering if there was something i missed. A common application of this would be like the planks used on the hull of a boat (generally cut and then shaped after being steamed).
alright, from what i hear, sheet metal is going to vastly improved in version twelve, and hopefully allow this sort of thing if it isnt already possible. input?
www.evolved-ideas.net
-KOP CAD parts available for download
You know your me if.....
5) your 91 honda civic dx drives @ warp .000005376, not 60 mph
4) You know what "Bi-directional parametric associativity" is
3) Playing Diabolo does NOT mean you are a level 24 mage.
2) You've discovered you can rearrange the letters in William to spell "I am Will".
1) Your bicycle is 3 times more expensive than your car.
Unread 11-06-2006, 11:40
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Flat Pattern "Situation"
Inventor has a "Flat Pattern" tool when working with sheetmetal parts. Is this what you are looking for?
Unread 11-06-2006, 14:13
AKA: Willomatic
not specifically. Read my boat example again. To design a boat you need to bend the sheets of plywood to contour to a hull shape. Making these in a sheet metal part file, and then flattening them would give you approximate measurements of the sizes of plywood sheets. i hate myself for asking this question btw because im pretty sure you cant do it. My only concern is whether you can at least do it in 12, because i heard sheet metal is going to be improved substantially.
Unread 11-06-2006, 17:04
run the trap!!!
Team Role: Human Player
Are you actually making a boat with inventor?
I designed a boat with inventor, but I found it far easier to draw each frame and then use a loft to create the hull.
-Philip J. Fry
Unread 12-06-2006, 07:48
Robert Thacker-'s Avatar
Robert Thacker- Robert Thacker- is offline
2007 Autodesk Inventor Winner
FRC #0836 (RoboBees)
Robert Thacker- is a jewel in the roughRobert Thacker- is a jewel in the roughRobert Thacker- is a jewel in the roughRobert Thacker- is a jewel in the rough
The only qway to get curved peices, like if you're modeling a shaver or a boat, is with the loft tool. This will get you the effect you need.
Mentor on FIRST Team 836: The RoboBees
Alumni Team 103:
2005, 2006, 2007, & 2009 National Autodesk Inventor Award Winner
Unread 12-06-2006, 10:25
AKA: Willomatic
alright. I guess lofts are thway to go then. Thanks for the help. btw doesn anyone know the new sheetmetal featres that are supposed to be introduced in twelve?
rendered image "situation" negfrequency Inventor 2 09-05-2006 19:51
New NEMO White Papers! "Creating a Killer Packet" and "25 Ways to Sponsor" Jessica Boucher Team Organization 0 10-08-2005 10:55
"Thunderbirds" Vs. "Team America" Which one will rule the box office? Elgin Clock Chit-Chat 3 07-09-2004 19:53
Conflict between "Initialize_Tracker()" and "pwm13 & pwm15"? Kevin? gnormhurst Programming 3 22-02-2004 02:55
how tall is the ramp when in "up" and "balanced" position??? archiver 2001 1 24-06-2002 00:54
