Go to Post "If everything is possible, there is the possibility that something is impossible..." ::sigh:: :) - Kims Robot [more]
Unread 11-06-2006, 14:39
shadowops06 shadowops06 is offline
shadowops06 is an unknown quantity at this point
PID
Hello, I am trying to find a PID code for the vex system and not having any luck. Does anyone have a code that will work or a resource I could use to find it.
Unread 11-06-2006, 22:47
DonRotolo's Avatar
Back to humble
FRC #0832
Re: PID
Hi, this is a good place to start.
Note that PID is just a mathematical formula that calculates what the real-time output value (e.g., for a motor output) should be. You just write a formula and the Vex controller does the math. Yes, as easy as it sounds.
Don
Unread 12-06-2006, 06:34
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: PID
There's also a white paper here which will help you get started.
Unread 12-06-2006, 11:33
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
Re: PID
Can you take a piece of code from this website and modify it to suit the vex controller.
http://kevin.org/frc/
Unread 13-06-2006, 08:32
EricS-Team180's Avatar
EricS-Team180 EricS-Team180 is offline
SPAM, the lunchmeat of superheroes!
AKA: Eric Schreffler
FRC #0180 (SPAM)
EricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond repute
Re: PID
You may also find this article from embedded.com to be useful:
PID Without a PHD
This year we controlled our shooter wheel speed and turret position with code adapted from it.
Eric
Don't PANIC!
S. P. A. M.
Unread 16-06-2006, 22:48
FRC #0180 (SPAM)
Re: PID
ooops.....my apologies to Don Rotolo. Somehow I missed that he already posted the same link I did. ....now where did I put that reminder for that eye exam?
Don't PANIC!
S. P. A. M.
Concept of PID explained ConKbot of Doom Technical Discussion 11 27-01-2008 00:11
Tuning PID Code Rick TYler Programming 17 30-01-2007 00:46
PID without a Ph.D. Joe Johnson Programming 3 07-02-2006 17:37
PID Control Chris Bright Programming 9 26-03-2005 19:44
PID Control Loops ttedrow Programming 7 05-12-2002 12:03
