Go to Post An FRC team's success should not be measured in how many robots it can build or how many blue banners it can collect. It should be measured by how many engineers (and other professionals) it 'builds'. - jvriezen [more]
Unread 14-06-2006, 09:33
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
Re: VEX Start Kit Projects
Originally Posted by artdutra04
The Vex Ultrasonic Sensors are spec'ed at 3 inches to 10 feet. So in order to ensure that an object (wall) can never be closer than 3" is to place your sensor at least three inches inside your robot frame. Like this:
Voila, no more 3 inch problem!
Yeah - thought about that, but then you can't put anything in the space between the sensor and the wall/objects... Maybe not a big deal, depending on what the bot needs to do, whether you are rotating the sensor. Etc.
Thanks for the suggestions and the slick illustrations!
Blake
Vex start up code run PWM outputs without Rx intellec7 Programming 3 05-05-2006 23:29
vex programming kit Alex Burman FIRST Tech Challenge 1 30-03-2006 18:30
Start a Vex team NOW! skimoose FIRST Tech Challenge 4 25-01-2006 14:43
VEX kit SALE/DISCOUNT !! Stu Bloom FIRST Tech Challenge 10 13-11-2005 23:24
VEX EDUbot hybrid or $50.00 VEX kit? Tazlikesrobots Robot Showcase 15 13-08-2005 22:12
