Go to Post FIRST is just a single step in a multi-step process. Rome wasn't built in a day, and neither are solutions to the world's problems. - Tim Baird [more]
Unread 13-06-2006, 21:26
animatorkid's Avatar
animatorkid animatorkid is offline
ouch
FRC #0079 (Team 79)
Team Role: Animator
animatorkid is an unknown quantity at this point
Talking New video I want an opinion on
Hi guys, I've got something new. I've posted a link to the website that my video is on. I just entered it into a contest and I wan't to know how good (or bad) it is. Download it, don't view it off the website because it stretches the video a bit and it screws things up.
PS It sounds terrible in surround sound. alas, I don't have surround sound so I can;t listen to it and fix it. It also sounds a litle metallic because of the compression.
Tell me what you think!
Technically, if you placed a black hole on your robot with enough mass so that your robot is entirely within the event horizon, size constraints will no longer be a problem!
Is that smoke coming from from the victors or servos?!!!
:if only we had an electric beaver!"
you know you play online games too much when your teachers ask why you type "T" before every sentence.
Unread 13-06-2006, 21:43
Tomasz Bania's Avatar
Tomasz Bania Tomasz Bania is offline
FSN Cor. Det/Pal 2006
AKA: Micro3000x
FRC #0818 (Steel Armadillos/Genesis '02)
Tomasz Bania has a spectacular aura aboutTomasz Bania has a spectacular aura about
Send a message via AIM to Tomasz Bania Send a message via MSN to Tomasz Bania
Re: New video I want an opinion on
Probably a stupid question:
Where is the link?
Playstation Network ID: micro3000x
Thank You to the Rookie Teams at the Detroit Regional for accepting our invitations for the elimination rounds. Good Luck!
Team 818 Regional High Definition Video 2008,CLICKHERE
Unread 14-06-2006, 12:12
ouch
FRC #0079 (Team 79)
Team Role: Animator
Where is the link?
I'm an idiot. sigh
sorry about that, heres the link:http://www.acidplanet.com/artist.asp?PID=814551&T=294
If the link doesn't work, search for "acoustic rhythms" as the title or "crazy mixer" As my artist name. (I usually put my music on this account but I found I could put my video's on it too)
Unread 14-06-2006, 12:35
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is online now
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
Looks good but I have one nitpick: The bass strings should get lower in pitch when they're shorter, not longer. Lengthening the string will only lower the pitch if the tension stays constant (ie a guitar or violin). This appears to be working more like a stretched rubberband. Other than that tho, it's really awsome!
Unread 14-06-2006, 12:45
Bill_Hancoc's Avatar
Bill_Hancoc Bill_Hancoc is offline
Volkswagen Enthusiast
AKA: Bill Hancock
FRC #0573 (MechWarriors)
Bill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud of
Send a message via AIM to Bill_Hancoc
Wow that is really cool....how long did that take to make?
MechWarriors 573
Unread 14-06-2006, 12:52
I like it. I love animations of things that dont exist in the real world - esp when you create new things, like new musical instruments.
How easy would it be to change the view point of the camera?
The camera seems pretty static, only changes a few times. It would be more interesting if you zoomed in, maybe 25% of the time, synched with the music.
Its hard to see much detail from the wide angle view.
Unread 14-06-2006, 13:04
fimmel's Avatar
fimmel fimmel is offline
Founding Mentor, Team 2370
AKA: Forest Immel
FRC #2370 (iBots 2370)
fimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond repute
thats sweet nice music and animation. btw what program did you use?
Unread 14-06-2006, 13:14
Originally Posted by Nuttyman54
...The bass strings should get lower in pitch when they're shorter, not longer. Lengthening the string will only lower the pitch if the tension stays constant (ie a guitar or violin). This appears to be working more like a stretched rubberband. Other than that tho, it's really awsome!
I had the impresion the instrument was stopping down (fretting) the string, not pulling it.
Depending on what the string is made of you wouldn't need to pull it very far to double its pitch, but if you are fretting the string then twice the length gives half the pitch. That appears to be the relationship in the video.
Unread 14-06-2006, 17:18
Capt.ArD Capt.ArD is offline
Animator
FRC #0116 (Epsilon Delta)
Team Role: Animator
Capt.ArD will become famous soon enoughCapt.ArD will become famous soon enough
am i stupid or misunderstanding? If the tension in the string is constant, then a longer string will be lower than a short one. I play bass guitar, and i know that if you play an open string (no fingers on the frets) it will be lower than when my fingers are on the 5th fret, which is lower than the 10th fret. this is why those squealing guitar solos are played way up the neck by the body. shorter string = higher pitch.
Unread 14-06-2006, 19:47
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
I think what he means is the less tension there is on a string, the lower the pitch will be. Take a rubber band, stretch it out, and then pluck it. Then relieve the rubber band a little bit, and pluck it. The pitch will be lower.
It appears as if the string is being stretched and relieved, rather than being fretted.
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
Unread 14-06-2006, 19:54
ouch
FRC #0079 (Team 79)
Team Role: Animator
Red face Re: New video I want an opinion on
Man! You guys are quick!
The main thing seems to be with the strings. The idea was that the strings were to be pinched at one point like you would on a guitar, and that point changes with the pitch. The tension was constant. However, the due date for the contest was coming up fast (To quote Douglas Adams: "I love deadlines, I love the wooshing noise they make as they go by") and so I kinda improvised by using that moving cylinder, not realizing it looked like it was stretching the string.
For Bill Hancoc: It took about a month to make.
For KenWittlief: It would be easy to change the camera view, the problem is the render time. I'll probably get around to it eventually.
For Fimmel: I used The trial version of acid xpress 5 to make the music, And plain old 3dsmax6 for the actual animation. Everything you see was keyframed, no plug-ins or anything.
P.S. Have you guys ever seen animusic? Its really awesome and it was made on 3dsmax too. (that's where I got the idea for this)
Thanks for your opinions on this, it really means a lot to me.
Unread 14-06-2006, 20:54
Mazin Mazin is offline
FRC #1720
Mazin is a name known to allMazin is a name known to allMazin is a name known to allMazin is a name known to allMazin is a name known to allMazin is a name known to all
Send a message via AIM to Mazin
Ya, I saw an amazing Animusic at Fry's that I've been wanting to duplicate (I mean, I was inspired by it), once I find time to wrap my head around MaxScript. It had pipes shooting tons of metal balls that just happened to hit instruments (marimba, drums, etc.) to make a melody. Truly fantastic.
It's pretty obvious where you got your idea, and it's pretty good - I like it.
Unread 14-06-2006, 22:31
run the trap!!!
Team Role: Human Player
Good job! This is some nice work.
I'd even go so far as to say its on-par with some of the Animistic videos .
I can't say I like Animistic (I thought it was kinda dull) but I admire your use of 3dsmax to sync music to video.
I don't know if you knew this, but the instruments in Animistic were actually programed to sync to the notes of the music. There was no human intervention in animating the clips; the instruments literaly 'played themselves'.
I'm no animator, but I would be interested to know if you can do this with our version of 3dsmax, or if it takes a special program.
-Philip J. Fry
Unread 14-06-2006, 22:32
ouch
FRC #0079 (Team 79)
Team Role: Animator
A man! I love that one! it's called pipe dream. Did you know there is two of them?
Unread 15-06-2006, 20:27
RoboJedi75's Avatar
RoboJedi75 RoboJedi75 is offline
Do or do not, there is no try.
AKA: Nate Fong
FRC #0075 (RoboRaiders)
RoboJedi75 has a spectacular aura aboutRoboJedi75 has a spectacular aura aboutRoboJedi75 has a spectacular aura about
Send a message via AIM to RoboJedi75 Send a message via Yahoo to RoboJedi75
I like the video (and music).
It's very similiar to Animusic. And it's nice to see another animator duplicate something like it. I just noticed that two of the large string players don't play at the end. Is that part of the music or just an animation 'oops'?
Was the big thing in the center supposed to be a big light? It took me a while to catch that. It does blend in with the white background a little.
Nate Fong
Team #75, the RoboRaiders, Alumni
New School Website- WANT *YOUR* FEEDBACK!!! Joe Matt Website Design/Showcase 17 30-06-2004 16:25
New Video Idea JakeGallagher Chit-Chat 0 04-04-2004 12:20
Enough pictures... I want to see some video! f22flyboy Robot Showcase 7 02-03-2003 18:20
So, you want a list of new ChiefDelphi threads IN your phpBB2 forums? Brandon Martus Announcements 10 16-12-2002 22:12
I want to welcome a new member! Joe Matt Chit-Chat 12 20-09-2002 14:19
