Vex Programming Help!
Hi. I am programming my vex robot and was wondering if the remote control stick could be configured so it is a tank drive, upwards and downwards, and each left and right movement of each joystick could be set to trigger a few motors. I was wondering if this is possible with regular C programming and what the code looks like.
If this is not possible, can any of the other buttons on the vex remote control to be set to trigger motors? Thank you. |
Re: Vex Programming Help!
If you are using MPLab just have something like this:
pwm01 = PWM_in2; // Left drive = left joystick up/down pwm02 = PWM_in3; // Right Drive = right joystick up/down //for one motor on each joystick left/right pwm03 = PWM_in1; //extra motor 1 = Left joystick left/right pwm04 = PWM_in4; //extra motor 2 = right joystick left/right //for multiple motors on each joystick left/right pwm03 = pwm04 = ... = PWM_in1; pwm05 = pwm10 = ... = PWM_in4; I don't know EasyC , but you should be able to do something similar. |
| VEX programming | Gene F | Programming | 14 | 08-08-2006 22:21 |
| Vex Programming help! | davelu | Programming | 4 | 23-12-2005 22:03 |
| Vex Programming Module | Vex | FIRST Tech Challenge | 3 | 30-08-2005 21:27 |
| Vex like programming? | Morenoh149 | Programming | 2 | 09-07-2005 22:32 |
| Vex Programming | foobert | FIRST Tech Challenge | 3 | 24-06-2005 01:09 |
