Go to Post With computers, every once in a while you see something that makes you think "I could have done this, why didn't I think of it? It would have made my life so much easier." Now is one of those times. - Nadav Zingerman [more]
Unread 18-06-2006, 18:38
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
Blinking Vex Battery Charger
I purchased the a Vex kit back when it was on sale. I just dug the kit out of the closet after it has been sitting for probably over a month.
No matter what port I plug the 7.2 volt robot battery into after a few minutes it starts blinking at me.
I checked the voltage which was 7.97 volts but the battery appears to be dead while on the robot.
Anyone know what the problem might be or has anyone experienced this?
Edit: Does the battery have to be sitting on the base?
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 18-06-2006, 19:01
Steve0100's Avatar
Steve0100 Steve0100 is offline
Steve0100
Steve0100 is on a distinguished road
Re: Blinking Vex Battery Charger
Hey,
Yes, the battery has to sit in the charger in order for it to work. There are switches engaged with the 7.2V motor when it is in the cradle that tells the charger what voltage to charge at. When charging batteries buried in the middle of a robot, I just tape the switches down with duct tape, so the charger "knows" that a 7.2V battery is connnected. Without this, you will get a blinking light.
I've also had a battery go bad on my already- fizzled and fried after only one charge, so if you still get a blinking light with the battery firmly in the cradle, I'd take it back for a new one.
Hoe this helps!
Steve
Battery Charger for long term battery care DougHogg Kit & Additional Hardware 0 08-02-2003 15:25
Battery Charger Circut PyroPhin Electrical 1 30-01-2003 13:49
battery charger archiver 2001 3 23-06-2002 23:20
Battery Charger jgrater Kit & Additional Hardware 1 12-04-2002 14:14
Exide Battery Charger jeffreym Electrical 2 25-03-2002 15:06
