Go to Post Its just going to be a dirt game. We are going to be using shovel bots to dig for gold. Anyone who strikes oil gets the 100 point bonus! - Uberbots [more]
Unread 18-06-2006, 22:32
Joe Matt's Avatar
Joe Matt Joe Matt is offline
Wake Up Get Up Get Out There
Joe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond repute
Plexiglass Help/Question
I've recently taken on a project for the summer: http://home.comcast.net/~jleblanc77/cube/
I'll be converting an old PowerMac G4 Cube (shell, no working parts) into an aquarium for college (I currently have the names Steve, John, Gil, and Lisa picked out for obvious reasons, but I digress.)
I'm looking to purchase a 1/4" thick 9 x 9 inch (or so) piece of plexiglass, clear. I was wondering where I should buy it, either online or at a store. As I'm going to be making an investment here, I was wondering if there should be a way I should handle it or cut it. I'm going to use a Dremel to cut the edges and it down to size.
Thanks guys.
Unread 19-06-2006, 00:06
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: Plexiglass Help/Question
It looks like you're using it for the bottom of the tank, right?
If so, you might want to just use a belt sander to make the rounded corners—you'll get a cleaner finish than with a Dremel, because you'll be removing material as it heats up, as opposed to just melting it due to all the friction from using the slitting wheel on the Dremel. If you can't get it cut precisely to the size you need, get something oversized, and then score and break it, rather than trying to cut material off with the Dremel, in a long pass. Or put it on a table saw. In general, trying to cut a straight line with a Dremel is an exercise in frustration, and won't likely be pretty.
By the way, acrylic can be laser-cut...if you know of any place that can do it, you might be able to convince them to do it cheaply.
Unread 19-06-2006, 00:41
Joe Matt's Avatar
Thanks Tristan.
I'm looking into other options besides the Dremel, the reason why I brought it up was because the guy who created the page used one. I don't know if I can get a hold of a table saw (I'll ask my dad) or a laser cutter (again, Dad!) but I'll see what I can do. Yes, it's for the bottom of the tank.
Unread 19-06-2006, 01:57
Now that I think of it, the table saw might create some problems, if you don't have just the right blade, and a solid method to hold down the workpiece. Acrylic can shatter easily, and using a common saw blade probably won't work too well. Polycarbonate, on the other hand, cuts nicely.
Unread 19-06-2006, 03:22
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
You could also use a band saw or a jigsaw (orbital saw). The jigsaw will work, but the trick is to use the finest tooth blade and sandwich the plastic between scrap pieces of plywood to keep the Plexiglas from chattering and cracking. Then take your time to cut slowly and at a steady pace until completed. This is how I cut Plexiglas acrylic sheets in the shop.
As always, try this method or any method on a scrap piece of plastic to see if it works.
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Unread 29-06-2006, 15:53
Joe Matt's Avatar
Just an update, I got the cube and pexliglass (thanks to Don Rotolo!) and I'm going to start the project soon. Here's a pic of the cube....
http://homepages.udayton.edu/~mattjosw/cube.jpg
More updates later.
Unread 03-07-2006, 13:12
Joe Matt's Avatar
Updates
It's inplace!
I used a jiggsaw and my dad to help with the cutting. After that I used the file Dan provided to even it out, then sanded it down till it fit.
The top and inside the sides are somewhat scratched, but I'm going to remove them with some Wet/Dry paper at different gradients, then use some Brasso and silver polish to put it back good as new.
It's also sealed, and I went a different way of mounting it. This time instead of nails, I used a small shelf type system, which adds a slightly more futureistic look to the cube because of it's metal grounds that hold it to the cube.
Pictures here.
Unread 03-07-2006, 13:37
Tapoore's Avatar
Tapoore Tapoore is offline
AKA: Tom Poore
FRC #1519 (Mechanical Mayhem)
Tapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of light
Cool! I like it!
- www.mechanicalmayhem.org -
* 2015 Granite State District Event Champions
* 2013 Einstein Finalists
* 2006, 2010, 2011 Granite State Regional Champions, 2009 Chairman's Award
* 2012, 2013 North Carolina Champions
Unread 03-07-2006, 16:46
chrisinmd's Avatar
chrisinmd chrisinmd is offline
AKA: Chris Pickett
FRC #0888 (Robotiators)
chrisinmd is a jewel in the roughchrisinmd is a jewel in the roughchrisinmd is a jewel in the rough
Send a message via AIM to chrisinmd
Very cool, good work!
Virginia Tech 2010!
Chesapeake Regional
Pittsburgh Regional
Unread 05-07-2006, 21:45
Joe Matt's Avatar
It's all done.
I double sealed it and did an overnight water test. No leaks! I bought some fish stuff (plants, rock, food, net) and let that sit with the water and added the special stuff to the water, then got the fish today and added him. As promised, pics!
wide shot
focus on apple logo
I'm also going to add instructions on how to recreate this on my website under the projects tab.
Unread 06-07-2006, 11:59
Onward through the fog.
This looks great Joe. It's going to be a hit at college.
Way to go!
~ Helen Keller
(1880-1968)
Unread 06-07-2006, 16:23
CraigHickman
Posts: n/a
I've gotta say, that's freakin awesome. You should add some (insert favorite color here) LED's into the bottom of the sides so you can also make it a glowing lamp at night time.
Please Help!!! OI question... capenga Programming 5 09-02-2004 07:26
Plexiglass Archon Off-Season Events 6 25-04-2003 11:17
Help!!! Battery question trollin1st General Forum 7 12-02-2003 08:48
Can we use Plexiglass? Devil's Kid Technical Discussion 2 07-02-2002 21:49
Density of Plexiglass? turbidum Technical Discussion 14 24-01-2002 22:48
