Originally Posted by Elizabeth Ritchie
Rule changes at IRI:
1. There will be no muzzle velocity ball speed limit. Rule S02 under
Aim High's Game Rules section 4.3.1. is voided for IRI. Fire at will!
Keep in mind that the 120 pound weight limit is still in effect. Scales
will be available, please don't make us use them. If a team modifies
their robot enough to make other teams wonder if they are over the
weight limit, we will check their robot weight. Consider your GP as you
make any robot mods.
We are also working on other rule modifications, and will send out
detailed information once these are finalized:
a. We will be replacing the DQ for 1 point goal incursion with a
penalty. The level of severity for this penalty is to be determined.
Our intent is to still discourage incursion, but to not have DQ's for
this action. We are re-wording rule G21 to make this clear.
b. We are considering the replacement of the serpentine draft with an
alternate method. Our intent is to either go back to 1-8, 1-8 or try
another method for 2nd round selection. First round selection will
definitely be 1-8. Once this is finalized, an update will be sent.
Thanks!
Libby, Chris, and Andy
Dang - We just dialed the 1213 PID in to 11.9 +- 0.3 MPS :-/
Otherwise, great changes. The incursion DQ should have been dropped after automatic scoring considerations became moot.
As for (b): I'd like to see elimination matches where the seeded teams weren't able to select each other. I think good scouting would come into play and the outcome would be less predictable.
Also, in the "other rule modifications" area, mere contact outside the bumper zone should not be penalized (as was threatened at the Champs). The penalty should be reserved for HITTING with force, otherwise it takes away some pretty neat, yet benign, ball catching contraptions.
Jack
