Go to Post IRI: Where the Egos Go to Tie. :ahh: - Ian Curtis [more]
Unread 19-06-2006, 13:35
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Adding Bluetooth to Vex
Originally Posted by mechanicalbrain
Im not that familliar with VEX but maybe a gumstix (www.gumstix.com). They have built in bluetooth and I know they work fine with the IFI controller.
Let me re-emphasize this. You'll probably have a lot less trouble if you just buy the 400MHz Gumstix with Bluetooth, which will run you about $169. Connect one of the serial ports on the Gumstix to the Vex, and write a couple of lines of code on the Gumstix to redirect I/O from the wired serial port to the Bluetooth UART. Then you have your Bluetooth Vex, and you have a nifty off-board co-processor should you ever need it.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
how to build a VEX programming module bblack7489 FIRST Tech Challenge 78 09-06-2011 16:03
Useful VEX Tools Joe Johnson FIRST Tech Challenge 4 26-04-2005 18:48
Vex Robotics Vex FIRST Tech Challenge 0 14-04-2005 13:48
VEX Robotics vexrobotics FIRST Tech Challenge 8 30-03-2005 23:25
VEX Kits ARRIVED!!! Joe Johnson FIRST Tech Challenge 14 28-03-2005 19:28
